I just did a price comparison (in Yen) between Nengun, Perfect Run & Greenline of a kit list I'm about to order and found each place had some items cheaper than the others.
Interestingly Nengun were only the cheapest on the HKS GTSS turbo kit (but considerably so) and the PFC. Greenline had the cheapest SARD 700cc injectors, Nismo gearknob, HKS dumps, Tomei Poncams + pulley set, and Tomei sump baffle. Nengun & Greenline had the same price for the Tomei manifolds. Perfect Run had the cheapest prices for a Nismo fuel pump and AFMs. According to their website, Perfect Run don't stock Tomei parts.
This just reinforces the point a few people have made here to shop around! Nengun are not always the cheapest and you may end up waiting for parts that you paid more for.
https://www.sau.com.au/forums/topic/102081-nengun/page/15/#findComment-2923467
  • Replies 343
anyone else bought smaller things eg oil filters but where charged with individual postage on all of them. Thought would be cheaper for postage when they are combined?? my case bought 5xpower enterprise filters and trust gear knob but was charged del cost for all of them individually. Does Nengun do a combined del cost??
https://www.sau.com.au/forums/topic/102081-nengun/page/15/#findComment-2931033
thats what i thought they did at first
but they dont
add up each product delivered, the total will be less
dont forget the "delivery" fee also contains tax
anyway....damn nengun is slow...sure price is cheaper, but they're damn slow
ordered my dumps/front 1/2/07, set for shipment 13/2/07 and now its 24/2/07, after 11 days..im still waiting
thats coz i couldnt find HKS dumps/front for BNR34 anywhere in australia
https://www.sau.com.au/forums/topic/102081-nengun/page/15/#findComment-2931953
I went EMS Special for my turbos from Nengun.
I ordered HKS dumps and NISMO gearknob today from Greenline (my NISMO gearknob from the SAU groupbuy never turned up :P ).
Interestingly whilst Greeenline had the cheapest prices the official quote from them was exactly the same as Nengun's. Greenline's shipping with EMS was dearer than Nengun's and the exchange rate they use is less favourable for Australian buyers. However, I still went with Greenline for the dumps and knob to try another vender.
https://www.sau.com.au/forums/topic/102081-nengun/page/15/#findComment-2935561
I'd be going with EMS special, that way all the big brand markings are removed..alot less chance of it going "missing"
Yea good idea, its only an extra $11 nzd, i will also ask them if they could please not display the real value of the item, i dont want it getting stolen or tampered with etc, also if they dont show the real value hopefully i wont get charged importing tax when it arrives in NZ. Fingers crossed :wave:
https://www.sau.com.au/forums/topic/102081-nengun/page/15/#findComment-2935640
Yup everything is going sweet, it says they have recieved my payment, my order is being processed and under shipping it says 11th march so i guess thatis the estimated date that delivery will start (correct me if im wrong please)
Cheers for the help guys.
https://www.sau.com.au/forums/topic/102081-nengun/page/15/#findComment-2938195
Yea they kinda milk you a bit but in the end it will arrive...
The worst part of buying o/s is when it comes through customs, if its over 1k they want 10% tax and nengun put 120,000 yen lol (assholes)
I had to show customs that my power fc was cheaper than 1k which all in all was a hassle but regardless the parts came... happy with em :action-smiley-069:
https://www.sau.com.au/forums/topic/102081-nengun/page/15/#findComment-2938215
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
    • I checked spark on all cylinders and they all visually have spark with the plug pulled and grounded, but plug 1 is the only one that fouled. This was a running swap that blew up and was rebuilt by a machine shop, put a new wiring specialties harness and did all gaskets, studs, and bolts while it was out.  compression is 135-150 across all cylinders. Aside from that from my understanding with the z32 ecu and maf the car should start regardless. The wiring for TPS and the dual 02 sensor/ dual knock sensor stuff shouldn’t actually stop the car from starting or even running well, (just slightly rich)  they just give fault codes. Car supposedly is supposed to start as long as you have z32 afm and ecu with the nistune base map and that’s info coming from a well known and trusted tuner who does a lot with SR/RB (Rsenthalpy). After more trouble shooting today where I’m at right now is that the cas is sending signal to the injectors they click while spinning the rotor, Fuel pressure is now set at 43psi, all cylinders have good compression and all of the plugs looked great (just wet with fuel) except for cylinder 1 which was very black (cylinder 1 has 150psi compression). all of the coils generate spark if pulled out and grounded out on the head. On the fuel pump car just pops into the exhaust. On starting fluid car will fire off. Hard to tell if all cylinders are firing off but definitley a couple. sounds like all of them but it’s only for 3-5 seconds hard to tell.
    • Final update!!! Got the front bar fitted and sprayed and all sorted now. My cutouts worked great and the indicators aren’t just falling off. 😂
    • Is this a brand new LSD? if so, have you followed any break/bed in procedure for it? Usually involves heaps of figure 8 patterns, a fluid flush.
