Hi, guys... I just bought my R34 GT-t not long. (have not much knowledge about turbo cars ) Up to this minute, my modification is pretty simple:
1. Apexi pod filter
2. Front mount intercooler
3. apexi turbo back exhaust
4. blitz BOV
I am just wondering which turbo should I buy (not necessary to be extremely powerful :D) such that i can direct bolt on without too much modifications on the pipings?
Also, my car constantly have back-fire, is that if i buy a safc will help?
How much does it usually cost for a normal tuning?
cheers everyone
Joe
https://www.sau.com.au/forums/topic/103528-upgrade-turbo-for-r34-gtt-manual/
theres a fair bit of info you need will before you just can just "get a bigger turbo". it would be certainly maxing out your current turbocharger as this will give you the most fun and response on the street (ie: turbo lag)
if i was you i would do the following
good cold air intake (with heat shield / box and route cold air to it)
apexi powerfc ecu
boost controller (apexi powerfc add-on one is fine)
3" split dump exhaust from batmbl (on the forums)
some good tyres and suspension
get it tuned and it should be nice and snappy and make some good power
with a larger turbo comes more lag, heat and stress. before you consider a new turbocharger you will need
aftermarket ecu
aftermarket injectors
cold air intake setup
good tyres
good suspension
aftermarket fuel pump
at least 3" split dump exhaust and 3" front pipe and 3" cat back and 3" hiflow cat
Firstly, set a power goal for yourself.
Bear in mind the stock motor limit is around 260rwkw
So, once youve set a power goal
Have a read of here:
http://www.skylinesaustralia.com/forums/in...showtopic=66556
There are lots of threads on what you need before you get to the turbo stage
And then have a look here, at the results
http://www.skylinesaustralia.com/forums/in...showtopic=55845
Both are sticky threads in this very section... just incase your wondering how i found em
:D
But what do i need to do for that?
aftermarket ecu
good tyres
good suspension
:D
    • So..... it's going to be a heater hose or other coolant hose at the rear of the head/plenum. Or it's going to be one of the welch plugs on the back of the motor, which is a motor out thing to fix.
    • The oil pressure sensor for logging, does it happen to be the one that was slowly breaking out of the oil block? If it is,I would be ignoring your logs. You had a leak at the sensor which would mean it can't read accurately. It's a small hole at the sensor, and you had a small hole just before it, meaning you could have lost significant pressure reading.   As for brakes, if it's just fluid getting old, you won't necessarily end up with air sitting in the line. Bleed a shit tonne of fluid through so you effectively replace it and go again. Oh and, pay close attention to the pressure gauge while on track!
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
