  • Replies 155
Posted Images
Hey, i got the VHT stuff, only cuz i spent about a week trying to track down a supplier of duplicolour metalcast (only to walk into a local supercheap to find out they had it after i already brought the vht stuff)
http://www.vhtpaint.com/anodized.html
the blue anodized + the silver under coat
got mine from autobarn caboolture
Hey, got my R33 GTS afew days ago, doing all little mods to it to make it look good in my eyes. Really wanting to do this DIY but the calipers are much different, guessing because its a GTS
Spraying these wouldn't look so good imo. Would it be practical to upgrade the calipers both for performance upgrade and for looks? + anyone know what rims they are?
Silly me, After making my initial post Donkeys ago, I forgot to show off the finished Project, Btw thanks again paul for a great Tutorial. worked a treat, also gave me a chance to fix up some other things i found wrong. I went with the Metal Cast Blue cause it is just awsome. Also I used Vaseline on the Nissan logo, before the paint, then just scraped the paint off with a Razor blade after painting.
  • 5 months later...
good thread!
i'll be doing mine in 'dupicolor metalcast red' as most agree that this is the best paint for the job.
i will also give it a base coat silver to help bring out the red BUT im not sure if i get the top clear coat...is this needed?
lastly, will this paint ever crack/peel if i track the car?
i didnt bother with the top coat, the finish of the anodized paint was enough for me
as for the cracking/peeling on the track - not sure on that, they say its rated up at 500 F (approx 260 C) intermittently, so how hot do your brakes get???
    • Yes, I know🙄 but the sequential is not in my budget... don't want to reduce power neither, so looks like I'm stuck in the rabbit hole🤣
    • You’ll be very upset when you bust that too not to mention the gearing totally sucks. Don’t do it.
    • Is the panel filter one that is oiled? Have you ever cleaned or touched the AFM?
    • So.... the K&N air box thingo was too big, ended up gifting it to a mate, well, by gifting it he actually supplied food and beer at the pub,  which was nice, as it will not sit on a shelf in the garage for the next 10 years I did trim up some of the existing stuff to neaten it all up and gave it some wrinkle paint, unfortunately it currently has a used and abused mish mash of different types of hose clamps, 4 big fat T bolt type (shit), and a few normal clamps of vairing sizes and brands, but..... only until the 6 constant tension black worm clamps that I ordered from EFI solutions turn up next week Currently the current hose clamps are triggering me hard, LOL Is this the final version, probably not, I really want just 2 silicone pieces, a straight bit of silicone from the filter to the MAF is easy and will happen as soon as I head into Just Jap tomorrow, the problematic part is a 30° silicone bend from the MAF to the TB that I can connect the engine breather from the head, I found that there are bulk head fittings for boat bilge pumps that should work, but until I can get a 30° silicone bend the alloy pipe, and the 11ty thousand hose clamps, are there for the foreseeable future 4 hose clamps are golden, 6 are grudgingly acceptable, the 8 currently holding it all together is just taking the piss    I've also ordered 60 more retaining wall blocks for the front yard, I mis-gonculated the height that was required to get above the base of the Photinia's (red robin's) that are the hedge behind the front fence, currently it is 2 blocks high, and about 1/2 a block short, so going 3 blocks high will be above the base of the red robin's, and allow some room for mulch
