  • Replies 83
^^^hey man wat kit iss on that 32, its real nice by the way :D ^^^
The kit is a Aeromaster Type 1 (which is remarkably similar to a vertex, but not quite). Front back n sides. I bought the original from Japan, which Aresspeed got off me to copy. Ended up keeping it for well over a year and finally fitted my original onto some demo car of theirs and gave me two copies for my trouble. Apparently they're bankrupt now, so not much I can do about it.
haha... hope it's not mate!! Got written off about a month ago!!  :lol:
lol yeah I know, well not written off, it didn't even need a viv check. once striped the damage was far less than it looked, wasn't hard to fix.
Edited by wal
  • 2 months later...
  • 2 months later...
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
