haha its actually kinda scarey when a moderator says that !!  :lol:
I would be more scared about what mr Plod will say when he sees them!! :D
coming together nicely campbell, when do we get to see it in action???
Oh and i find it pretty funny that u've still got the back seat in :lol:
BTW peoples, its an r33 gts't, he's got a topic in the QLD section regarding the build and mods
Harness belts are not designed to be used at greater than 90 degrees to the wearer. To much angle and the protection level goes down considerably. For example, they won't hold you in the seat during a roll over, you will just slide up the belt until your head hits the roof.
That's why the seat belt installation regulations for CAMS and ANDRA specify angles. I strongly suggest that you read and follow them
NOS in cabin, I don't think that's a good idea. I posted this a couple of years ago from the Boston Medical Journal...........
"the hypoxia resulting from high enough concentrations of nitrous oxide may result in irreversible brain damage."
"use of it can damage the bone marrow and nervous system"
"nitrous oxide rapidly leads to complete loss of motor control, and anyone who breathes it while standing will soon reel about and fall down"
"nausea, neuropathy and myeloneuropathy"
"hyperesthesia, hyperalgesia and hyperhomocysteinemia"
"serious mood and personality changes"
"nitrous does kill brain cells"
"severe bilateral sensory dystaxia"
And the best one of all
"This 36-year old electrical engineer came to the emergency room complaining that he was unable to walk. Symptoms had begun 4 days earlier with "pins and neeedles" in both feet that gradually worsened and ascended to involve the knees and the fingertips. With worsening of the paresthesias (-no sense of touch or pain-) he noted difficulty in maintaining proper control of the movements of his arms and hands and trouble in walking. He also reported the sensation of electric shocks through his back and legs upon flexion of the neck. He denied bladder or bowel impairment but he had been unable to have an erection for the past week."
You make up your own mind on whether it's bad idea to have NOS and hose connections in the cabin with you.
:) cheers :)
Edited by Sydneykid
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
    • So M12 and sealant should be fine?    NPT ” because that’s what I had and what I could get atm.
    • Wouldn’t touch par if they gave it to me. You need to ask how much power you’re looking to make and then add about 50% to it because that’s what you’ll end up making  The factory box says no more at about 350kw or so, the upgraded synchro boxes won’t handle much over 500kw for long and at that point you’re looking at an auto or dog engagement manual,  once you’ve gone dog engagement you may as well go sequential, they cost a little bit more but it’s worth it  also while you’re at it you should upgrade the transfer case with 10 friction plates
