Just wondering what sort of speeds a standard r32 GTR with the standard gearbox ratio's will let you get up to. Thats of course if you get rid of the fuel cut. I was thinking 260 or 270. Is that close to the mark when hitting redline in 5th??
I have the 320 dash and just wouldn't mind knowing. :lol:
Cheers fellas
https://www.sau.com.au/forums/topic/97971-what-speeds-can-you-get-to/
I've had my gtr to 270 on my speedo, probably not very accurate tho.. but it was no where near the redline in 5th. was still pulling but ran out of track.
top of 3rd is around 180, top of 4th is around 240 ... will have to get hte gps out next time i have passenger lap to see how true it is
according to reference.com the top speed is 257 km/h
there you go theres a official number
and im guessing reference.com is a trustworthy source....??
and from when i was doing a top speed run in my GTR from speed and revs i was doing i believe thats right on the money of the gearing (for a R32 dont know if others have different gearing)
RellikZephyr
   Cheers fellas
Gearing for an R32 GT-R is as follows (all in km/h per 1000rpm)
1st 8.9
2nd 14.8
3rd 21.9
4th 28.5
5th 40
There is an old Wheels magazine around with a test which produced a terminal velocity for a stock GT-R at around 250km/h (from memory).
But don't try it at home, kids.
Edited by djr81
  • 4 weeks later...
FTR: I have just watched an R32 GTR torrent file, I think its an old BMI Video from 1989, they have incar footage of standard R32 GTR around the Nurburgring, speedo was hitting 240kmh.
Then later tested over the QTR = 13.32
Then on a Banked High speed circuit = 247kmh
My Speed limiter cuts in at 181kmh as I found out at the drags :P which is basically top of 3rd in a GTR.
Can anyone remember which wire it is on the ECU you cut to disable the speed limiter?
Or point me in the direction of a thread that does......
r33 its gts-t its 280
280km/h in a GTS-T? :blink: For a stocker? :lol: I seriously doubt that! :P
(EDIT: Or do you mean it is geared for 280km/h? In that case it is more beleivable and you are forgiven with my apologies!)
On the serious side, I've heard around 250km/h mark is about right for the R32 GTR - the car may be geared for more (maybe 260-280km/h), but I don't think the stock car can pull redline in fifth.
Edited by Big Rizza
define STOCK R32 GTR
mines got 3" turbo back straight thru exhaust, apexi pods, boost restrictor removed
and it was still pullin strong at 6k in fifth
i would have no doubt i could hit the fifth gear redline
but mine may not be considered STOCK
RellikZephyr
1st          8.9
2nd          14.8
3rd          21.9
4th          28.5
5th          40
good stuff - seems to work out spot on with my R32 GTR which from the speedo roughly gives 120kph in 2nd, 180 in 3rd, shifting at 8000rpm. Looks like its actually 118.4 and 175.2. Close enough for me. I think I hit about 220kph going into the Caltex Chase at Bathurst on the run where I got a tow behind a sport sedan down the straight and didn't lift through the kink - but its hard to get more than a quick glance at the speedo in those circumstances! Plus its a 300kph speedo, so its hard to be too accurate with the lines being quite close together at the best of times, let alone at over 200 going into the Chase right up the arse of a sport sedan... :unsure:
I've also heard the top speed for a standard R32 is 250kph - I think I read that in a Julian Edgar Zoom article when he first got that Aus-delivered GTR he crashed :lol: Not sure what his source was. As you can see from djr81's specs above, 5th is a real overdrive, so it wouldn't surprise me that it isn't able to put on too much speed in 5th.
RellikZephyr
Sorry to hijack but u say u have removed the boost restrictor. what exactly is this and is it easy to do? can it be done on an R33 GTR
RellikZephyr
You dont have a hope in hell of getting anywhere near the redline with those mods . The 32 + 33 GTR is geared to so about 320 if you could get to the cutout but unless you have a very powerfull engine you wont go anywhere near .
A stock 32 will do about 240kmh a stock 33 a little more and a 34 a bit more still
If you could get to the cut out on the 34 you will be doing over 340kmh in 6th , but for a stock car about 255-260 is all you will do .
sorry mate i didnt remove restrictor myself so i cant help you with that, from what i understand its not that hard also i think R33 is electronically boost controlled so its a little different (but not sure i own a 32 so i know the 32, not 33 sorry)
cant really say i agree with that, but i will try another run when i get my car back (fixing idle problem), rather than me arguing yes and you arguing no i will prove (or disprove) what really happens
RellikZephyr
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
