yeah i just got a soft cloth and rubbed a bit it, tries to wipe it off but it was a bit difficult so i just used a wet cloth and then just dried it off afterwards, came up good i rekon.
predator666:
you get to the bulbs from your engine bay, there is a cover that you just give a half turn to and it gives you access to the globes, have a look and twist the cover of, it should all be pretty self explainitory from there, globes range in price, depending on if you want just normal ones or pretty blue ones, hahaha :P
  • Replies 66
Posted Images
R33_Cam: thanx but, err, yeah, i know how to do that.. I wanna know how i can pull the whole front lens off the rest of the assembly to clean. Sounds like other people have done it.
There are some clips, but i've removed them, and it doesn't come off.
Meguires Mirror Glaze Clear Plastic Polish - works best - takes it off easily and it doesnt build up again for a while after. Bought it in K-Mart auto but anywhere that sells Meguires should stock it - from memory its not terribly expensive either. Haha i saw that a lot of the cars had frosty lights at the last cruise and quite a few ppl asked me what i used.
  • 3 weeks later...
If u ever wana get em off put em in the oven for a few min without letting them melt till the goo stuff goes soft n rip em apart
then jam it back together and put it back in for another few to hardend the goo again
werkd for me
but dont try it if u dont trust ureself :(
I hit mine with cutting compound, works a treat.
Don't bother doing it by hand as it wont last long.
I had a friend do it with a very fine polish/cut compound, worked but did not last.
This time I insisted he use the hardest cutting compound he had.
Have a real close look the plastic is very thick.
I also replaced my bulbs with Phillips Opti blue, about $80 a set including parkers.
I found that when I pulled the parkers out they were stuffed and just crumbled in my hand.
Have the problem where I have had condensation on the inside of my lights leaving nice dirty streaks inside... so mine will be going in the oven soon.
Some ppl's lights look really clean but at night u can tell if they have had the inside done too, as heaps i have seen have the same streaks.
My soarer came in and the plastic had almost gone pearly. Had some old kitten cut & polish in a tin at home and it made a huge diff. Finished off with meguires plastic polish
  • 1 year later...
The parking/side lights come out from behind the headlight - the same as the low/high beams... you put your hand in there (hope you dont have big hands) and very akwardly twist it about 1/4 turn, and it comes out, you put your new globe in, and put it back in, with a 1/4 turn and done :D
takes a bit of patients and a few cramps in the hand from the akward angles :D
    • For race cars, this is one part where I find having the roll cage bar having gone through a hole in the floor better than the build it up on a ledge inside... The Merc I help on, the main hoop ends are marked on the car, and the jack is marked... Jack goes under a few inches and lifts one whole side of the car up... Removes that fight for long slim jacks for race car duties!   My biggest issue for the daily drivers I work on, is my jacks don't go high enough. The jacks start out on a few blocks, jack it up, then start a second jack under it on more blocks, and then I can get an axle stand under it. My axle stands are presently in use, and are nearly fully extended. The car is sitting with barely more than a cm of clearance to get the wheel off the studs! Sarah's Kluger is the same, as it has an ungodly amount of droop available in the suspension and a distinct lack of good jacking points!
    • Happy? Yep, my to do list is getting shorter and shorter. Either this light approaching is the end of the tunnel, or I'm about to be hit by a train... Ha ha ha   Also, Duncan isn't that far out of town that you need to make a multi day drive out of it. 😛
    • Sorry I meant that we are building the EH for a client.
    • LOL, when one "money pit" is never enough Noice, and excellent work mate
    • I have more than enough digging, laying blocks, moving gravel, airrating, feeding and top soiling the grass, and setting up the veggie gardens growing some seedlings,  and then removing all the unused rock to keep me busy for the next few months at least,  hopefully the rain stops soon so I can get a few hours in this arvo, but, before that Sunday is washing day, is every body happy, you bet your life we are Nice country road day drives are a day off whenever I'm muscle sore from all the landscaping at the moment, but, more epic multiple day drives will start once the majority of the big jobs outside are completed
