  • Replies 78
It's great to see some low mounts out kicking ass GREAT STUFF guys
AWESOME times.
AND i also think that backyard engines are the go (more time, effort and care taken)
I agree with cruiseliner that i hold a great deal of respect for people willing to give it a go themselves and don't just give there wallet a work out.
pete
ps who needs big single when twins do it better lol lmao
Pete quick you had better tell Mark Jacobson :lol: :lol: that he'll go quicker with twin low mounts, 9.49 at 149.85 1.51 60ft RB26 non stroked just isn't good enough
buster you might want to read the state i posted and you quoted it doesnt say low mounts so you might want to tell KW, GTR700 and munro there got it wrong. As there a little quicker than mark and i know mark his no slouch but i dont think he will surpass the time gained by the above. SO DONT TRY and twist my words so say something there not
pete
ps and yes i am a fan of low mounts for all round performance
I'm sure if Mark wanted to go quicker with his T51R, he could do so easily. Don't forget that Mark's car is also a FULL weight street car - ABS, air con, complete interior, etc, plus the added weight of ANDRA tech inspection compliance.
Pete what happened when Simons single turbo graph was compared to the twin turbo low mounts on the R34?
I DONT KNOW WTF YOU ON ABOUT AND I NOT GETTING BLAMED FOR TAKING A GOOD THREAD ON LINE
SO FINE SOMEONE ELSE TO WITCH HUNT
again great work guys cant wait to read the future progress of these cars
nxtime i got nothing against mark his the guy that supplied with gear for my motor and talk to him actionally (i dont bring him into this)
Its ok Pete I'll stop now lol lmao :lol:
hahaha. these threads alsways go OFF - literally.
Low mounts v high mounts v singles. Who gives a toss? As long as it goes fast, then thumbs up.
Plenty more left in XRATED's car. Well done again.
You the man Charlie, no need for little snide remarks either way at the end of the day its a fast Skyline and thats all that matters
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
    • Lock me in mate, although I'm not sure if I'll be heading up from Goulburn or down from Sydney, either way, return will be back to Goulburn
