Hey guys, has anyone ever experienced HICAS more than 5 times in the span of their car's life? yup thats right, all scared the S*&t outta me too!, i mean why does it do what it does, i sometimes feel that it could be more a driver error, but all the symptoms are there, main two being 1) over 80km and 2) vicious and oncontrollable (so true)
Im very greatful ive been lucky these five times whilst on quiet roads (i clawed the side of my car once), but i think ive come to a point where im thinking HICAS has to go?what do you guys think?anyone here experienced HICAS kick in before?
I've really only heard bad things about HICAS, and ive only experienced it on the road twice (thankgod), as the rest were trackdays which weren't so bad, but its always on the back of my mind, but the thing is , i do forget about it at times, and worry that one day its gnna give me hell!
Does HICAS only work around corners or even sudden movements on the straight?
https://www.sau.com.au/forums/topic/104400-hicas-the-end-is-near-i-feel/
  • Replies 84
HICAS (or any 4WS) is great on a street car that gets driven well below the limits. Theoretically, it should improve the steering response, stability and turning circle of the car.....in the same way that theoretically, traction and stability control makes your car go faster around the corners :D
As for a brief description on what HICAS does, run a search for the word "HICAS" on this Q&A page:
http://www.nissanperformancemag.com/february05/ask_sarah/
umm, at 80+km around a corner, it can ,depending on how you've attempted cornering give you what i belive to be some sort of vicious oversteer, which is very very hard to moneuvre/correct, i havent been able to, but luckily, i never hit anything (bar that one time, which wasnt too bad), it unnerving cause some corners it wont kick in, whereas others HELLO HICAS!!!!!!
someone posted this pic earlier when sumone asked abt the same thing..
I like his explanation ...
HICAS is 4 wheel steering
HICAS stands for "High Capacity Active Steering"
suppose to correct, minimise your understeer when normal driving, but very annoying at high speed
Edited by SKY 34
ohhh alos HICAS is in GTT +- 0.5 degrees or so I heard
while SUper HICAS is in GTR +- 1 degrees
use a HICAS lock bar to remove that problem~~
I experience HICAS thingy, went into wild snakey, I can't control the car....but never tried with the lock bar...so it's either my driving suk bad..or it's HICAS...
I'd like to believe it's HICAS :lol: :lol: :lol:
Edited by SKY 34
hahaha, you're with me on that one, id like to believe its HICAS, but i do believe its HICAS as ive never experienced anythign as vicious as this before, and im always driving on the limits when it happens, this aint a good combination for a car that actually handles well before this sudden HIT
I dunno abt the details...the pic is suppose to be from R34 manual...it's showing HICAS correction at slow med and high speed...
but if you ask me what exactly happened during cornering I can't really tell....I think the car will try to prevent your wheels from loosing traction so 1st thing the TCS will cause fuel cut.
If radius of turn is wide enough, the TCS will not activate (I'm not sure how TCS works either but I notice if my radius of turning is wide, TCS does not kick in)..
in this case now the HICAS will try to prevent understeer, also for more traction, the rear wheel will turn in the same direction as the corner you taking (see picture, high speed)...let's say fast corner to right, front wheel to right, rear wheel to right slightly....as you countersteer (steering wheel turn to left), the front wheel to left..but the rear still to the right because of HICAS....I would imagine this will create a rotating motion making the car want to spin 360 degrees anticlockwise( massive oversteer)....
so the tail of the car is now swinging in anticlockwise direction dangerously....and as you notice the tail of the car start spinning too much you slam the steering wheel back to the right...and there you go big messy snakey...that or you spin out....
I'm not sure about what I said...jsut my impretation of what might happened...I think what I said is rubbish ..lol ...but I havem't been able to find a proper explanation yet... ><
i got rid of hicas on my 32, and now on my 33 and never looked back.....wen ur driving hard 9in my case trying to drift) theres nothing worse the unpredictable steering reponse.....my suggestions, get a lock bar and feel how good it feels to have almost complete control of ur cars handeling.......then ul know if ur a bad driver or not LOL
Whats it cost to get this done? Can basically anywhere do it?
HICAS Lock Bars can be bought from Nengun/Greenline
http://www.nengun.com/catalogue/product/60
The other alternative is do what SK recommends and remove the bloody thing ;) (frees up approx. 20kg). Costs nothing if you follow a tutorial.
.....I thought SUPER HICAS was only on R33 and later models and I was sure that R32 GTR's on have normal HICAS....
    • That sounds like an excellent idea. But total self-sufficiency means exactly that. You have no-one else to blame when your system faults out and you have no power for a week or two while it gets fixed. You'd have to go the whole hog and get a diesel genny and all the switchover gear, to get you through such times. And, despite the fact that over 20 years, my system has been pretty reliable**, I have seen so many inverter explosions (or less dramatic deaths), panel and roof JB fires, and so on, over that time, to know that the stuff is the same as any other bulk Chinese manufactured stuff. The failure rate is well above zero - both on the equipment and on behalf of the meth addled installation labour force. And then..... warranty and means of redress against the supplier you bought the gear from. Best I can tell is that only a handful of solar companies are still around within 5 years of starting their advertising pitch. They disappear and phoenix like crazy. So, as per 1st paragraph, I suspect the only way to is go balls deep and spend maybe 2-3 times as much as you might think, so that you have every base covered. Plus, know and understand your gear intimately, so you can diagnose problems, sort them out yourself, etc, etc. Plus, probably have to consider upgrading various parts as the years pass, to maintain compatibility with newer stuff, performance and reliability, etc, etc. Whereas, remaining attached to the grid has an ongoing cost that keeps going up even if you use bugger all power from it. But it does provide the fallback in case of the worst case with your own gear. You either pay up front or as you go, I suspect.
    • Add more solar panels to the array. Call the electricity company and tell them you're moving out... Live off grid electric wise
    • Hi Jasmine. How's the war going?
    • I'm extremely suspicious of the VPP stuff. Best I can tell, you surrender any and all control of your panels and battery to the VPP, because there's no way that anyone could write a sufficiently useful set of "rules" as to how much you would be willing to let out of your export meter at any given time. If one of your main interests is to have enough in your battery every evening to get you through the night without having to import, you could easily find yourself with nothing in your battery at the end of the day, or part way through the night, and then be paying import pricing instead of paying nothing. I cannot see how this cannot come to pass.
    • majority aftermarket is an10 yes, but majority of OEM is An12 r35 OEM cooler lines at close to an 12, the hard line that car uses is almost 20mm  Porsche OEM is also AN12   i figure, if our power levels are close to 1000hp, then AN12 should be a must if many OEM standard power vehicles use AN12
