well since ive melted a hole in my rb20's no. 5 piston its obvious i need to rebuild it.
ive got a nice set of cp pistons to rebuild the motor with but im wondering what else i should do to the bottom end while i have it apart.
i plan on using arp head studs and an oringed block with stock hg to keep it from blowing out under high boost but what other things should i do while the engine is apart.
i was gonna have the rods resized as well as shotpeened, but got to thinking do i need to change out the rod bolts and the main studs?
the motor should be capable of nearly 500whp, and i want it to last a while so what are your guy's thoughts on making it do so.
i was also gonna toss on an n1 oil pump to help the oiling system as well as a proper oil cooler.
ideas?
https://www.sau.com.au/forums/topic/100320-uprating-rb-bottom-ends/
If you are going to stick with factory rev limiter, shotpeened rods are adiquate, but if you plan to rev the engine harder thin get a new set of rods. Replacing rods bolts is a must, get ARP rod bolts.
N1 oil pump and oil cooler is also highly recommended.
It goes without saying that you are getting the block x-rayed and crack tested, internals checked, ballanced and blue-printed.
yeah, block is going to be inspected and cleaned along with the crank and what not, going to have the crank's oil gallerys grubscrewed for proper cleaning......
as for revlimiter im proly going to keep it near the stock 7.8k rpm, perhaps raise it just to add a bit of head room but nothing more past 8.5 for sure.
the head will be cleaned and checked as well as well as uprated valve springs to cope with sustained high rpm operation.
what arp bolts can i use on the rods will z32 vg30 bolts work?
How about sussing out why you burnt a hole in the piston, or you may end up doing it again with a fresh motor...?
Id hate to think what the power band will be like on the 2Lt with just more up top....
Why not go for a 2.4Lt bottom end (rb26 crank and rods, and them toyota factory forged pistons) ?
Edited by Bl4cK32
More cubes via RB26 rods and crank is the only way you are going to make it possibly reliable.. It will need too many rev's and boost to make ~600hp at the fly with only 2ltrs and 7.8rpm.
Do the airflow calcs you will see what I mean.
500whp is 373rwkw... Good luck reaching and maintaining it if you stick with the 2ltr. ;)
Edited by Cubes
Carl wants 500rwhp... Thats around 600hp at the fly.
For any motor its going to need rods and pistons.
The larger motor will always last longer than the smaller and be more reliable as it won't need to spin as hard to make the same power.
hrmmm, you are right on a few fronts but i didnt say it was going to MAKE 500whp, i just wanted to beable to make one dyno pull and get a number like that......
the reason the piston went was due to a dodgy romtuned ecu, however decided that for high power needed to step it up so i invested in a pfc.
i do believe its possible to make 450whp as it was making nearly 400whp (387 to be exact) untuned and at moderate boost (17psi) made peak power at about 6.5k rpm iirc.
but back to the original question what arp bolts can i use on the bottom end?
RB30 bottem end is all thats needed.
- Luke
Maybe...but an RB30 is a bigger engine that sits higher in the engine bay...not major problems but problems all the same. Some may have problems with engine numbers/registration etc.
Plus, i love revs, and screaming out of 2nd gear corners with the thing just screaming its head off up to 8,200-8,400rpm. A std RB30 bottom end wont do that. Some will say wont need to, and thats fine, but i like how it does.
RB24 again would be good...but im more inclined to spend the money saved with using std RB20 crank and rods on headwork, valve springs, perhaps bigger valves and cams etc. Things that will actually help the engine make power.
Whilst i am always impressed with how Rb25s with bigger engine RB cars always get up and boogie so quickly, im a lazy street driver and i now like how my car isnt spooling up everywhere with lots of induction noise etc.
If my RB20 let go, id be curious to do fresh bearings, oil/water pumps etc. Crack test, balance...the usual. Then just throw in a set of 81/82mm pistons with 8.6-8.8:1 compression...and then spend the rest of my budget on headwork, cams etc.
And im still trying to get my head around how everyone says the torque makes the car easier to drive, when all i ever see is the engine with better low rpm/torque just frying tyres. With a little less response, and higher rpm power band it seems the tyres/suspension handle the power better at higher road speeds?!?!?!?!
With something like a HKS 3037 or some other nice 550-600hp turbo, i think i would quite enjoy the power band from 4,750rpm to 8,500rpm. I would hope it makes 320-330rwkws on about 1.4-1.5bar.
N1 oil pump ......... is also highly recommended.
I read this a lot, and personaly I think it's a big mistake to use a wide drive flange oil pump on a narrow drive flange crank. This is made even worse by the higher oil pressure relief spring the N1 pump has, because it means more torque loading on the narrow drive flanges. With the crank driving on less than half of flange on the oil pump, the tendancy to crack the rotor is exacerbated.
I see no reason to run an N1 oil pump anyway, they flow no more than a standard RB26 oil pump. All they do is relieve at a higher pressure.
;) cheers :D
;) cheers :D
fair enough SK, but i had planned on fitting a oil pump drive collar to the crank while it was out, it couldnt hurt any........
another reason for the n1 pump is for the slightly higher pressure, since the poor rb20 got stuffed with no oil cooler an external one is to be fitted to this new motor for longevity's sake.
roy - my gt30r is the same as a hks 3037, and belive me when she gets going it is an insane blast to drive, im anxious to see what she will do once i rebuild it with proper compression......
boostn32 - the l20 rod bolts were a proper fit? hrmmm i may have to look deeper into this.
Edited by carl h
Increasing cubes does increase power. I know going from the 3.0Lt std bore to the ~3.1Lt i have in my car roughly equals about 10 more Hp across the rev range....or so a reliable source tells me :P
I would have stuck with modding my rb20 had it not blown, and i know what you mean about revs there Roy. Having ridden a RZ250r for the last 6 years i love revs, and that thing is built for it (redlines at 12,000rpm :D)
But i like not having to downchange (as you noticed when i drove your car) when goin up a slight gradient. I like the fact i can leave it in 5th and cruise up a hill.....tyre frying just means you havent sorted suspension or tyres properly :)
You are a lazy man. I estimate 42 gearchanges in my car per 1000mtrs whereby burning approx 72 calories. That is extra sauce on my meat pie, and an extra beer with dinner base don the average number of kms travelled in a day.
As for 3.0L vs 2.0L no doubt, but as for 2,4L with the same head? Your 3.0l is also using a different head.
I have no idea what the answer is, but would be interesting to take your RB30 build budget, and spend all that money on headwork and cams. It will be interesting the performance difference of the two engines usign the same high flow turbo , even allowing for the differend head etc?????
...and for what its worth, the car doesnt have that nasty tune anymore, or the 10cm housing. When the 8cm housing went on with the new tune it transformed the car...LOL, that means it still sucks and is laggy, but at least i dont have to use 1st gear and a carrot on a stick and string to get the thing up a hill in 1st gear :D
    • Yeah the rule of thumb with an LS is 7psi per 1000rpm. That is decidedly not enough at 6800rpm. I mainly looked for the scenarios where knock started to be picked up and it was later in the session when things were hotter, and oil was thinner, and the pressure was lower than it should be. (i.e very horrible). I am hoping with thicker oil (I was running Penrite ten tenths 10-40, the manual specifies 10-30) that does not leak that it's much improved at that time!!! I am using Project Mu Club Racer CR pads. I'm also using the Project Mu 335C fluid. The symptoms imply that it was fluid that boiled, but no bubbles seemed pretty weird to me when I bled it today. I want to try Castrol SRF as it has a much higher wet temp but, well, I have new Project Mu fluid lol... so I should at least use that. The pedal on track was really noticable. It went from basically normal feeling to instantly near-floor. The car did pull up as before, it was just very much nearly at the floor before the brakes engaged. At that point I pretty much decided the day was very done, it did *kinda* come back during that very slow cooldown lap into the pits. Felt perfectly fine driving home.
    • f**king around with the bro
    • Ludenham   44.2 tops day no issues
    • Then today, I went to visit a man with an r33 hat Peter and Road and Race sorted the alignment. As it is being set up for general track/hillclimbs etc it has a heap of caster (7o), less camber than I am used to (1o front and 2o rear, as the caster looks after that in turns without the braking downsides), 3mm front toe out and 0 toe rear. Will see how that goes and track tyre wear to see if it does need more camber, but adjsustment is also limited with nismo arms and adjustable bushes at only 1 end. It does have a bent inner tie rod on the driver's side front but as it came up within spec I'll just leave that as is. So, that is getting close to my chapter of this story....could of tidy ups then a shakedown in early October before it finds a new home.
    • So, it went to Unigroup for a run in and tune on Friday, everything went (generally) well. In terms of fixes, the engine was good and there were no leaks. It needed plugs (I hadn't checked them because the coil pack cover was on a new engine and I couldn't imagine they weren't new.....but turns out the temporary plugs to just keep it sealed up were in there.....new plugs gapped to 0.8 and it was fine from there. Also, there was a little preload on the clutch slave which caused some slip. I haven't had the box off so I don't know what the clutch looks like; my guess it is brand new and the pedal had not been adjusted....backed that off a bit and it held fine. Last thing will have Dose crying....the idle especially when cold is a bit difficult between the cams, forward plenum, atmo blow off valve and an 80s air management system. It is fine when hot but a little uneven when cold, will see if I can sort or at least improve that one cold morning. Other than that, tuning went fine. It made 245 but was pulled back to 227 which 2 opportunities to improve in future. 1. The factory CAS is not great and was jumping around at high RPM, so Mark took 2 degrees out up top (that is why it stops making power and lost 20kw). Very safe this way and the extra power is available but will require a more modern ECU and better cam (or even better crank) sensor 2. The 2871 in factory housings is very big for a low mount, and the internal wastegate is too small, so it was creeping from mid range all the way to redline....the duty cycle on the boost controller is turned down a little for safety. That is much harder to fix, it would need a large external gate and that would require a whole bunch of other changes, so it will go as it is for now. It feels nice and healthy and safe, so should be good for about a billion laps like this.
