hi,
just bought my first skyline, been waiting for a while to fiond the right one at the right price and i fouind her.
Its a 1994 R33 GTS-T Turbo 5 Speed, with Greddy Profec B Boost Controller, Greddy Turbo Timer, Greddy Front Mount Intercooler, HKS Coilover Hyper Damper Adjustable Suspension, 3 1/2" Stainless Steel Exhaust, 6" Canon Muffler, Twin Plate Clutch, 17" Enkei Racing Wheels, Greddy Boost Guage, HKS Pod Filter, Blitz Blow Off Valve. i will post some pics when i finally pick the car up. looking forward to getting behind the wheel of my new baby.
https://www.sau.com.au/forums/topic/103312-my-new-car/
hpoe fully 2 weeks still waiting for it to be complied. the guy at the car yard is going to put her on the dyno for me this week he said he is expecting at least 240-250kw at the wheels. this this smokes 1st and 2nd and chirps 3rd at 130km. should have a little fun. the car has got M factiory badges on the timing cover and the dash anyone know if this is a good thing or a good good think?? also found out she's got forgies and stainless head gastket.
https://www.sau.com.au/forums/topic/103312-my-new-car/#findComment-1898670
Remember guys its not just the psi its also about cubic feet for air the turbo can flow....
If its a high flow then 200-220rwkw would be the absolute limit you could get....
I mean they just cant flow anymore air... Run out of legs....
If its aftermarket then 13psi could be flowing huge volume of air...
Who knows... But yeah i agree with pred.... 190rwkw area would be about right....
https://www.sau.com.au/forums/topic/103312-my-new-car/#findComment-1900721
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
