BTW The rods in the RB20DET-R in the HR31 GTS-R Gibson race car were stock so that should give you some indication of strength. ( Yes they were shot peened ).
Unless you rip a Gibson engine down and check, I wouldnt be so sure. I have read the same, and up to recently had little reason to doubt the claim...but now am starting to have my doubts...
my mate has put down 520rwhp on stock RB20 rods - they where only shot peened and ballanced...
He also turned that motor to like 8500rpm or something like that as well...
520rwhp is an awful lot especialy when turning 8.5k redline.
i would really like to see a dyno sheet of that pull.
Remeber the stroke of an Rb20 is fairly short so revs is not such a big problem. Shot peeing rods deos increase the strength of the rod considerbly.
As for them being able to take 520rwhp. That doesn't suprise me but I would have to see it to believe it.
How do the stock RB20DET Rods compare in size to the RB26DETT rods? (other than the length) :P
while revs are something the rb20 is capable of it does increace engine wear and the potential for something down there to let go.....
ive included a pic of the rb20's stock rods from when i tore down the engine and they felt and looked very beefy to me.
i guess the key to the rods holding power is a proper tune and making sure the engine doesnt detonate at all, which is what seems to cause failure.
Edited by carl h
Race car claims are sketchy to say the least.
The gibson cars also had a "stock" intercooler. But for some reason they are different to mine?
yer, its stock position i think, but thats about it.
They dont use the stock Nismo GTS-R manifold either :(
Wish i still have the RB20DET-R in mine. Not to use, just to anchor my boat with :lol:
    • It was a great, but typical track day, and some VB was ingested at the night time debrief 🤪
    • And so, to round this out, I couldn't be happier to confirm @MBS206 has decided to buy the car. He drove down from sunny QLD with a trailer last week and it is off to its new home today. I'll let Matt confirm on next steps but I understand broadly that the plan is to leave it pretty much as is, and just get some quality wheel time with a nicely balanced car that is pretty much track ready. There are a few a jobs still to be done first but nothing too major and I think its a very smart buy Dinner last night at the Paragon with a round of VBs (mostly) for Neil
    • Well, 50 pages and the end of a chapter for this car. We took it out for a shakedown at Wakie yesterday, and everything went well. There were a couple of niggles: - Oil cooler fitting leak - tightened, cleaned, stopped leaking - Radiator cap overflow fitting was leaking....Mark called it, the overflow fitting was threaded in and not tight....tightened, tested and held pressure - Small oil leak at the rear of the block, probably the turbo oil feed - too hot to get at it comfortably but probably just needs to be nipped up - leak at the driver's side rear brake line where it meets the hardline. Fitting wasn't loose, so Matt backed it off and back on, no further leaks - there's also a leak somewhere on the top of the fuel tank, maybe that cross over fuel line - that was has been left to fix when its on a hoist Otherwise than those niggles the car went great, turned great and stopped great so it was a very successful day out. I'm always really nervous when a car first hits the track after a long break, especially with a brand new engine as well but it was great. VID-20251011-WA0007.mp4  Big thanks to @The Bogan who dropped by and helped out, @MBS206 and my nephew Lachlan the apprentice.  Neil's wife Mel also surprised the hell out of all of us by dropping by; she's up in Tamworth these days but was travelling to Melbourne so had plausible deniability for turning up at the garage, it was great to see her but also obviously a bit sad all round.
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
    • Unsolicited advice? Keep the engine as close to stock as you can. Nothing wrong with adding some boost and making a little more power, but given where you are, you really don't want to try to make it into a monster. I can't imagine the roads are up to it, and the lack of locla support when it grenades will be a ball ache. FWIW, If there is a dyno around that you can access, then brand new injectors are a good idea, which will lead you to (at least) putting a Nistune in it, which will allow you to put an R35 AFM on it, all of which will make it possible to make it much much nicer to drive and live with.
