  • Replies 1.5k
Posted Images
For those of you that care here's wat happened in qualy
btw.... live timing is jerkoff-able
1 G. Fisichella Renault 1:33.840
2 J. Button Honda 1:33.986
3 N. Rosberg Williams 1:35.105
4 M. Schumacher Ferrari 1:35.010
5 M. Webber Williams 1:35.252
6 JP. Montoya McLaren 1:34.536
7 K. Räikkönen McLaren 1:34.667
8 F. Alonso Renault 1:35.514
9 C. Klien Red Bull 1:35.171
10 R. Schumacher Toyota no time
11 D. Coulthard Red Bull 1:34.614
12 R. Barrichello Honda 1:34.683
13 J. Trulli Toyota 1:34.070
14 J. Villeneuve BMW 1:34.752
15 N. Heidfeld BMW 1:34.783
16 F. Massa Ferrari no time
17 S. Speed Scuderia Toro Rosso 1:36.297
18 V. Liuzzi Scuderia Toro Rosso 1:36.581
19 C. Albers Midland F1 1:37.426
20 T. Monteiro Midland F1 1:37.819
21 T. Sato Super Aguri 1:39.011
22 Y. Ide Super Aguri 1:40.720
Edited by ctjet
Agreed, live timing is sex.
If Webber was able to get a few more laps in with those new tyres at the end he could have ended up on the first row.
No one was near him for the first half of the session, he did well to bank that nice lap.
oh and i didnt mention that "Fisico" looks good for a win, not that im cheering for him or anything but he kept on pumpin in the fast ones with no probs
and wat happened to Alonso???
SMWBH syndrome.
Lets hope Webber gets a podium, Williams/Cosworth combo looking ok at the moment hopefully they can keep it up.
Rosberg has certainly impressed.....so far.
what the??? Nico>>>> P3 (not bad for a newbie!!!) glad to see Alonso at P8-might get interesting if he starts to come through the pack. I'm betting Fisi doesnt last long at the front-hmmm could be an interesting race with this jumbled grid.
well the race was good for the first 20 laps, then it was a bit of a snooze fest.
it was nice to see webber not taking any crap from rosberg at turn 1. but they both got hung out to dry a bit. I dont think there was any great need for rosberg to squeeze webber so far off line as webber was always going to come up the inside, rosberg should have been more concerned with the rest of them (gonzo in particular).
shame the cossies blew, but 2 fresh engines for melbourne means i will get to hear a V8 at 21 000rpm in qualifying. :dry:
I'm glad Kimi got shunted-it will make it interesting later in the season when he tries to regain some points.
Yep fresh cossies for the boys in Melbourne-love to see the williams on P1 P2
Edited by overev1
Rookie mistake from Rosberg.He should have realised Webber was going though and just tried to stop Alonso.He ruined Webbers and his own chance to shine up front before their motors went.
Montoya wasnt that quick and hardly seen him,but Raikkenon would have been fast i think as always.But its starting to look like the Renaults are gona run away with it again.
I reckon Nico will get is arse kicked for the turn 1 move.
Far too busy trying to squeeze his teammate right to the inside, there is no excuse for allowing someone around the outside
absolutely. like i said above he was far too concerned with keeping webber behind him when he should have been thinking about a fast starting, fuel heavy renault. because had he and webber kept alonso behind i doubt alonso would have been able to pass them with the amount of fuel he was carrying. it was a dumb move by rosberg and nearly ended badly. he is so quick though and will definately keep webber on his toes.
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
    • Lock me in mate, although I'm not sure if I'll be heading up from Goulburn or down from Sydney, either way, return will be back to Goulburn
