Which Station do you listen to?
32 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
On the way to work this morning I noticed that regular hosts have gone on holidays, which got me thinking - which radio stations do you listen to???
My choices are:
Breakfast (6.00am - 9.00am) - Hughsey, Kate & Dave on NOVA
Drive (4.00pm - 7.00pm) - The SheBang on MMM
At all other times im a channel surfer
Share your thoughts on who's good entertainment and whose not.
https://www.sau.com.au/forums/topic/97310-radio-stations/
Listen to a lot of CD's at the moment as there seems to be a phase of crap music much like the movies. Used to listen to H,K,D a fair bit but generally channel surf.
At work listen to UK stations online either with listen again or live.
https://www.sau.com.au/forums/topic/97310-radio-stations/#findComment-1765070
usually a CD, but on the way to work early in the morn (5am) i flick between nova and fox, they have the highlights from the respective breakfast shows...both are funny, and i just switch between the 2.
those are the only 2 stations i really listen to, mostly fox
https://www.sau.com.au/forums/topic/97310-radio-stations/#findComment-1765152
I'm always flicking between MMM & Gold, there's just too much crap going round & I'm a bit over Nova & Fox.
The Cage in the morning, sometimes the shebang in the arvo, but they've been getting crap, so the ol' function button gets a work out flicking to the cd every 2 mins.
https://www.sau.com.au/forums/topic/97310-radio-stations/#findComment-1765677
    • End game is to: - Remove all the slop from old worn parts - Adjust setup so that the wheels actually fit and the car is drivable (currently it is not because of the extreme rubbing on the guards).   Progress over the last couple of days, removed the rear hubs! Next steps: - Buy bushings - Replace bushings/bearings on hub - Reinstall
    • Cracked deck  And other cam snap stuff
    • A few random issues have popped up since my last update. My WMI pressure sensor failed within about 10 minutes of it seeing liquid. It was a 20$ China special, so I'm not surprised. My name brand replacement should arrive today.  My power steering assist also decided to crap out last weekend. The usual, works for about 60 seconds after starting the car then I lose it. I dusted off my old copy of NDS and connected to the HICAS ECU. Code 4 for assist solenoid.... I tested the solenoid and it's fine.  I knew the day where my HICAS ecu would crap out would come, and I welcome it. It was the last HICAS part on the car that is now in the bin. I've ordered an SSR and I will control the power steering solenoid with my Haltech ecu. It will be nice to have proper speed referenced assist again after all these years.
    • Haha I just finished the last season of TPB: Jail last month. I'm happy they're still pumping out episodes.
