Hey guys, is anyone here a fan of low cars
I just lowered the line and goddamn that thing is low now.
Didnt really know what to expect, just jacked it up and changed the springs. dropped it again and hmmm LOWRYDA!!
donna have to get those as plates. lol or BOUNCIN cos thazz the other thing it does now.
Anyways just looking for any opinions on lowness. anyone else got a lowered line but not with coilovers (coilovers hmpff why do it properly when you can just dump it) and would like to share with me their driving experiences in terms of handling etc.
And please no links to the whiteline website. lol
latas
RiaZ
Hey Adrian I will try to call you about the "view the dump & front pipe session" at EVO R
https://www.sau.com.au/forums/topic/9705-low/
  • Replies 60
Mine has Apexi coilovers which where far too low when I bought it. It used to scrape the tyres in the arches, and scrape exhaust bits on dips in the road. I lifted it 25mm, and it still below legal, but because I have stock body it rarely scrapes now. Except in my own driveway which has a big slope and a lump at the top. That 25mm didn't make a huge difference in handling, and its still set firm, but then I don't know how a stocker handles.
Might want to have the wheel camber checked, or make friends with tyre retailers :)
https://www.sau.com.au/forums/topic/9705-low/#findComment-147900
I have KYB Coilovers lowered below legal limit.. I must have the hardest suspension on earth!!
I have stock Type-M front bar, and it scrapes on just about everything. the middle of the exhaust scrapes on speed humps at most shopping centres. the rear muffler (it's angled) is FAR too low to reverse upto a kerb efficiently.. bah!
but all in all, the car handles like a dream.... looks dam schmick. So i'm happy.
https://www.sau.com.au/forums/topic/9705-low/#findComment-148028
When you lower em too low , and my front is right on that limit, then the front lower control arms actually invert and hang lower at the inner pivot than the outer mount on the hub.
This creates a rocking effect on patchy road surfaces and also most shock bodies have no upward travel left which means on reasonable bumps the stops are getting hammered.
Hence this is why you get the occassional crash over a bump.
Having said that , a line lowered till the sills on the floor is a sweet look.
As b2barker said , if lowered the camber goes to neg and on the rear it is hard to get it off as there is insufficient
adjustment.Inside tyre wear then becomes an issue.
Cheers
Ken
https://www.sau.com.au/forums/topic/9705-low/#findComment-148073
100mm clearance off the ground is the legal limit,
but from the wheel centre to the mid of the wheel arch needs to be lime 320mm in the front and 330mm in the back.
mine is not near there.
hang on.....
just measured it roughly
front is like 300mm and rear is like 285mm
hehe
looks slammed. if i could just get some 18's
https://www.sau.com.au/forums/topic/9705-low/#findComment-149828
Cant roll a coke under mine.
My tyres hit wheels arches too - but as for making friend friends with tyre retailers i havent had a prob with tyres they have been 90% tread since ive had it in Aug. I would be more grovelling to the likes of pedders! The rubber bit that stops it hitting the wheel arch on mine has warn away and the shockies have packed up (i think that was the basic explanation) so they wanted to put new springs in it which will lift my front end a little but the ansewer to that was NO! so now i gotta get special shockies - i think - suspension isnt really my area of expertise i kinda say its making my CD player skip fix it but i dont want it any higher - like the difficult female i am. Oh and be prepared for lots of scrapes thats why i didnt want to take on mandurah in the next run because that place just is shocking for low cars i cant even get on grannys driveway cos the curb is too high.
https://www.sau.com.au/forums/topic/9705-low/#findComment-151648
reading back about what GTRken said about the stops getting hammered and the bouncy castle effect thats whats happened to mine - i think the stops are pretty much non existant now. But theres apparently a solution without making it any higher that will last for ages and if it doesnt my mechanic will be seeing what the inside of my boot is like!! Just dont play the CD player on bumpy roads and advoid country driving because you'll be itching to get out of it by the end.
https://www.sau.com.au/forums/topic/9705-low/#findComment-151655
Nizmo , what type of shocks are on the car.
If they are the usual Tein , Hks etc , they are designed for smooth racetrack style roads.
They have HUGE spring rates and the shock valving is usually so stiff it doesn't need the springs.
A few of us go to Wilkinson Suspension in Bayswater. He sells quality gear ( Bilstein, Koni , whiteline , superpro etc ) and can get you good shocks and springs that actually go up and down.
Cheers
( no I'm not on commission )
Ken
ps luv your signature hehe ...close the door.:lol:
https://www.sau.com.au/forums/topic/9705-low/#findComment-151694
Originally posted by Pva_Glue
also a condition known as "TItt Giggler" :P
It's been also reported to male genders... due to Man Boob effect
cheers
Joe
I think you mean Jiggler , joe .
Or do you mean joe Diggler ??
Cheers
( cracks me up , bwahaha )
Ken
https://www.sau.com.au/forums/topic/9705-low/#findComment-151698
all sounds very expensive!! im the kinda person that likes to take my car to one place and have them handle it - too many cooks spoil the broth as i found out with my Z31. Ive been told estimate $500 to have it fixed - should last as long as i have car - sounds decent to me. I would rather spend the money on something that actually makes it go faster!!
https://www.sau.com.au/forums/topic/9705-low/#findComment-151861
$500 to repair the shocks, supply new springs and bump rubbers sounds pretty cheap.
I think Wilko does Koni and king springs for about $1100-1200 but at least you know they will work.
Trust me , decent suspension will make your car go faster , around corners and even on the ( heaven forbid ) dragstrip.
Cheers
(ndf )
Ken
https://www.sau.com.au/forums/topic/9705-low/#findComment-151904
Oh and in reply to taking it to one place, nobody is an expert on everything ( not even phptf ) but if you know which specialists to take it to a better result will occur.
For instance I wouldn't take my car to Wilkinsons to get tuned but visavis I wouldn't take it to Exhaust dynamics for a w/alignment.
Cheers
Ken
https://www.sau.com.au/forums/topic/9705-low/#findComment-151908
Hey Ken,
I resemble that remark. I always take my car to the best man/woman for the job. I too have super stiff suspension, and will be taking it to Wilkinson Suspension to let them have a look at it and recommend a handling package for racing.
Nizmo,
$500 will not get you very far when it comes to good suspension, I would shop around and check out what each are offering first.
See'ya:burnout:
https://www.sau.com.au/forums/topic/9705-low/#findComment-152028
your right joe , that is an odd question.
Funny thing is , coming from you , it sounds perfectly normal:D
Answer is no, you would have to take the springs out and replace them with solid blocks and fill the tyres full of concrete cos they have a cushioning effect as well.
Cheers
( we get some weird ones )
Ken:lol:
https://www.sau.com.au/forums/topic/9705-low/#findComment-152325
    • Neg, the top one is actually for the front. The sizes are 18x10.5 +18 and 18x11 +32.   I measured many times but I'm sure I'll have problems as this is the thread for problems.
    • Just one thing; tapping tapered threads is tricky. Taps are always tapered and you would generally run it as far as you can, but with a tapered thread you have to stop much sooner otherwise the wide part of the taper will run in too far and you will have to thread the sensor in too far too as well (possible that it will never make a good seal) BTW nice wide wheels, I guess the top one is for the back!
    • Welp, good to know. Will have to wait awhile until steady hands with drills and taps are available. In other news, these just arrived! I will weigh them for posterity. Edit: 11kg each (or 10.9/11.1 depending on what my scale decides over multiple tests, the 18x11 don't seem to weigh noticeably any more than 10.5)
