well i was going to post something with a bit of a introduction since its been barely a month since I finally got my R32 GTS-T but unfortunately my post is going to be a bit of a sad one.
Was driving home tonight at 80km/h (the legal limit i might add) and heard a loud bang. Back of the car lurched and the car spun and the back right hand side hits a huge dip on the other side of the road backwards. (this whole incident happens in the blink of an eye)
Anyway getting out of the car its obvious that I had had a blow out. Unfortunately hitting the huge dip on the other side of the road has caused some damage and the wheel is bent at a pretty big angle now ;)
Hopefully nothing else like the HICAS is damaged
Great just got a new clutch put in and this has to happen....
Funny part of the story is that the car following me didn't even stop and help :P
bad luck deo :P...i guess you can be thankfull it wasnt any worse and you came out ok.
i'm guessing a rear wheel blew out? man i'm always paranoid of blowouts, for some reason i'm always driving with 1 hand and thats a big no no if something blows.
damn.
a blowout would be when your tyre bursts/pops, hippy.
I'm kinda scared of this happening to me atm, considering the state my tyres are in :P I need new ones badly ...
welcome deorbit
sorry it wasn't a more happy introduction ;)
Yup, I've had the same happen in my first car. Obviously a nail embedded in the tyre just decided it wanted to go at that moment. Not much you can do. I was lucky that there weren't too many cars on the road and a wide shoulder. At 70km/hr though its definitely scary when you just don't know what the fug has happened just that you can't steer anymore.
I ended up sliding off and knocking over a small tree. The damage wasn't too bad and i didn't really give a rats about the car too much, but I was pretty lucky. Could have been much worse if there was a big sized tree or I was in the right lane or something with other cars.
btw: You're looking at maybe a thousand or so to get what is damaged repaired (depending of course how bad it is), but at least it wasn't worse and you're on here to tell the story. HICAS isn't that important, if its damaged you can rig it up to do without.
Happened to me at 105km/h in the middle lane on the western ring road once... Rear tyre - not pleasant at all. Didn't loose control or anything, managed pulled over as soon as I could merge to the emergency stoppign lane - no damage to mechanicals, just the rear mudguard panel of the car damaged where a 36-inch long piece of tyre had delaminated, bent the panel then torn off and was left on the road.
Wouldn't want it to happen in again! :P
Haven't had a blowout for more than 25 years. Had two about 10 minutes apart whilst doing well over 90 miles an hour in a Triumph 2000 MD PI. No panic....no drama.. just a loud bang followed by a strong but easily controllable pull to the left. Only problem was by the time I had stopped from that speed the inertubes were totally destroyed just a collection of little rubber balls and shreds inside the tyre...........So much for modern suspensions!!!.... maybe it's the HICAS which causes problems
Round about that time my family and friends were in a Falcon station waggon that blew a front tyre at around 100kph.......it did 3 complete rolls ending up on it's roof....they were very lucky to survive. One reason I've always driven imports and never owned a Ford or Holden
Back to Skyline.... it drives and handles so well I just can't believe it turns into an uncontrollable heap of junk if a tyre goes flat.
or ....is the average Skyline driver incompetent???
come on guys......how about some informed comment
I am into triumphs and owned a PI which I rebuilt and warmed up. Which Triumph was it a 2500PI or did you put the fuel injection on a 2000?
Mick.
The origional PI was the Mk1 body with 2.5l lucas mechanical fuel injection.
Mine actually my first of 3 or 4 was a Triumph 2000 MD an Aussie Special Edition I believe. It had chromed wire spoke wheels and an MD badge :( I swapped in the 2500cc PI motor and Injection. Used to piss off a lot of hotty Holdens and Falcons and blew off my mates GTS Monaro (go the V8 power!!)
The Triumph 2000 and 2500 were and still are a very underated car
Yeh i was thinkin the same thing last time i blew a tyre it was pretty dam subtle and i took my time to pull over (eb falcon) the tyre was shredded, back left tyre, but i didnt do any of this crazy swerving stuff u guys are talking about. I think they design em so that its not suposed to happen cause tyres do blow quite often.
Were u yankin at the steering wheel like a cheerleaders bra or sumfin? was it wet? looks like uve been driving a few years so i wouldnt have expected u to pull a boxhead. Scary stuff if blowouts do that. U mess with ure camber/castor settings at all?
Wasn't doing anything too fancy. I had just finished going up a hill and was a bit of a turn up ahead. The car ended up pointing towards the other lane after the blowout which is where it all went bad.
Hey either keep the car straight and go into on coming traffic or try and correct before I end up becoming chop suey.
Only reason why I'm alive now is because the Skyline does handle so well!
btw The rear right lower control arm is bent. Apparently around $180 to get another one. Doesn't seem to bad. Hopefully nothing else is stuffed :D
I guess the experience varies... Mine was very uncontrollable and wasn't much i can do. The totally handling of the car instantly changed and it was difficult to control. It was hard to tell in mine whether it was the actual wheel blowing first, and when it went up the curb it bent the control arm, or in fact he control arm separated, which in turn caused everything to go pear shaped. All I remember afterwards was all these people seeing whether i was ok, and this huge hissing sound as the air was pissing out.
Was quite a few years ago now, but i still remember it quite well.
    • If it dies, then bypass. The task isn't difficult. I have one running on a standard R32 FPCM. That's after nearly 20 years of it running an 040, which pull substantially more current than the Walbro. They're not the same module, but I'd hope it indicates that the R33 one should be man enough for the job. I think people kill them when putting proper sized pumps on them, not these little toy pumps we're talking about here.
    • Silicone spray won't hurt anything. And if it does, that's an opportunity to put some solid steel spherical bushings in, so you can really learn what suspension noise sounds like, If you're going to try it, just spray one bush at a time, so you can work out which one is actually noisy. My best guess is that if the noise started only since putting the coilovers in, then it is just noise being transmitted up through the top mounts of the struts, and not necessarily "new" noise from bushes. But it's almost impossible to know.
    • Are you saying the 34 is SUV height, and not that we're talking about an SUV here? (because if we're talking about an SUV, you don't fix them. You just replace them when something breaks. Not worth establishing sufficient emotional connection with an SUV to warrant doing any work on one). I wouldn't jack my car up on a short little loop of 10mm steel rod poking out through a hole in the bumper bar, front or rear end. I realise that we're probably not talking about that type of loop at the front, being the one under/behind the bar on a Skyline.... but even for that one, trying to jack up on what amounts to a thin piece of steel, designed purely for withstanding a horizontal tension force, not a vertical compressive force (and so would be prone to buckling/crushing) and, my most particular bitch about it - located RIGHT AT THE EXTREME FRONT OF THE CAR, applying a load up through the radiator support panel, etc, with almost the entire mass of the car cantilevered between there and the rear wheels? Nope. Not doing that. Not on the regular. That structure out there in front of the front crossmember is not designed to carry load in the vertical direction. Not really designed to carry any load at all, really. The chassis rail that the tow point is connected to would be fine loaded in tension, as per towing. Not intended to carry the mass of the whole car, especially loaded all on one rail, with twisting and all sorts of shitty load distribution going on. No, I will happily drive up on some pieces of wood, thanks. That can only happen on driven wheels, and they are at the other end of the car, and this problem does not exist at that end of the car. And even then, I have been known to drive up on at least 1x piece of 2x8 each side at the rear, simply to reduce the amount of jack pumping necessary to get the car up high enough for the jack stands. What really really shits me about Skylines is the lack of decent places for chassis stands at either end of the car. You'd think they'd be designed into the crossmembers.
    • I've got MCA Blues on my V36 Skyline, and while I've managed to sort out issues with scrubbing/bottoming out by raising it a smidge and increasing the damping hardness, the rear end still sounds *super* noisy when driving on anything other than the flattest surface imaginable. It sounds like a small party of flamingos are just chatting away in the back, which makes me think there are several link points in the suspension contributing to the noise. Am I hearing dried out/worn bushings? None of it sounds like metal-on-metal, it sounds more like hard rubber squeaking on metal. It's been suggested that a bit of silicon spray on each bushing might quiet them down, but I'm not sure what material the current bushings are made of (probably factory, I imagine) and whether silicon spray will degrade that material.
    • The obvious answer here is get a ND2/3 RF with the Targa top. The red is nicer, too!
