Hey fellow wagoneers,
This thread is for all the DIY's anyone wishes to post (It may as well be called SK's thread). I'll stick a list of links from the Skyline DIY section that are applicable to stageas, so we don't double up. If you find something i havent yet, just PM me & I'll update it regularly.
Just remember, we take no responsibility to what you do you your car.
GENERAL
Australian Stagea Part Dealers
External Stagea Web Links
Stagea Parts List
Stagea Dyno Results
GLOSSARY OF TERMS
The C34 Buyers Guide
What do I need to do to my car before a track day?
Getting It Off The Line
FYI: Insurance for your stagea
SERVICING
DIY: Stagea 5000km Service
FYI: Air Regulator Maintenance
DIY: RB25DET: Changing the Spark Plugs
DIY: Changing the Oxygen Sensor, Lambda Sensor, O2 sensor, etc etc etc.
ECU
FYI: Series 2 (R34) ECU pinouts
FYI: copgy Backs
M35 ECU Fault Codes
ENGINE
RB26DET Conversion Tutaorial
DIY: RB25DET High Boost mode with standard solenoid
DIY: Adj Camshaft Pulley & New Cam Belt
DIY: Stagea Air Deflector
DIY: Oil Cooler Installation
FYI: Aftermarket Fuel Rails( thanks to SK)
Updates On The Jun 2.7l Staj Build
FYI: Max Hp Out Of Standard Rb25
FYI: Max Power Out Of Neo
How To: RB26 conversion
DIY: 5min $5 Intake Pipe Mod For Your Stagea/skyline.
TURBO
TUTORIAL - Guide To Selecting The Right Turbo
FAQ: Stagea Turbo Upgrading
DYI: Jaycar Boost and Fuel Control
FAQ: Turbo Timer Install.
FYI: SBC ID III vs AVC-R
EXHAUST
FAQ: Stagea Exhaust
FAQ: Split Dump Pipe
INTERCOOLER
FAQ: Stagea Intercooler
DIY: R34GTT Intercooler into Stagea
DIY: Water Spray For Aftermarket Intercooler
FYI: Check Your L/h Inner Guard Intercooler Exit
FYI: Intake Temp Cooling Options.
TRANSMISSION + DIFF
C34 Stagea CV Joint (and Boot) removal/replacement (and part numbers)
FYI: Stagea gear ratio's
DIY: Transmission Cooler
FAQ: Automatic Trans Thread
FYI: Stagea Diff - Is It Wearing Out - Replace With?
FYI: out goes the stagea diff in goes the GTR diff
DIY: Running your Stagea in RWD mode
FYI: Manual Conversion Checklist
DIY: Auto to Manual Conversion Guide - SAU
FYI: Why NOT to convert auto to manual + some manul conversion info
DIY: Stagea Auto Troubleshooting
DIY: How to SAFELY convert your AWD Stagea to RWD (for dyno days, etc.)...
BRAKES + WHEELS
Stagea Brake FAQ
DIY: Anodize your brake calipers
DIY: How To Paint Your Standard Brake Calipers
DIY: Stop your brakes squealing 101
FAQ: Stagea Wheel Dimensions
DIY: Stagea brake upgrade using R33 GTSt calipers and discs.
DIY: Painting your wheels tutorial
BODY
Car Care Prescription (detailing)
FAQ: Stagea Body Kits
DIY: Front Bar Removal
FYI Front Glass Tint
FAQ: Replacement windscreens
Tow Bars for Stageas
FAQ: Insuring your Stagea
FAQ: Alarm for your Stagea
DIY: Rear Taillights
DIY: Headlight Bulb Replacement
Stagea Bonnet Gas Struts
INTERIOR
DIY: Stagea Headunit/stereo Removal
FAQ: Stagea Floormat
FYI: Nismo Key
How to Adjust your Window Close Hieght
How to replace/install LED dash globes.
How to replace/install LED Climate Control globes.
How to remove and replace your air-conditioning filters.
Edited by GoldZilla
fixed links
  • Like 1
https://www.sau.com.au/forums/topic/102808-stagea-d-i-ys-how-tos-f-y-is/
  • 1 month later...
  • 2 months later...
  • 2 months later...
  • 2 months later...
  • 6 months later...
  • 7 months later...
  • 1 month later...
Has anyone done a r33 gtr frount end conversion. can you do it on any stageas. just wondering because i like the r33 gtr front better than all the others and i was going to get a 33gtr but the but i need a wagon for work and i cant get a towbar for the 33 to tow the trailer to go karting on the weekend. so a stageas my best option. however i want the 33 gtr front end. any suggestions?
  • 4 weeks later...
hello fellow owners. just gettn my first stagea its a 99 rs4 s and wondering what mods can be done to the neo engine with out spending mega bucks. (and f*kn it up) Im thinking maybee puting on a exhaust, front mount, bov and uping the psi a notch and then a good tune but this alone is costly. if anyone has done some budget mods and can help me out with some info that would be much appreciated.
  • 1 month later...
Hey guys/girls, i ve just picked up a pearl white 98 stagea and i am looking for touch up paint to fix a few little marks . Any help??? do the stegea paint colours match other nissans similar age like silvia's and skylines???
Yeah, you should be able ot find the paint code on your VIN plate under the bonnet. A Nissan dealer or any automotive paint shop should be able to provide some paint for touch-up use. If they don't have it, they should be able to mix it up without any hassles.
  • 8 months later...
    • This sounds like someone who would have owned an R33 in their past... It's okay, I'm 100% picking up what you're putting down Mark.
    • Just back on what was raised about jacking off the the tow/tie down point on the front of cars. I've used it plenty. I've also watched it on a car where you could see it move the front end of the car. It was like the front end/whole car being tweaked and twisted a bit. I will say, I struggle to find good jacking points on MOST cars. The ones that have good points, I then normally struggle to find a jack tall enough to make the car change height!   One of my go to points for either the jack, or the axel stands though, is either a suspension pickup point, OR a subframe to chassis major bolting point. I actually think its the subframe on my R33 that has a bit of a bend in it, from being jacked in the middle too. However, it could have been one of my many other cars I've had over the years! Or it could also be the from me jacking it up, and the fact the top of the front radiator support isn't there, so it can allow the front of the car to move and bend etc.
    • My apologies. I forgot we were talking about weird beard M series stuff. Had been talking elsewhere with someone about an R33 with similar subject and got confused.
    • Nope, I don't like the look of ND RF, or any ND really, I don't like their faces or arses, why, because of their "modern" lines, the NC, whilst "modernish" has a more rounded shape that I like Well, that's how my overly judgemental eyes see it anyway
    • Should be more than fine, especially the overall fuel pressure would never exceed 3.5bar (assuming that thing never gets more than 0.5bar of boost in stock form). According to the chart, it's 11amps.
