hey guys i have done quite a bit of research... especially reading past threads..
i thought i would quickly check with yall first...
i have a 33 with ems cooler exhaust new turbo manifold etc..
and want to upgrade my turbo... i have decided on a Garrett gt3071 with .63 exhaust and with an internal wastegate....
does this all sound like a good setup ?
Cheers thanks for any feedback
https://www.sau.com.au/forums/topic/100253-garrett-gt3071/
A GT3071R , (real one has 84T 60mm GT30 turbine + 56T 71mm GT35 Comp = CHRA No 700177-23) would not be the most responsive thing on an RB20 . Works better on 2L four ie 4 ~ 500 cc pots .
The HKS GT2835 Pro S in .68 a/r turbine housing would be a little better with its smaller 52 trim compressor but the kit is not cheap .
All in all I reckon a std (ceramic BB) turbo Hi flowed like GCG's or a model specific HKS GT2530 sounds good for the road . You can go bigger but its getting not nice for a street car at typical street car revs .
Cheers A .
https://www.sau.com.au/forums/topic/100253-garrett-gt3071/#findComment-1827705
Hay guys I have a GT3071R with a 0.63 turbine hsg on it. I have not installed it yet due to Christmas and New Year but will be hopefully on in about 2-3 months so if you can wait till them I will pm you with how it goes.
I have pm'ed discopotato03 about this turbo set up before and he mentioned that is was very similar to the GT2835. Please correct me if I am wrong?
A few people I have talked to that had them on there RB20s made 240rwkw and had full boost by 4000rpm so on a RB25 it will hopefully be around 3500rpm with a good tune.
Cheers,
Boz
Cheers  A .
https://www.sau.com.au/forums/topic/100253-garrett-gt3071/#findComment-1827906
Similar to a 2835 in that it has the same series of turbine and compressor wheels .
ALL of the GT2835 HKS's and GT3071R's are GT30 turbine based turbos , ALL of them use 71mm GT35 (BCI-18 series) compressors . The turbine is cropped in all of them except the propper GT3071R cartridge 700177-0023 .
Most of the HKS GT2835 series use the 52 Trim compressor though I have a table of HKS turbos that shows a 48 Trim compressor version rated at 380ps . 52T rated at 400ps , the 56T 410ps and the 56T Pro S at 420ps .
Garrett has a bad habit of only offering the largest trim compressor version in the turbos they market .
CHRA's
700177-0002 Cropped Turbine 84T + 52T comp
700177-0003 Cropped Turbine 84T + 56T comp
700177-0004 Cropped Turbine 90T + 56T comp
700177-0023 Uncut !!! Turbine 84T + 56T comp
I suspect the 48 trim compressor version is 700177-0001 but unconfirmed .
The middle two of the list above are what Garrett is fobbing off as "GT3071R WG or wastegated " . You are getting ripped off big time if you buy them or any of the HKS GT2835 series with the T28 flanged GT28 integral gate exhaust housings as the combination of GT28 housing and GT30 based turbine is a flop .
Also to save confusion , you will notice the first three have a cropped version of the GT30 UHP (Ultra High Pressure Ratio) turbine . Its major diameter is 56.6mm where the uncut version is 59.9mm . So the 84 and 90 trim versions of the first three are based on a smaller diameter than the last which is an 84 trim 59.9mm .
HKS/Garrett turbo unit numbers for the above cartridges or CHRA's
700177-0002 = 700382-0002 , 700382-0006 , 700382-0018
700177-0003 = 700382-0003 , 700382-0007 , 700382-0019 , 700382-0024
700177-0004 = 700382-0004 , 700382-0020 , 700382-0021
Turbo unit numbers vary because of differences in turbine and compressor housing style and a/r .
The last one (-23) is only sold by Garrett as a cartridge that you can select a number of housing options for . ATP Turbo (US) sell them as a unit with .63/.82/1.06 a/r GT30 turbine housings + .50 a/r TO4E compressor covers .
Cheers A .
https://www.sau.com.au/forums/topic/100253-garrett-gt3071/#findComment-1828724
from a poster here (Fantasy Performance).....
"The exhaust housing's I am offering have a T03 foot print and are cast by Precision Turbo's in the US. They use a Ford style T03 internal wastegate set up but are a proper GT housings"
i believe the housing was coming from a Qld Turbo supplier.
perhaps there is an option internally gated with the 60mm turbine.
ps. don't panic if you don't understand the above info. i have been getting my head around this info over a period of time, with a lot of patient help from disco. there are lots of threads that relate to the 'real' GT3071R' if you do a search you will find them pretty easily.
Edited by wolverine
https://www.sau.com.au/forums/topic/100253-garrett-gt3071/#findComment-1829493
I'm grabbing Corky Bell's Maximum Boost book and going to have a good solid read.
Its too hard to learn what you need to learn via google. :P
Just when you think you understand whats going on you realise your back at step one. ;)
I totally agree...
Step 1 is the hardest part...
I have to say tho choosing a turbo is alot like making a sandwich. I mean first there is the filling (size of compessor and turbine) then you got the sauce (housing sizes) salt & pepper (flange type) then the type of bread (brand of turbo)....
I get so confused some times that i reckon ill stick to sandwich's cause they make me happy too. ;)
But seriouslly i have been tossing up inbetween keeping the high flow i already got or a GT30 style Garret unit (probablly a .82 rear housing and a .7 front housing with an external wastegate setup) But yeah changing all the exhaust manifolds makes me also check out the GT turbines from HKS as their bolt on....
I guess for the cost tho you could get a full garrett setup for the same price as a HKS turbo....
https://www.sau.com.au/forums/topic/100253-garrett-gt3071/#findComment-1829599
i have an rb20 and put a gt-rs turbo on (400ps) internal wastegate.
full boost at 3500rpm with standard computer, mainifolds and blowoff valve.
great up grade but costly
around $3,500
what sort of hp you after.
mainly for street or drag racing.
hope this helps
https://www.sau.com.au/forums/topic/100253-garrett-gt3071/#findComment-1831415
hey cubes, another bastard thread like mine hey? hehe
mate, you might want to have a loo kat my thread, towards the end, there is all of this talk about me and my turbo (GT30)..
worth reading. Hope it doesn't scare you too much lol.
http://www.skylinesaustralia.com/forums/in...showtopic=89613
https://www.sau.com.au/forums/topic/100253-garrett-gt3071/#findComment-1832322
thats exactly right - GCG highflow is the most cheapest upgrade ($2k) and it bolts straight back on, no adjustment to oil or water lines.
2530, you'll be spending $300 on oil and water lines, and lots of time and stuffing around... I've been there and done that, pain in the ass.
If I could do it again, I'd get a high flow. But, I can't do it again..
https://www.sau.com.au/forums/topic/100253-garrett-gt3071/#findComment-1835362
    • Stock ECU (or more accurately stock tune) absolutely refuses to go over 10psi and behaves like you have seen. The Nistune is the same if it is the stock tune. If the Nistune chip has been tuned, the resulting tune could be literally anything for any combination of parts. The Nistune just makes the stock ECU Tunable.
    • So stock ECU does not like anything above 10 psi?  That Nistune one is just for "try" if it will be any different, I know it need to be tune for that. I know but YOU may know about these problem but i/we dont. They few little Skylines here let alone people who know anything about tham so that is why iam asking here
    • So now we have a radiator with no attachments whatsoever. It lifts up with a particularly tight spot between the drivers side air box mount and the lower radiator outlet, but if you've got this far you will sort that too. This is the lower mounts with the rad out so you can see where the rubber bushes go, it is a straight shot upwards Done! Assembly is the reverse of disassembly, with blood less likely to be shed.
    • Right, onto the second last trick. The Air Con condenser is mounted to the front of the radiator and stays in the car when the radiator is removed. There are 2x 10mm headed self tappers holding the top of the condenser to the radiator, remove those The bottom of the condenser is attached to the radiator with clips. You need to lift the condenser out of those clips and clear (up, then forward). f**ked if  could work out how to do that last bit with the front bumper on. I hope you can, and you share the trick.  Bumper removal probably deserves its own thread one day once I've recovered the will to live, but basically you need to remove the wheels, front inner guard liners (clips and 10mm headed bolts), the self tapper between the guard and the bumper at the rearmost point of the bumper (same as an R32 that bit), any remaining clips at the top/front of the grill, an absolute bastard design with a plate that holds the top of the bumper above the headlight each side (only 1 bolt which is tricky to get to, but the plate catches 2 places on the bumper and must be removed....carefully!) and push clips between the bumper and guard under the headlight. If you've done all that you will be faced with wiring for the fog lights on both sides and in ADM Q50 RS at least, 4 nasty tight plugs on the driver's side for the ADAS stuff. So, the clips at the bottom look like this on drivers side (looking from the front) And on the passenger side (also from the front), you can see this one is already out Clearance on both of these are super tight; the condenser needs to move up but the upper rad support mount prevents that, and the radiator can't move down far because it is (rubber) mounted. Once you achieve the impossible and drop the condenser off those mounts so it does not stop the rad moving, you are good to go
    • OK, next the shroud needs to come off and there are a couple of tricks. Firstly, there is a loom from near the passenger side headlight to the fans, coolant temp sensor etc and there is no plug to undo.  In my case I was OK to leave the shroud on top of the engine so I just undid the passenger side fan plug and about 10 of the clips which gave enough free wire to put it aside. The fan plugs were super tight, the trick I used was a small falt screwdriver to push down on the release tab, then a larger flat screwdriver to lever the plug out of the fan unit....be careful with how much force you apply! If you need to remove the shroud altogether for some reason you will have to deal with all the plugs (tight) and clips (brittle)....good luck. I removed all of the clips and replaced them with cable ties that I will just cut next time. Also, in the Red Sport / 400R at least, the intake heat exchanger reservoir hose is bolted to the shroud in 2 places with 10mm headed bolts; so remove them (the hose stays in the car; no need to undo it at the t fittings down at the radiator lower mount. Once you've dealt with the HX hose and the wiring loom, there are 3x 10mm headed self tappers holding the top of the shroud to the radiator; remove those.   The shroud then lifts out of the bottom mounts where it sits on the radiator, up and onto the engine out of the way. Simples
