Well guys, I want IGN cut and launch control, but the have discontinued the production of the Powerfc Pro.
What are my options now? Are they making them a standard feature of the standard powerfc in the near future or something?
Can anyone help?
https://www.sau.com.au/forums/topic/103653-launch-control-powerfc-pro/
are you seeing issues with fuel cut instead of ign cut?
you could get a 3rd party bee*r rev limiter which i think can support launch control similar to what you are thinking. otherwise try and buy an rb25det1pro 2nd hand from someone, or you could try and email nengun?
the fc pro still exists for er34 however
nah, just want launch control.
As for nengun, they said its been stopped and not to ask for them.
I just want to know what they are going ot replace the powerfc pro with.. Maybe they'll make those features standard with the next generation of powerfc?
i dont think there will be any new power FC model released. in fact one day they may stop making them alltogether. From what i have seen and been told Apexi (now Apexera) is not in good shape. they did not even have a stand at this years Tokyo Autosalon...
I wouldn't be suprised if they really were struggling as a business.
The PFC is a good example of a product that has had bugger all development in recent years.
It's still a good product in my books, but if the company (APEX, APEXi, APEXERA or whatever they call themselves now) was serious about the product they would at least have foreign language (at least English) manuals for all versions.
Oh year - the handcontroller design and lighting really is something out of the 1980s!!
Edited by Gav
From what I have seen all the standalone launch controllers/rev limiters are all hard cut limiters i.e cut all spark or cut all fuel as opposed to a/m ecus which (some) have a soft cut feature.
I can gather the negative side of a hard cut fuel limiter but what, if any complications would a hard cutting ignition limiter possibly cause to an engine?
  • 6 months later...
ive just realised why the pro model doesnt exist.
the pro versions were based on the older FCC1 layout.
much like what the ap engineering versions use.
it must need to use the older chipset/firmware for some reason.
basically the cpu used isnt in production anymore so apexi brought all the remaining stock (likely) and have had to discontinue the production.
perhaps it was too much developemt to make it work on the new chipset/firmware or they couldnt for some reason.
Yes Apexi isn't even having a D1 car this year.
What i wanna know is will a fuel cut damage your engine or not?
they havnt run a d1 car in the japan now for 2years (if i remember right) i remember reading or watching somewhere.. they said we are going to foucs on the america market from now on
shit yeah it will damage it
thats a load of crap.
Ignition cut will do more damage than fuel cut.
Fuel cut cuts the injector on its next cycle thus no fuel at all being in the cylinder. How can that damage it?
And don't say that "It will lean out"
Becuase if injectors can't cut fast enough then they are stuffed. They seem to be accurate enough at high rpm... So why would they lean if told to cut...
So drive yore car on the limiter for a while and see how long it lasts ! Ive seen the melted pistons this
causes ! Ignition cut is definately better and you get the bonus of lots of bangs and flames ! :blink:
causes ! Ignition cut is definately better and you get the bonus of lots of bangs and flames ! :(
thats just a dumb ass thing to do.
Do you hold yours flat and on the rev limiter for long periods of time?
Is the invisible fuel the isn't going into the cylinder because the injector is off going to melt the pistons?
Actually i did use to, when i first took my 99 sti to the race track and found out it speed cut at 180 kmh which was cutting of the fuel and yes it did melt a couple of pistons ! And yes it was a dumb ass thing to do ! Also micro tech ecu have function you can set up as a launch control.
    • Just trying to get my head around this. At 5psi of boost, you turn on your wmi pump, and then you're using a 3000cc injector, to allow flow upto the actual engine, where you have your 6x200cc injectors and a 500cc injector. If the above is correct, what advantage are you obtaining by having the 3000cc injector blocking flow, is this just incase a line breaks between that injector and the motor you can stop flow immediately? Or are the 6x200cc and 500cc less injectors and just spray nozzle?
    • Welcome! New member myself, but I had an R33 back in 2002. Best advice I could give, based on my experience: if you're running the factory turbo, be very conservative with boost. I made the mistake of just fiddling around with the boost controller and cranking the boost for fun, and the end result was my intake pipes popping off frequently from the constant deluge of oil that was being blown into the recirc by the stressed-out turbo, which itself was siphoning oil from the engine and farting it out both sides of its centre bearing (or something to that effect). If I could do it all again, I would have gotten a new turbo and had a tune dialled in professionally and then just left it alone! Funny you mention the metal shavings in the gearbox, as I had the same thing - the probe plug (magnetic drain plug, essentially) would come out caked with shavings. At least it was doing its job. Not sure if that's just sacrificial wear and part of the deal, or if my gearbox was shagged, but I wasn't abusing it. Enjoy the R33 - they're a dying breed, and if they weren't $35k+ on CarSales in Queensland, I might have picked up one of those again, instead of the 370GT I own now (though I'm loving the 370GT, that big 3.7L V6 just hits different).
    • Howdy folks. I owned an R33 back in 2002, which was thoroughly beyond my capacity (financially speaking) to maintain/insure, so we parted ways in 2004. Fast forward 21 years (to literally yesterday, in fact) and I'm now the proud owner of a 2007 V36 370GT. I'm happily surprised by how much power the VQ37VHR makes, compared to the RB25DET, considering the latter is turbocharged. I had planned to add a turbo at some point but I'm on the fence about whether I'll even need it (though I do love the sudden onset of extra torque). Any other 370GT owners around the traps, I'd love to hear about your experiences with this car (good and bad).
    • Perhaps the answer is... more jacks!* *proper jacks must be used.
    • I NEVER think about using a scissor jack unless there is absolutely no other alternative. f**king things are dangerous, annoying and stupid.
