  • Replies 100
I had a VL for years... never had any real problems with it except for the regular, cooling and such. Both are very reliable (hence still seeing so many of the fu*%ers on the road) and pull great cred. But I'd go for an R31, Silhouette version if possible, stonger auto and came with an LSD. Plus had electronic instrument panel in the dash for, KM's till empty, fuel usage and a few other features.
So yeah 31 dude, even if they are a little more expensive. Plus better re-sell value.
Cheers
https://www.sau.com.au/forums/topic/98189-r31-or-vl/page/3/#findComment-1787194
SHHHHHHHHHH MARK!
geez.. the more people that buy 31's, the less goodies are left for us!
baahahaha
Theres not contest really. R31s have everything better, the only good thing IMO (apart from the calais frount) about the VL is the Rb30, which is rooted by the cooling. R31s rarely have cooling problems, but the factory power steering is f**king dodgy as. when it works it works well, but its hard to find one without the pump or rack leaking. Mine do..
Either way, enjoy your lifter tap.
https://www.sau.com.au/forums/topic/98189-r31-or-vl/page/3/#findComment-1787382
I would take a mint calais over a TI R31 anyday of the week.
The R31 does have a better chasis, build etc.
But to be honest the local model R31's have never done anything for me.
Import 2 doors are horn though.
Still wouldn't ever sell my calais for R31 though, even though i like the import R31 models.
https://www.sau.com.au/forums/topic/98189-r31-or-vl/page/3/#findComment-1787434
The reason they crack heads and have problems is because gm mounted the radiator to low its lower then the hose ,if you look at r31 the radiator sits higher,just mount the vls radiator up higher and it saves the head ,every vl nut knows this.
Laterz
I would go VL calais anyday they are hectick!!!
8OOSTED you forgot to add in vx clubsport leather interior and there massive brakes !!
https://www.sau.com.au/forums/topic/98189-r31-or-vl/page/3/#findComment-1787832
In VIC, any VL thats cheap will be more than likely thrashed. R31s have more older owners and its easier to find a clean example. Oh and the police wont look twice.
For practicality the 31 got better gearing, air con standard, power steering standard, 4 wheel disk brakes standard, couple of KWs and boots that can double as a pond in winter lol.
https://www.sau.com.au/forums/topic/98189-r31-or-vl/page/3/#findComment-1787877
i worked in a cyclinder head recondition place for awhile and we got falcon heads 10 times a day and vl / commodore heads 5 times a day. but we never ever got a rb30 head off a skyline... never... and my boss said to me. they never get em. only VL's coz they fudged it up.
if you wanna fit into the bogan scene get a VL and do it up...
get the r31, do it up and it wont look so bad. look tuff etc. but prepare to be mocked by other skyline drivers that drive anything newer....
https://www.sau.com.au/forums/topic/98189-r31-or-vl/page/3/#findComment-1787887
bogan scene? get a VL and do it up?
id say alot of the ethnic dudes are the ones bombing VLTs, and they are far from bogan!
in mild stockish form a R31 is perhaps a better daily driven street car, but when highly modified id go the VL Calais all day long!
https://www.sau.com.au/forums/topic/98189-r31-or-vl/page/3/#findComment-1787905
to me, someone who doesnt own a syline as of yet and a VL, i would have to say the reputation surrounding the VL is too much for me to handle consdiering buying one.
sure, they have sleeker lines that the R31, but as previously mentioned, the cops will hastle you like no tomorrow because the representation vl's are given is that your going to do something very stupid, very soon.
R31 to average commoner is a granny spec car. im still looking around as to what skyline i would like to get, but the 31 has a quieter name in the law circle, and considering i dont want to get told off constantly, i would go the skyline hands down...
https://www.sau.com.au/forums/topic/98189-r31-or-vl/page/3/#findComment-1797779
Hmm tough choice.
VL Turbos can me made to really fly, but at the end of they day they're a Holden. Plus as mentioned by a few ppl, you will get hassled in a VL, they have a rep, whereas R31s, most people just think its some old car.
Buy either based on condition.
https://www.sau.com.au/forums/topic/98189-r31-or-vl/page/3/#findComment-1797816
    • Thank you, 100% the intent. New coils were due and the 17" sixers look/feel loads better than the stock wheels. The aero options are so spot on.   Thanks for the warm welcome, all!
    • 98 r34 gtt Been rocking my latest setup and car running like never before. Have put a good 200 miles on it since all the latest changes and additions. everything is dialed in and have been driving it a bunch.   However, all a sudden last weekend as soon as I pushed throttle passed 4k and the engine stumbles, (slow or fast acceleration) hesitates and doesn’t go above 4100 or so, like a misfire. Everything else seems fine. I had a “good” set of coil packs that I removed from car when I first got it when I changed them over to new coils. I swapped out current ones for those, but no change. I also changed the plugs, no change. Seems to rev over 4 when out of gear with no load just fine no “misfire”, but as soon as its in gear with a load of any kind, it “misfires” as soon as rpm drop back below 4 k it runs perfectly, smooth, starts, restarts and drives fine as long as I keep it below 4 k while in gear. All readings look fine, no CEL   Any idea as to what could all a sudden cause an issue when pushing rpms passed 4 k?
    • When you say your cams are 272/262 is that 272in and 262ex?
    • We're arguing semantics. I am saying 45 accel and a 55 deccel ramp are "2 ways". Even a 45 degree ramp and an 89 degree ramp is "2 ways", because it is literally... two ways. The cusco 55/30 ramp is a 2 way. It's two ways. I get it though - in normal nomenclature a "2 way" would be 45/45 or 55/55 or 60/60 i.e the same locking in both directions. And something like 45/65 would be considered "1.5 way". I would then say if we're getting into the nitty gritty then every locking diff is a "2 way" diff and we should not speak in 1.5, or 2 ways but ramp angles instead. Which ofc if one of those ramp angles is 90deg, that side is not doing any locking. :p So Nismo don't obviously sell 3 things. The fact of the matter that they only sell two items really goes to show that there's a 2 way and a "1,5 way" which is really a 1 way. I believe the actual lockup for the 'adjustability' of the GT pro is really just setting preload for when the ramps actually start locking up. It's not changing how much 'wayness' there is. It is (somehow) horribly explained. People just buy whatever diff and go "locks up good bruh" and that's what ends up on socials forever.
