Hey guys, got my cooler fitted, got a type m front getting resprayed as i speak, and cut the opening of the bar for more air into the cooler.
My question is should i have my bumper meshed up or not?, how many on this board have meshed theirs up???, and should it be done, i knw it looks cooler w/o the mesh, but will meshing help save my cooler in the long run??
Edited by nsta
https://www.sau.com.au/forums/topic/104242-to-mesh-or-not-to-mesh-cooler/
  • Replies 44
Posted Images
Mesh will stop stuff like decent sized gravel flicking up and putting a hole in the cooler..that has to be a good thing!!
If you care about your cooler then mesh it. If you want to show the world your bling cooler, then leave it off. Personally for my 10 cents worth - go with the mesh.
if you put the mesh on you will probably take it off in a few months, and vice versa. hahah thats what im like.
seriously though, there are some big bugs round Australia and they eventually find a way to bend every bloody fin, and the last thing that goes through their mind right before they hit that cooler is...... their ass
hahah, nice thoughts, i'll see how i go tommorow wen car is back, somehow i got the feeling im going to be taking the mesh off right away!!! thanks
Can you post pics when your done? I wanna see what a Type M bar looks like with a centre bit cut out.
Cheers,
Setting aside the 'wank' factor of having mesh....I've done heaps of interstate driving as well as some fairly spirited country road cruises/drives and my mesh has saved the coolers from heaps of rocks & bugs etc. All you need to look at is the state of the mesh now with bent bits etc etc.
So I'd say it depends on what kind of driving you intend to do....
if you ever plan to drive fast on the freeway, or do to a race track you should mesh. having had the GTR (no mesh) out on the track a number of times i can tell you the cooler looks much worse for wear than it did a year ago. i have now bought the stock GTR mesh for it and one day will whack it on.
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
