  • Replies 42
Posted Images
Rolled my car onto Bel Garage's dyno yesterday. I have attached torque and power curves.
The most we saw was about 990nm and 390rwkw, but my injectors were more than maxed at that level, so we took out a bit of boost.
awesome result, what setup u running? turbo/s, etc?
how come from 5100rpm its not making anymore power? (not having a dig, just a question)
Edited by StageZilla
I wish it made all of it's power by 5100RPM! The aim was not to make peak power anyway, but to get the most area under the curve.
I'm still running the useless laggy peaky GTRS turbos, but somehow, they don't seem so laggy now.
Oh...and the dip towards the top of the rev range is wheelspin on the rollers.
Edited by Mik
awesome result mate. 370+ kw at only 5100rpm is amazing :P
can i ask what type of cams you are running now? and injectors afms?
it must really hammer from about 4500 onwards.
nice! at what boost is it? 1.4? 1.5? these things are supposedly good for nearly 2bar. excellent for a stock stroke 26, would be pulling nice and hard by 4500. once you do your injectors, ive seen these hold power right up to 8grand!
what cams are you running?
beat me to it beer baron :P
Edited by SLY33
Stock bro, even has a stock airbox .....
Nice results there Mik - Get some larger injectors in there STAT!
Why would traction be an issue? It's only got 370rwkw... :lol: Seriously though...traction is not too bad, but I do have pretty sticky 275s all round and it does like to randomly break traction in 2nd when it comes on boost.
Nick...to be honest, I though 700s would be okay. They are about as big as I would like to go on a daily driven car. I'm also running a bit more rail pressure than I would like.
Also something to note is that the torque figures estimated by these dynologs are apparently pretty accurate....just ask Morgs and WilliamsF1.
Awesome Mik, I'd definately upsize those injectors and pump a bit of boost into it. The new motor sounds like its a good one.
Edit: Mine only made 350kw at BEL which on CRD was 319Kw at all four, as a reference. Has since changed.
Edited by Morgs
I don't really care about the numbers to tell you the truth (although the torque one is interesting).
So your car only made 319 at CRD? That's so odd...after what you made at SMW, and speaking to Jason, I would have expected heaps more than that.
Also, Tommy's car made 330ish at CRD irc and a bit under 300 on Bel's dyno in the same state of tune.
I'm more worried about the shape of the curve and how it drives, which is why we spend a couple of hours on the freeway cleaning up the spool-up.
I'll go to the drags eventually, it will be a while though because I'm flat out with work atm.
yes, but what cams and afms? :D
yes the curve does look very good. and like you said the dyno graph is really only relevant to you. It's just lets you know how much improvment you have been making.
Is that the same dyno Jerry made 240rwkw on with his car?
Nice result - doing anything else to it or are you finished? Whens it go to the drag strip? :D
No Andrew , i expect my car to make about 260-270 rwkw on that dyno, but my car is pretty gutless , just about everyone makes more power than me !
I will let you know what power mine makes on this dyno when she goes on it soon .
(yes, but what cams and afms?)
Beer Baron : refer to post 7 . There is plenty wrong with airboxes when you make that kind of power, but he wants a stock car .
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
    • You haven't driven many modern cars then have you? Most of them have sfa steering feel with their stupid electric bullshit steering systems.
