Hey guys, is anyone here a fan of low cars
I just lowered the line and goddamn that thing is low now.
Didnt really know what to expect, just jacked it up and changed the springs. dropped it again and hmmm LOWRYDA!!
donna have to get those as plates. lol or BOUNCIN cos thazz the other thing it does now.
Anyways just looking for any opinions on lowness. anyone else got a lowered line but not with coilovers (coilovers hmpff why do it properly when you can just dump it) and would like to share with me their driving experiences in terms of handling etc.
And please no links to the whiteline website. lol
latas
RiaZ
Hey Adrian I will try to call you about the "view the dump & front pipe session" at EVO R
https://www.sau.com.au/forums/topic/9705-low/
  • Replies 60
Mine has Apexi coilovers which where far too low when I bought it. It used to scrape the tyres in the arches, and scrape exhaust bits on dips in the road. I lifted it 25mm, and it still below legal, but because I have stock body it rarely scrapes now. Except in my own driveway which has a big slope and a lump at the top. That 25mm didn't make a huge difference in handling, and its still set firm, but then I don't know how a stocker handles.
Might want to have the wheel camber checked, or make friends with tyre retailers :)
https://www.sau.com.au/forums/topic/9705-low/#findComment-147900
I have KYB Coilovers lowered below legal limit.. I must have the hardest suspension on earth!!
I have stock Type-M front bar, and it scrapes on just about everything. the middle of the exhaust scrapes on speed humps at most shopping centres. the rear muffler (it's angled) is FAR too low to reverse upto a kerb efficiently.. bah!
but all in all, the car handles like a dream.... looks dam schmick. So i'm happy.
https://www.sau.com.au/forums/topic/9705-low/#findComment-148028
When you lower em too low , and my front is right on that limit, then the front lower control arms actually invert and hang lower at the inner pivot than the outer mount on the hub.
This creates a rocking effect on patchy road surfaces and also most shock bodies have no upward travel left which means on reasonable bumps the stops are getting hammered.
Hence this is why you get the occassional crash over a bump.
Having said that , a line lowered till the sills on the floor is a sweet look.
As b2barker said , if lowered the camber goes to neg and on the rear it is hard to get it off as there is insufficient
adjustment.Inside tyre wear then becomes an issue.
Cheers
Ken
https://www.sau.com.au/forums/topic/9705-low/#findComment-148073
100mm clearance off the ground is the legal limit,
but from the wheel centre to the mid of the wheel arch needs to be lime 320mm in the front and 330mm in the back.
mine is not near there.
hang on.....
just measured it roughly
front is like 300mm and rear is like 285mm
hehe
looks slammed. if i could just get some 18's
https://www.sau.com.au/forums/topic/9705-low/#findComment-149828
Cant roll a coke under mine.
My tyres hit wheels arches too - but as for making friend friends with tyre retailers i havent had a prob with tyres they have been 90% tread since ive had it in Aug. I would be more grovelling to the likes of pedders! The rubber bit that stops it hitting the wheel arch on mine has warn away and the shockies have packed up (i think that was the basic explanation) so they wanted to put new springs in it which will lift my front end a little but the ansewer to that was NO! so now i gotta get special shockies - i think - suspension isnt really my area of expertise i kinda say its making my CD player skip fix it but i dont want it any higher - like the difficult female i am. Oh and be prepared for lots of scrapes thats why i didnt want to take on mandurah in the next run because that place just is shocking for low cars i cant even get on grannys driveway cos the curb is too high.
https://www.sau.com.au/forums/topic/9705-low/#findComment-151648
reading back about what GTRken said about the stops getting hammered and the bouncy castle effect thats whats happened to mine - i think the stops are pretty much non existant now. But theres apparently a solution without making it any higher that will last for ages and if it doesnt my mechanic will be seeing what the inside of my boot is like!! Just dont play the CD player on bumpy roads and advoid country driving because you'll be itching to get out of it by the end.
https://www.sau.com.au/forums/topic/9705-low/#findComment-151655
Nizmo , what type of shocks are on the car.
If they are the usual Tein , Hks etc , they are designed for smooth racetrack style roads.
They have HUGE spring rates and the shock valving is usually so stiff it doesn't need the springs.
A few of us go to Wilkinson Suspension in Bayswater. He sells quality gear ( Bilstein, Koni , whiteline , superpro etc ) and can get you good shocks and springs that actually go up and down.
Cheers
( no I'm not on commission )
Ken
ps luv your signature hehe ...close the door.:lol:
https://www.sau.com.au/forums/topic/9705-low/#findComment-151694
Originally posted by Pva_Glue
also a condition known as "TItt Giggler" :P
It's been also reported to male genders... due to Man Boob effect
cheers
Joe
I think you mean Jiggler , joe .
Or do you mean joe Diggler ??
Cheers
( cracks me up , bwahaha )
Ken
https://www.sau.com.au/forums/topic/9705-low/#findComment-151698
all sounds very expensive!! im the kinda person that likes to take my car to one place and have them handle it - too many cooks spoil the broth as i found out with my Z31. Ive been told estimate $500 to have it fixed - should last as long as i have car - sounds decent to me. I would rather spend the money on something that actually makes it go faster!!
https://www.sau.com.au/forums/topic/9705-low/#findComment-151861
$500 to repair the shocks, supply new springs and bump rubbers sounds pretty cheap.
I think Wilko does Koni and king springs for about $1100-1200 but at least you know they will work.
Trust me , decent suspension will make your car go faster , around corners and even on the ( heaven forbid ) dragstrip.
Cheers
(ndf )
Ken
https://www.sau.com.au/forums/topic/9705-low/#findComment-151904
Oh and in reply to taking it to one place, nobody is an expert on everything ( not even phptf ) but if you know which specialists to take it to a better result will occur.
For instance I wouldn't take my car to Wilkinsons to get tuned but visavis I wouldn't take it to Exhaust dynamics for a w/alignment.
Cheers
Ken
https://www.sau.com.au/forums/topic/9705-low/#findComment-151908
Hey Ken,
I resemble that remark. I always take my car to the best man/woman for the job. I too have super stiff suspension, and will be taking it to Wilkinson Suspension to let them have a look at it and recommend a handling package for racing.
Nizmo,
$500 will not get you very far when it comes to good suspension, I would shop around and check out what each are offering first.
See'ya:burnout:
https://www.sau.com.au/forums/topic/9705-low/#findComment-152028
your right joe , that is an odd question.
Funny thing is , coming from you , it sounds perfectly normal:D
Answer is no, you would have to take the springs out and replace them with solid blocks and fill the tyres full of concrete cos they have a cushioning effect as well.
Cheers
( we get some weird ones )
Ken:lol:
https://www.sau.com.au/forums/topic/9705-low/#findComment-152325
    • I came here to note that is a zener diode too base on the info there. Based on that, I'd also be suspicious that replacing it, and it's likely to do the same. A lot of use cases will see it used as either voltage protection, or to create a cheap but relatively stable fixed voltage supply. That would mean it has seen more voltage than it should, and has gone into voltage melt down. If there is something else in the circuit dumping out higher than it should voltages, that needs to be found too. It's quite likely they're trying to use the Zener to limit the voltage that is hitting through to the transistor beside it, so what ever goes to the zener is likely a signal, and they're using the transistor in that circuit to amplify it. Especially as it seems they've also got a capacitor across the zener. Looks like there is meant to be something "noisy" to that zener, and what ever it was, had a melt down. Looking at that picture, it also looks like there's some solder joints that really need redoing, and it might be worth having the whole board properly inspected.  Unfortunately, without being able to stick a multimeter on it, and start tracing it all out, I'm pretty much at a loss now to help. I don't even believe I have a climate control board from an R33 around here to pull apart and see if any of the circuit appears similar to give some ideas.
    • Nah - but you won't find anything on dismantling the seats in any such thing anyway.
    • Could be. Could also be that they sit around broken more. To be fair, you almost never see one driving around. I see more R chassis GTRs than the Renault ones.
    • Yeah. Nah. This is why I said My bold for my double emphasis. We're not talking about cars tuned to the edge of det here. We're talking about normal cars. Flame propagation speed and the amount of energy required to ignite the fuel are not significant factors when running at 1500-4000 rpm, and medium to light loads, like nearly every car on the road (except twin cab utes which are driven at 6k and 100% load all the time). There is no shortage of ignition energy available in any petrol engine. If there was, we'd all be in deep shit. The calorific value, on a volume basis, is significantly different, between 98 and 91, and that turns up immediately in consumption numbers. You can see the signal easily if you control for the other variables well enough, and/or collect enough stats. As to not seeing any benefit - we had a couple of EF and EL Falcons in the company fleet back in the late 90s and early 2000s. The EEC IV ECU in those things was particularly good at adding in timing as soon as knock headroom improved, which typically came from putting in some 95 or 98. The responsiveness and power improved noticeably, and the fuel consumption dropped considerably, just from going to 95. Less delta from there to 98 - almost not noticeable, compared to the big differences seen between 91 and 95. Way back in the day, when supermarkets first started selling fuel from their own stations, I did thousands of km in FNQ in a small Toyota. I can't remember if it was a Starlet or an early Yaris. Anyway - the supermarket servos were bringing in cheap fuel from Indonesia, and the other servos were still using locally refined gear. The fuel consumption was typically at least 5%, often as much as 8% worse on the Indo shit, presumably because they had a lot more oxygenated component in the brew, and were probably barely meeting the octane spec. Around the same time or maybe a bit later (like 25 years ago), I could tell the difference between Shell 98 and BP 98, and typically preferred to only use Shell then because the Skyline ran so much better on it. Years later I found the realtionship between them had swapped, as a consequence of yet more refinery closures. So I've only used BP 98 since. Although, I must say that I could not fault the odd tank of United 98 that I've run. It's probably the same stuff. It is also very important to remember that these findings are often dependent on region. With most of the refineries in Oz now dead, there's less variability in local stuff, and he majority of our fuels are not even refined here any more anyway. It probably depends more on which SE Asian refinery is currently cheapest to operate.
    • You don't have an R34 service manual for the body do you? Have found plenty for the engine and drivetrain but nothing else
