  • Replies 123
have you got pics of the kit installed.
i just want an idea of what the r32 gtst piping kit looks like and where the pipes run ?
how much for just a r32 gtst piping kit ?
cheers- Ricko.
Same question, need piping only.
Hey man,
the PM's your sending dont seem to be coming through :(
Could you please copy paste what u wrote and email it to me at : [email protected]
Would appreciate heaps!!
Cheers,
Dan.
hey mate, i would like to know this before i buy... is there any cutting required of the standard type m front bar on an r32 gtst and do i have to chop any of the fan blades or cut a hole in my chasis like the just jap cooler kits??? cheers mate
you will need to chop the f**k out of the stock type-m r32 bar (i had to, and it needs tidying up atm). basically i found i had to cut a heap out of the centre hole including the vertical support bit, and completely cut out both the side holes in the bar.
i didnt have to chop the fan blades on mine. i just made sure the exhaust piping was pushed up against the cam cover and away from the radiator blades. you will need to cut a hole through the side part of the engine bay just below the battery compartment though.
the gts kit is very generic though, as it is made for r32/r33/r34. i found the support on one of the pipes was useless for my rb20det (the one that is sposed to bolt onto the engine block).
pm for pics if you want
Edited by flagger
3/ Hybrid RS spec kit (core - tube and fin - 580x295x95) - $730 delivered.
Got this in stock for JZA80 Supra?
Send me a PM or email. Ill gladly buy one of you. Thanks
PM sent.
:laugh:
couple of questions -
ok yep bar and plate or tube and fin?
fitment to a 97 stagea id IMAGINE is the same, being the same engine bay, same R33DET engine. anyone else know?
haha will await your PM.
1/ HDI GT spec kit (core - tube and fin - 600x300x76) - $630 delivered.
Will this fit an R33 S1?
Cheers
Jamie
Yep, will fit.
PM me ur email addy if you want a copy of the install guide.
I would like the 'bar and plate' monster kit to suit r32 gtst. Can you supply me pics of the actual kit please!
I also need payment and delivery details.
Thanks.
Edited by HR-32
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
    • BTW I measured the jack I have, it is 70mm at the saddle but you only have about 700 until it returns to 150mm high at the cylinder so it is good but no magic bullet.
