No you should just watch it over time tho the cheap ones dont always last too long, A mate of mine brought a cheap Boost Gauge and his lasted a month. Then it started to creep off, My HKS Boost Gauge on the other hand is still going strong and it came with the car.
So I guess you get what you pay for.
Edited by 7yphon
Greddy makes a nice electronic boost gauge. I currently have one in my car, it reads boost accuratly and responds quickly. Where as my buddy had an autometer gauge that would read 5psi when the car was off :blink:
I have found the Apexi Boost gauge to be great.
But i was considering getting 3 cheap gauges, for temp and pressure, for $220 or the DEFI DIN-gauge set for $600.
I know Defi are accurate and will last for years. But i am thinking; even if the cheap ones are inacurate, you only need to know where they usually sit and be worried if this changes. But now i read that these cheap gauges do alter their readings with time :O.
Is this the case for both mechanical and electric gauges? As i am only getting the electrical type.
I know Defi are accurate and will last for years. But i am thinking; even if the cheap ones are inacurate, you only need to know where they usually sit and be worried if this changes.  But now i read that these cheap gauges do alter their readings with time :).
And the Apexi ones look the best too! :O
yea apexi rocks but cant find one under $275 ...
Nengun: Click Here
OR
RMS Motor Parts Pty. Ltd.
Unit 3 / 662 Whitehorse Road,
Mitcham,
Victoria, 3132,
Australia
Phone: (03) 9872 6669
Fax: (03) 9872 6697
Emails:
General Info : [email protected]
Sales : [email protected]
Trading Hour:
Mon-Fri 10AM-6PM
Sat 11AM-5PM
I would also recommend VDO. If you're not after a fancy dial face and only after functionality, VDO is the way to go. Autospeed did a review and found that the VDO boost gauge was good (Avg error of 2.5%).
To quote Autospeed :
"Indeed, VDO offer good value for money while perhaps lacking the frills and panache of some. Accuracy is up there, and thanks to the German company establishing a manufacturing facility here in Australia, warranty isn't a problem. VDO gauges are available from most outlets and the range of hardware is extensive."
Funnily enough, there is one for sale on Ebay right now :Ebay VDO Gauge
Why spend $240 on an Apexi gauge when a $80 VDO gauge will do the same without having to worry about the accuracy/reliablity of something like Speco. I'm like having Functional stuff in my car, not into bling so I bought a VDO.
    • Yeah, plenty of air flow, there is a dedicated path that feeds the air in to the OEM intake tube behind the bumper As for a "tangible effect", maybe, but getting the pod/intake air out of the hot engine bay is worth it psychologically to me, even if it gives no performance difference, so the tangible effect in my Lizard brain saysss yessss  In the end, to me a tangible effect isn't always about performance, sometimes it a sound or a look, or even a...... feeling  Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga
    • yeah first and reverse is where you will find clutch release issues (whether hydraulic or mechanical) because the difference in revs required is the highest there; particularly changing down from 2nd to 1st when still moving. To be clearer though, it is possible that the clutch release bearing is the wrong height. This is less likely than a hydraulic issue but it is not unheard of when you are mixing and matching
    • Quite right, if you make it to that pension you deserve every cent
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
