She's run a big end, driver has continued on,  rod grabs and chucks itself out....Pretty usual RB  behaviour.....  :D
NB.  The blueing on the rod big end is the givaway as to the event sequence........
i reckon we may have a winner here.
  • Replies 67
was it in a street or track engine? if the motor was used for motor sport your on ya own . if it was a street motor i would be talking with the engine builder for some sort of compersation also depending how many ks the engine had done of course .but i reckon it looks like rod bolt failure to me .
if it was built in japan and just gave up
my guess was
previouse engine owner spun a bearing ( thought shit this will cost)
pulled off the sump replaced bearings put her back to gether running and sold her at the auctions
on tight arse jobs he probably just slapped teh bearings in and dindt torque it down properly
the 1000km later because the previouse owner didnt fix the actuall problem for the bearing failure you have had the same drama but obviously the dirver dint here the rattle before it was too late
if built in australia and is only fresh there are 1000 other reasons
pete
You say you wasnt driving it, was it knocking the last time you drove it ?
If yes the big ands gave up due to oil starvation , spun kept driving and the rest ..........
If it wasnt knocking then the dodgy patch up job has more weight , like pete said . Either way if the engine was recently built well i wouldnt gat tem to build mine ..
I feel sorry for you Charlie , something like that happen to me about 3 years ago. Mine a turbo spat the wheel out and stuffed the engine while someone else had the car and took it around the block, he even lost it and hit the kerb !!!
She's run a big end, driver has continued on,  rod grabs and chucks itself out....Pretty usual RB  behaviour.....  :P
God has spoken :D
I'm with Benno. There are even signs of heat spots on the journal face in the bearing cap.
Sorry but sounds like driver error (yet again) in that the foot didn't lift when the knocking started. Sure there might have been a little damage but not catastrophic.
It definately wasn't idling at the time it let go either...
LOL...when i saw the pic i thought something silly with a rod bolt...but there are those that know more then i ever will :D
I think the people that had the thought it wasnt to bad took it for drive. i think you said you had a 9k limter and say they sat on it alway around the block. Question when you went and seen the car was the oil spilt all over there work shop floor or a least a new patch where it happen or was it down the road more.
Hope you sort it out
Brad
First, let me say I am sorry to see an RB in that condition, hope the rebuild works out well.
You can look for all sorts of reasons, the one that sticks out for me is that it's #6. The one that suffers from detonation first, the one that suffers from oil starvation first, the one that runs the leanest etc. All that makes me lean towards big end bearing failure caused by eithe detonation or oil starvation.
For detonation, check the piston top. For oil starvation, look at the other bearings and the crank, there should be some signs.
I guess it's because I see blown up race engines all the time. But compared to the original build price, it's not a high cost repair by the look of it. Weld up the block, new/used crank, one rod, one piston, new bearings, gaskets and seals. Around $5K should cover it easily.
There may be hidden other damage, so be carefull when disassembling it. It is possible to cause more damage if close attention isn't paid to the process.
:) cheers :D
Blk180, The last time I saw the car was when I had it towed to the workshop after the initial problem developed. The car was tuned very conservatively to run on pump fuel, so it wasn't detonation. I am not sure about the oil spill location as I didn't see the car again until it was towed to another workshop.
Piston has also hit the head and bent 4 valves. Luckily, the head will be repaired.
She's run a big end, driver has continued on,  rod grabs and chucks itself out....Pretty usual RB  behaviour.....  sad.gif
Correct.
Exactly.
There are alot of things that I cannot say for obvious reasons, but I will say that the engine developed an engine knock which we initially diagnosed as a big end knock. So I had towed it back to the workshop to avoid any further damage.
I don't believe it is the engine builder's fault.
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
    • I checked spark on all cylinders and they all visually have spark with the plug pulled and grounded, but plug 1 is the only one that fouled. This was a running swap that blew up and was rebuilt by a machine shop, put a new wiring specialties harness and did all gaskets, studs, and bolts while it was out.  compression is 135-150 across all cylinders. Aside from that from my understanding with the z32 ecu and maf the car should start regardless. The wiring for TPS and the dual 02 sensor/ dual knock sensor stuff shouldn’t actually stop the car from starting or even running well, (just slightly rich)  they just give fault codes. Car supposedly is supposed to start as long as you have z32 afm and ecu with the nistune base map and that’s info coming from a well known and trusted tuner who does a lot with SR/RB (Rsenthalpy). After more trouble shooting today where I’m at right now is that the cas is sending signal to the injectors they click while spinning the rotor, Fuel pressure is now set at 43psi, all cylinders have good compression and all of the plugs looked great (just wet with fuel) except for cylinder 1 which was very black (cylinder 1 has 150psi compression). all of the coils generate spark if pulled out and grounded out on the head. On the fuel pump car just pops into the exhaust. On starting fluid car will fire off. Hard to tell if all cylinders are firing off but definitley a couple. sounds like all of them but it’s only for 3-5 seconds hard to tell.
