I may have fouled the  plugs now with all the cranking.
maybe cas has been broken somehow.
you can remove it and turn it by hand....you should hear the injectors squirting fuel. And yes you may have fouled the plugs with all that cranking
Edited by DiRTgarage
  • Replies 43
I'm not quite ready to fire bomb it. not sure where the coild packs earth but will check it out tonight.
the final (rear) bolt (12mm) that secures the alloy coil pack frames should have an earth eyelet under it.
Did putting spark plugs in it make any difference? :rofl:
Sorry Adam, we always leave them out so it can be cranked easily to bring up oil pressure. I just bolted the coils back in so they wouldn't get damaged in freight (maybe that was a lucky thing).
I'll fix you up for the plugs, we always throw them out when we do an engine, we've had too many problems with people reusing the old plugs and having a miss or hard starting problem.
It runs!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!11111111111111111111111111111111
You'd never guess but the engine builder didn't put my spark plugs back in and I just assumed he had. I did notice that it was cranking fairly easily.
Put some new plugs in last night, a little bit of stuffing around and away she went.
I don't have a video recorder but I was laughing hysterically when I pulled out the first coil pack expecting to find a fouled plug but instead found no plug.
hahaha. Just a little difference!
Oil pressure was good obviously.
I probably would have thrown the plugs out myself except for the fact that they were iridiums with about 2000k's on them.
lol no sparks! :)
Sweet Adam....christmas run-in's are great....i took "twoogle" up to the Gold Coast for Xmas/New Year two years ago for its run-in.....its engine is two years older than yours almost to the day.
:):):D That one of the funniest thing i have read in ages, how we over look the simple things sometimes. Well all the best with the run in as i'm doing the same, up to 370kms now and everything looks sweet.
pete B)
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
