  • 1 month later...
Updates, Money being spent :kiss:
s13 rear tein coilovers - $150 (looking for a cheap pair of fronts )
S13 sr20 front brakes + hubs and nuckles - $80
Saas seat $101.51 ( blue of all colours, sort of matches a red interior :kiss: )
Other News!
- turbo has done a oil seal, oil in intake.
-Rear panels still havn't been fixed :starwars:
- Got to go pick up a free l26 motor :O
That is about it, lol
Cheers!
What oil filter and fuel filter should i use? Aus spec r30 ones?
Cheers!
This is an interesting question, as my L20ET has a Ryco Z9 on it now, the L28 I recently acquired has an Z170, yet in past days L24E's had Z145A, so I guess you can use them all, as all L series 6 cylinder blocks are the same dimensionally.
Cheers,
D
Cheers!
Cheers,
D
Yup you can use. z9,z442,z101,z170,z145. All the same threads and seal size. The z442 is good for limited room area's Hence why it is used on rb25 neo's
I just used a r30 oil filter one i think. Also r30 fuel filter than doesn't fit in the dodgey fuel filter holder... nothing zip ties cant fix.
Also got some front coilovers coming, $275 :bunny:
I'm still happy with my coil overs, I bought them for $1700.00 for all 4 corners, complete with springs & seats. Fronts came with the DR bigger brakes & calipers, so I think I got a good deal at the time.
As for the fuel filter .... try an L28E one ............. p/n 16400-Q0800 as there are a lont of similarities with L28ET & L20ET configurations.
Cheers,
D
I made my own coilovers. I used Commodore strut tubes as the basis, and put Hills Hoist tube (threaded from top to bottom) over that. They now accept any Commodore insert - 40mm Bilsteins are shown. It is a bit of overkill for the street, but good for my purpose. I also modified the original platforms so that they fit on the adjusters as well, giving me a broad range of spring choices.
Strut with King spring:
Modified factory spring platform:
Cheers,
Matt
Edited by Matty T
are you able to take some pics off all the welding spots and everything you have done ? This looks like alot easyer setep to do than trying to fork out the money on s13 gear
Easier? It really depends on your point of view (and level of skill, patience, access to machinery, etc...). To some, it is easier to just spend the money on S13 gear and fit it in a weekend. To others, they enjoy making stuff themselves and don't mind the fact that it takes them a couple of weeks (and a couple of skinned knuckles).
Anyway...
I started with a pair of DR30 struts. I went to a wrecker and bought a pair of VB - VP front struts from a wreck ($50). They happened to have a pair of good Koni red adjustables in them (heheh - worth the price alone!).
Next, I cut the Datsun strut tube off 25mm above the stub base. I cut the Commodore tube off right at the stub base (so that the Commodore tube was as long as I could get it), and removed the brake line mount so that the tube was bare. Other people actually split the Commodore stub base open and remove the whole tube, then machine out the Datsun stub base to suit the tube. That produces a neater result, but incurs an additional cost. People like Errol at Datrats (www.datrats.com.au) do it for about $400, IIRC.
I then cut the top of the Commodore tube off (the part that has the inside thread for the gland nut). You can choose your own length here, but it was about 8 cm IIRC.
Now off to the lathe!
The inside diameter of the bottom 25mm of the Commodore tube needs to be machined out by about 1mm so that it slips neatly over the 25mm of Datsun tube you have sticking out of the stub base (got that?). Stick it on and weld it around the base. (Oh, while you are there you can give the tube a slight lean one way or the other to adjust the static camber if you want).
While the lathe is warm, go to your neighbor's yard armed with a hacksaw and cut down their Hill's Hoist (or you can go to your metal centre and get some tube with a 55mm(or whatever the Commodore tube OD is) ID). Anyway, thread the tube from tip to toe.
Now, here's the measuring part: slide the Commodore insert into the newly welded-on tube. You will notice that it sticks out the top some distance. Screw the gland nut (you know, the big nut that holds the insert into the strut) about halfway into the piece that you cut off the top. Now put it on the top of the insert. There will be a gap of about 15mm between the tube pieces. Technically, this is the only part you need to sleeve with the Hill's Hoist tube, but since we are making coilovers, we may as well make them adjustable as much as we want. Mark and measure where you want the sleeve to start and finish. Cut the threaded tube to that length. Slide over and weld.
* The second picture in my post above shows you the weld between the top (gland nut) piece and the top of the Hill's Hoist tube.
* Here is the bottom:
Ah, one thing I should mention - get your adjustable platforms first, so that you can cut the thread in the tube to the same pitch. Places like Heasmans (or Quadrant) sell them on their own.
Some people may be concerned about their strength - they are plenty strong. The tube wall thickness ends up at about 6mm (compared to about 2.5mm for the original one). A bit weighty? Perhaps. Strong? You betcha.
In total, it cost me about $300 to do the lot (including modify the original platforms), which is pretty cost effective. Once you add new 40mm heavy duty Bilsteins ($500) and a set of new King springs ($175), the cost gets nearer that of the S13 gear. The advantage is, though, parts are easily replaced compared to alot of the aftermarket S13 stuff.
Now, does all that sound easy or what? :(
Edited by Matty T
Matty,
That's pretty good, but that's all for fronts only eh!
$300 + $500 + $175 = $975.00 for fronts only, what are you doing on the rear, using stock shocks & spring configuration, or are you modifying the shock tower to become a coil over too!
My JIC's were about 50mm shorter in fitted length than the stock DR30 of the same spec. For the dollars I paid, I think I did very well, they have no leaks, they came complete with brakes, adjustable camber strut tops and the dampening is 4 way adjustable.
I have since found out they cam out of a Bluebird not a DR30 as originally thought, but they fit great, the ride height will be very similar to the black sedan shown earlier in this thread. Maybe for comp days a bit lower.
What I can't understand is this ........ you have done what amounts to quite an exotic modification to your front suspension, yet in another thread, your so concerned about cutting holes in a panel which may breech homoligation regs. Where do these exotic dunnydore/nissan front struts fit into homoligation regs that a hole in the radiator support panel, will not.
Cheers,
D
I hear ya Ghostrider. I am only trying to comply to the Badly Worded Book (a.k.a. the CAMS Manual) for Production Rally Cars. Basically, suspension is free, as long as you aren't altering the suspension mounting points on the chassis (certain reinforcing is permitted though). Unfortunately, the radiator support panel is not free. The only modifications that are able to be done is those that necessitate the fitment of homologated items; nothing more. That is why I am concerned about where Mr. Fury's intercooler piping went, but have gone nuts on the struts.
To be honest, if I was doing it again, I would probably make them (like I have done) but base it on the S13 hub.
As for the rears - at this stage, it is nothing more than a new set of Bilsteins and a set of Kings. They aren't adjustable (yet), as the original circlip groove has provided quite adequate ground clearance. But I do have a cunning plan... :(
  • 4 weeks later...
  • 4 months later...
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
    • Thank you so much for the help
    • Yes it is ATF. I quote @Duncan "it takes a good synthentic auto trans fluid like Castrol Transmax Z" It's not a diff. It's a transfer case. Totally different thing. Yes, fluid will come out the sender hole. No you do not really need to drain it. Just pull the old, quickly poke the new, clean up and top up. But realistically, you should probably take the opportunity to change it anyway.
