  • Replies 123
hey,
Im abit new to all this as well. What would u reccomend, tube and fin or bar and plate?? Im not 100% sure on the differences between the 2. Also would it require any cutting of the front bar or anything? Or would it be a straight fit? Would be for an R32 gtst with a 'type M' front bar. Im very intersted in a kit.
Cheers,
Andrew
haha if only you answered those questions here! :thumbsup: sorry i have to ask you also which is better out of the 2, what are the differences, and will either of them be a straight fit on my line? (picture of it in my sig) also are you located in sydney? thanks mate sorry for repeating the question
Hey GR3DDY,
I'm keen on the whole intercooler kit (cooler and piping) for my r33 series 2!!
What is the best price you can do delivered to Gold Coast,QLD and are there any modifications that need to be done to the front bar (standard)?
Cheers mate,
Daniel.
Yo
got a HKS type S FMIC but f*kt it up by running into some1's tow bar .
Need a new core, like ur prices and was wondering wot size the pipes were dat fit on da HDI cores. Also wots the difference between the tube and fin and the bar and plate
cheeRs
I put the money in your account this morning tried to send you a pm but it said you inbox was full ...
PM me so i can give you the postage details =)
Ohhh yeah my car is a SI gts-t :)
Edited by MsG_ChRiS
I am also interested in the hybrid cooler kits. Please pm any info i may need on ways of payment and delivery options (time, date, etc.)
is there a difference between the two 600x300x76.
It is 4 an R33 sii.
Thanks
Edited by DNR33
have you got pics of the kit installed.
i just want an idea of what the r32 gtst piping kit looks like and where the pipes run ?
how much for just a r32 gtst piping kit ?
cheers- Ricko.
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
    • When you pulled it off, there is no signs of blown head gasket? Is it possible you have some other issues going on? Possible cracked blocked? Or do you think it's straight up lifting the head? Did you check what the head was torqued to before pulling it down (To see if possibly they're stretching, or starting to break threads out etc)?
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
