R32 4 Door Posted December 7, 2005 Share Posted December 7, 2005 Hi, What is involved in doing a 5 Stud Conversion to a Cefiro. What parts do I need. Thanks, Chris. Link to comment https://www.sau.com.au/forums/topic/97740-5stud-conversion-to-cefiro/ Share on other sites More sharing options...
Big Rizza Posted December 9, 2005 Share Posted December 9, 2005 Dunno too much about it, but I know Just Jap sell bolt on kits to do it - $799 brand new. Hope that helps! Just Jap.com - 5 Stud Hubs and Conversion Kits Link to comment https://www.sau.com.au/forums/topic/97740-5stud-conversion-to-cefiro/#findComment-1778958 Share on other sites More sharing options...
R34GTT-R Posted December 9, 2005 Share Posted December 9, 2005 I used S14 front hubs and carriers, S14 Four spot calipers and discs. Got all that for $400. Moog ball joints, $150 delivered, I think you can use S14 lower control arms but mine were bent. And just bolted in a complete R32 rear cradle. Link to comment https://www.sau.com.au/forums/topic/97740-5stud-conversion-to-cefiro/#findComment-1778972 Share on other sites More sharing options...
drift monkys Posted December 12, 2005 Share Posted December 12, 2005 im doin mine using the s15 complete setup i.e. hubs.. rotors .. calipers... uprights... before iget started... are the brake lines the same or do i need custom shit??... ummm.. just wanted to know... :s cheers Link to comment https://www.sau.com.au/forums/topic/97740-5stud-conversion-to-cefiro/#findComment-1785076 Share on other sites More sharing options...
Hella Flush Posted December 13, 2005 Share Posted December 13, 2005 im doin mine using the s15 complete setup i.e. hubs.. rotors .. calipers... uprights... before iget started... are the brake lines the same or do i need custom shit??... ummm.. just wanted to know... :scheers <{POST_SNAPBACK}> im doing the same. full s15 - calipers, rotors, hubs, spindles, knuckles, handbrake and lower control arms... anyone know: a) will s15 lower control arms fit? if so benefitial due to possibley further out design? B) handbrake cable... how to modify between a31 and s15 to fit? cheers bigears Link to comment https://www.sau.com.au/forums/topic/97740-5stud-conversion-to-cefiro/#findComment-1786026 Share on other sites More sharing options...
Simon-S14 Posted December 13, 2005 Share Posted December 13, 2005 whats the benifits of 5 stud conversions OTHER THAN wheel choice? Link to comment https://www.sau.com.au/forums/topic/97740-5stud-conversion-to-cefiro/#findComment-1787550 Share on other sites More sharing options...
Softy Posted December 13, 2005 Share Posted December 13, 2005 u will have siker drift skill with 5 nuts holdin ur fatty dish rims on? Link to comment https://www.sau.com.au/forums/topic/97740-5stud-conversion-to-cefiro/#findComment-1787683 Share on other sites More sharing options...
A31Drifter Posted December 13, 2005 Share Posted December 13, 2005 hey i have a set of S15 4 piston calipers rotors master cylinder and booster for sale if anyone is interested. $350 the lot 0410300413 Link to comment https://www.sau.com.au/forums/topic/97740-5stud-conversion-to-cefiro/#findComment-1788197 Share on other sites More sharing options...
R34GTT-R Posted December 15, 2005 Share Posted December 15, 2005 im doing the same. full s15 - calipers, rotors, hubs, spindles, knuckles, handbrake and lower control arms...anyone know: a) will s15 lower control arms fit? if so benefitial due to possibley further out design? B) handbrake cable... how to modify between a31 and s15 to fit? cheers bigears <{POST_SNAPBACK}> Pretty sure S15 lower control arms are different. The size of the bolts where the strut mounts to the carrier are different on S15 also, S13 style shocks might not have enough meat to be drilled out 2mm. If you use a R32 GTS-T rear cradle the handbrake is as simple as clipping the cable back on. You will need a bigger master and a double diaphram booster I think. Link to comment https://www.sau.com.au/forums/topic/97740-5stud-conversion-to-cefiro/#findComment-1792381 Share on other sites More sharing options...
juiceman Posted December 15, 2005 Share Posted December 15, 2005 S13 struts can be redrilled, if done properly, its safe. Its common practice to do so as the s14. s15 struts are longer. You can either use a 14mm drill bit or a 9/16". If you can find them seperately, its possible to just press out the ball joints for the knuckles, and use the matching ball joints, as said before s14/15 are different. You will need the new master with the 32 rear brakes, and possibly a new booster, although it might not be worth the hassle, what has the ceffy got on the rear atm? Link to comment https://www.sau.com.au/forums/topic/97740-5stud-conversion-to-cefiro/#findComment-1792465 Share on other sites More sharing options...
cefiro Posted December 16, 2005 Share Posted December 16, 2005 If you buy 300zx tt spindle and hub from a wrecker, the hub bolts straight up to the S13, then just bolt on the handbrake, and rotor and caliper. Also notice from abservation that R32 GTR hubs looked identical to the 300zx. Can be done for about $300-$400. Also need to get brake booster from 300zx or R32. Here is a good website. http://www.sportcompactcarweb.com/projectc...scc_projsilvia/ Also I think the R32 front calipers are much better than the S14/S15 from memory. Aslo check out Nissansilvia.com.au Had a lot of probs with mine as I have nismo lower controll arms so I was wondering what the hell it had all come off, but seems sorted now. Link to comment https://www.sau.com.au/forums/topic/97740-5stud-conversion-to-cefiro/#findComment-1797663 Share on other sites More sharing options...
Hella Flush Posted December 17, 2005 Share Posted December 17, 2005 thanks for the help guys. couple of mates have done 5stud on their s13s/180s in the past... its the exact same as cefiro under there so ill have a chat with them and get cracking Link to comment https://www.sau.com.au/forums/topic/97740-5stud-conversion-to-cefiro/#findComment-1797792 Share on other sites More sharing options...
cefiro Posted December 19, 2005 Share Posted December 19, 2005 hey guys am in another dilema, thought my rear was a 300zx, and as I have the whole thing appart I need to get some info to grab the parts to change the hub. The 300zx is too large for the axle and just rotates over the spines, coulld it be an R32, does anyone know if they have a smaller axle. it does have the drum hand brake as well??? Link to comment https://www.sau.com.au/forums/topic/97740-5stud-conversion-to-cefiro/#findComment-1801942 Share on other sites More sharing options...
Simon-S14 Posted January 29, 2006 Share Posted January 29, 2006 just to rehash this thread... Can i fit R32 skyline 5 stud rear hubs to the back of my ceffy, and redrill the stock rotor to accept 5 stud? I want to do the 5 stud rear cheap as possible. i dont need the bigger bralkes but i need rims, and 4 stud rims are hard to find Link to comment https://www.sau.com.au/forums/topic/97740-5stud-conversion-to-cefiro/#findComment-1907047 Share on other sites More sharing options...
Hella Flush Posted January 30, 2006 Share Posted January 30, 2006 yes you can Link to comment https://www.sau.com.au/forums/topic/97740-5stud-conversion-to-cefiro/#findComment-1909908 Share on other sites More sharing options...
