i am trying to work out which car i want so i thought maybe some other opinions
would help me decide
Both will have the following
Manual or Auto
2 door coupe
R32 later model 92 to 93/ R33 will be around 93 to 95
colour doesnt matter as will be resprayed
stock as possible but dont really care if there are mods
prefer SA
around $10000 for R32 and around $13000 for R33
please help i dont know which one to get
and if anyone has one please post some details and pics of it!!
cheers guys
Edited by SR20 180SX
https://www.sau.com.au/forums/topic/97193-r32-or-r33/
  • Replies 50
Posted Images
i was originally looking for an R32 but went for the R33 because there was a much greater range to choose from.
at the time there was about 2-3 R32s advertised each week that met my needs compared to about 10 R33.
but either was it comes down to your own preference, have a look at a few, test drive the ones you like the sound of and make your decision from there.
https://www.sau.com.au/forums/topic/97193-r32-or-r33/#findComment-1763069
hmm I don't mind either cars.
but speaking from experience of having driving both and ending up owning an R32 myself. I found that even though the R33 is faster and newer and to some shallow minds 'Pull chicks' more lol.
I went the r32 cos I wanted a driver oriented car. sure its old and not as beefy and mean looking stock as an R33 but its lighter and more chuckable. sure the r33 has more power stock too but I'm not into the whole drag thing cos there's no skill involved.
The r33 feels a little too boring. its like nissan went back to a conversative approach as it looked more like a family car. I feel like I'm driving a maxima or camry when I'm in one.
I'm not dissing the R33's as they are great cars to drive still.
but I'm just hearing they are becoming the next VL commo if you know what I mean.
anyways thats my 2 cents. try em out. stock and modded form would be a good testing variable. should also check out the R34 while your at it. big improvement.
https://www.sau.com.au/forums/topic/97193-r32-or-r33/#findComment-1763518
Definatly the R33 you get a RB25 as aposed to a RB20 which i thinks is more like a VL commo, but by comparison the power to weight is pretty similar.
I chose 33 because i didn't want such a old car(and the 15 year rule saw a sh1t load of them come in)........I would only go a R32 GTR personally only because at a flick of a switch it's RWD...........mmmmmm lovin the rear steppin out!!!!
https://www.sau.com.au/forums/topic/97193-r32-or-r33/#findComment-1764017
33 comes with a good motor and gearbox.
All though the R32 is lighter, smaller and has more of a racier feel, the gearbox and motor will eventually have to be replaced with at least r33 bits IF you plan to make 230-240rwkw+
With regards to how quick each car is....
R33 is quicker in dead stock form.
R32 is quicker with real mild mods such as exhaust, fmic and boost due to the R33's rich and retard.
R33 is quicker once you drop a pfc in to it.
Edited by Cubes
https://www.sau.com.au/forums/topic/97193-r32-or-r33/#findComment-1764171
no no no, i have a r31 silloutte and i could comapre that to a vl... not a 33. :P
Edited by DriftR_33
https://www.sau.com.au/forums/topic/97193-r32-or-r33/#findComment-1766043
hahah.. at the R32 comment.. :P
I agree.. It does look a little like a VN cluster surround but still much better. The inlaws have a VN.. The dash surround and center vents etc look damn ugly.
Nothing wrong with the old VL Turbo though.. They are damn light, slightly lighter than the R33 I believe, and make better power with minmal mods than both the R33 and R32.
Exhaust, fmic and some boost and they are up there making the same power as a R33 with the same mods but a fully tuned ecu. :)
hence the SAU dyno day and Natho's 187rwkw VLT with its 2.5" exhaust and small IC :)
https://www.sau.com.au/forums/topic/97193-r32-or-r33/#findComment-1766089
I think the R33 looks rough as simply lowered slightly on a set of nice wheels running 255's.
Start putting body kits on them and they start to look a little ricey.
Then again I think the new HSV's look ricey with their body kits.
R32's are the same.. Nice gtr style front bumper with the type-m body kit slightly lowered on a set of nice wheels running the widest tyres you can fit under the guards.
Body kits generally ruin cars I think. I'm always able to pick the dodgy lines and wavey plastic/fibreglass and think why oh why.....
https://www.sau.com.au/forums/topic/97193-r32-or-r33/#findComment-1766395
    • Hi everyone, I have purchased my first GTR and I want to do a single turbo conversion to it. I've been doing as much research as i can and there are a few things that I can find and need to know. I need to run a coolant feed, coolant return, oil feed and oil return for my turbo setup. Here's what I know so far: On the hot side of the rb26 there is coolant feed, oil feed and oil return. Coolant return will be going around the front of the engine to where the thermostat is located. I will need to block off the rear oil return port. I will be running a turbosmart boost solenoid so any of the factory boost stuff wont be needed. Now onto what I don't know: 1. What do I do with the coolant / vacuum hardlines that run around the back of the motor?. 2. What do I block off or loop or move or remove?. I will be running the OEM intake manifold. 3. Is there anything in particular I need to buy for the cold side of the rb26?. I already have the intercooler and pipes sorted. If you have any pictures or information it would be appreciated. Thanks....
    • The fab work can be as simple as a couple of silicon hoses and clamps to the factory piping.
    • Just sounds like either way you need to do some fab work to get everything to fit, so why limit yourself at that point? If the GCG high flow option is zero effort in and out swap though I'd probably do that. It's almost certainly lowest risk, lowest cost, etc. The HKS GTIII-RS option that Kapr mentioned is laughably expensive for what it is, they charge the exact same for two turbos on the RB26 so their margins are off the charts on that thing.
    • Intake manifold is not a part of the issue. The turbo bolts to the exhaust manifold. That is easy. But close your eyes and picture the physical situation. That is a T3 flange on the manifold and a T3 flange on the turbo. As long as any new turbo has a T3 flange on the exhaust housing, that exhaust housing will bolt to the exhaust manifold. This places the exhaust housing in the same place as the stock one. But now move your mental attention a little further forward. The location of the compressor housing is set by the length of the turbo's core. The stock turbo had a long core. Let's say that it is..... 100mm long. So that would place the compressor housing 100mm forward of the exhaust housing. But a highflow, might well have a centre core that is shorter. Let's say that it is only 70mm long. Now the compressor housing will be 30mm further back in the engine bay than the stock one. This DOES move the turbo's compressor outlet backwards. It also moves the compressor's inlet backwards. You will very likely have to do some work to both the inlet and outlet piping to make everything connect again. I am not say this to make it out to be a bigger deal than it is. I am just pointing out that "bolt on" is sometimes not quite bolt on. The highflow from GCG that Murray linked above (https://gcg.com.au/turbo-charger-upgrade-skyline-gtst-2iu-xtrgts-s1.html ) uses a core that is the same length as the stock core, and so does not require this extra work. It will look very much like the stock turbo. No-one uses GTR turbos of any flavour (stock, or aftermarket) in a single turbo application on RB20/25. It's not a thing. Yes, people have been putting on GT3076, GTX3076 (and bigger and smaller versions of those) and G30s (of various sizes) onto RB20/25 since forever. But these are not "bolt on". Everything except the 4 bolts to the exhaust manifold change with these. And genuine Garretts are expensive. Non-gen, like Pulsar, etc, are cheaper, variously as good or nearly as good. But still not bolt on. No-one in the right mind would pay for an HKS turbo. Not in this modern day and age. Well, yes, the GCG highflow. You could ask HG what he can do to make the compressor housing sit in the original location. There are surely others doing highflows around the world. And some of the eBay/Temu ones (as reported by Dose) work and don't die. Bit of a lottery though. I would send your turbo to GCG (here in Oz) to be highflowed if you want a trivial no-extra-work option. But seriously, the work required to change inlet and outlet piping is not that hard. That's a boost control problem, not a turbo problem.
    • Thank you all for the replys 🙂 I know that intake would be different but that is one pipe at it is not that hard to get(custom one). I meant mainly bolt to the stock manifold and the turbo elbow. I looked and many sites/forums but they are just "old" with some old HKS turbos from GT-R i guess? What about some Garrets?  Or any other turbo? Is there even a turbo which i can just bolt on? 😄 And yeah i know about that new HKS but that is like 2000k USD without taxes/shipping in here   Iam getting a touch up tune but my "problem" is that on the "not" hot day iam getting peaks around 0,9 bar...and when it was around 15 Celsious i saw peak around 1 bar which is just too much for stock turbo. And of course turbo is old and i like to get some new one for a piece of mind 🙂
