Just wanting to figure out what turbo option would be the best in terms of price, response, and overall power band.
I was originally thinking a gt30r with high-mount manifold and tIAL gate' on about 17psi should hit the mark - not too sure tho.
I was having a look on the sticky thread about the rb25 turbo upgrade, and im wanting to find out more about the hks 2835 pro s... i tried searching the forum and the net and couldnt find any rock solid specs or real-world figures.
I'm just leaning towards the internally gated turbo now because its cheaper to bung one on. But would one of these fit low-mounted in a 180sx? And also, what other mods besides the obvious ones are needed for this power. I dont really want to have to do cams unless i really need to..
Cheers, Guys B)
  • Replies 51
i dont really trust the hiflow. I've seen one break before..
Id prefer an aftermarket one. And from what i've seen from that sticky thread on here, you SAU boys are making like 240kw or less from a high-flowed turbo.
As i said previously I have a s2 r33 gts-t engine in my 180sx - and im aiming for 270kw at the wheels on a stock engine.
Does the 2835pro s have boost control problems by being internally gated, or am i better off with a straight garrett gt30r :P
it has similar response if not very close, the exhaust housing is the same size a/r but the snout is made larger so there's not like an larger a/r housing is thrown on, just a bored out larger hole in the standard one. drivability should be awesome, comes on quick and has plently of top end
Did you see a GCG Hi-flow break?
Turbos break for any number of reasons. A "new" turbo is just as likely, and a hi-flow is as much a new turbo as anything with a "hks" label on it.
There are R33 GTS-t's making 250-260rwkw with a GCG hi-flow's.
Is everyone using a GCG Hi-flow in the Dyno sticky? (no they are not)
If you dont think im right, then search these forums yourself and see.
Otherwise, by all means use a expensive 2835 and see the same result with more expenditure
so in your opinion theres no real market for the hks turbo's when these highflow stock turbos are around.
Im not trying to waste my time or money, but i'd rather not have to send turbo's back and forth to GCG headquarters. It would most likely be more convenient for me to buy a new or used turbo locally..
And what flow do these GCG turbos make - is it more than an equivalent garrett/hks/trust turbo?
gt 30 r lowmounted with external gate in kit form can be purchased and installed for about $6000 that can give about 275rwkw on std engine with ok response on a 0.64 housing..
all you need is engine management then..
one GCG - 250rwkw @ 15psi
another 264rwkw @ i think 16psi/17psi
But IMO the GCG is right into the market if your MAX aim is 270rwkw. 2835's i think push more, but why get something bigger than the application?
They've finally got into a good combo thats a direct change over, and probably takes less time to arrive than a new turbo from Japan
But enough outta me. You do what you want.
IHI/Apexi AX6 turbo and ext gate....definately good for that on 1.0bar of boost.....ur internals mite not make it through tho
im currently running 294rwkw on std internals, just using a cometic metal head gasket..
the gt30r example above - 2 people running it - are both on std engines with std gaskets..
so he should be fine as long as the tune is not lean
the gcg one on that website says $1950?
is this the correct one?
thats only 200 bucks cheaper than a hks one, and more expensive than a trust td06-20g or a garrett gt30r...
:cheers:
i dont understand, are they cheaper for SAU members or something?
Plus if this was correct i wouldnt get any money back from sale of the stock turbo, to the upgrade one - making it more expensive
Edited by tuna_144
Your saying your car is stock you will need a full 3" exhaust from turbo back. Intercooler hybrid would be fine look in group buy section they have cheep kits. As for the turbo I agree with the others HI-flo is probably your best bet bolts staight back in place no mucking arround with oil/water lines. But I think this kit from www.nengun.com is good value too.
from nengun site
New version HKS GT-RS turbine kit 400PS with a HKS Actuator, Oil lines gaskets, New 740cc Nismo injectors, New format Apexi Power FC and Handcomander to suit a Nissan Nissan R33 GTS t
The HKS GT-RS Turbine. This Kit comes with everything for a straight bolt on to the existing Flange. Parts included are the HKS heavy duty actuator, oil lines, gaskets and bolts.
$4258 delivered.
You will also need a bigger fuel pump (Boch 044)
z32 airflow meter
fuel pressure reg
boost control
from what I have learnt on these forums I estimate
GTR-S turbo should make 260-270, 270-290 with cams
GCG highflow should make 240-250, 260-270 with cams
cheers
Tuna144 is on the ball.. i don't see the obsession with the GCG turbos for price/performance when they are nearly $2k.. when several full kits are available with all that is required for possibly only a few hundred more all said and done.
your only real advantage to a highflow RB25 option is the stealth aspect in the nazi states..
Im going to go hiflow myself, but probably via ATS (Adelaide Turbo Services) in liue of GCG. ATS hiflows are suppossidly built with GT30 internal's, fully balanced etc.....
So, Id gather good for a little bit more HP than a GCG, not much but it might help in your case. Slightly more than $2k.
i'd be goin a GTRS those things are awesome.. boosts early and has decent topend.. and capability of pushing close to 300rwkw if not a little bit over on a rebuilt engine with all the work.. on a stock engine i'd say you'd be able to get 260-270rwkw safely and rather easily
Yeah Ive been watching that deal at Nengun for ages, I think thats the way to go if you dont want to go down the GCG path. GTRS turbo kit, PFC and controller and 6 injectors for under 5k delivered is pretty cheap. :O
Saying that there is no real cheap way to get that power target because as soon as you start changing the turbo and boost settings away from the factory settings expect to pay more money for support systems, tuning and maintenance etc. Plus whats cheap for someone is expensive to someone else.
    • So stock ECU does not like anything above 10 psi?  That Nistune one is just for "try" if it will be any different, I know it need to be tune for that. I know but YOU may know about these problem but i/we dont. They few little Skylines here let alone people who know anything about tham so that is why iam asking here
    • So now we have a radiator with no attachments whatsoever. It lifts up with a particularly tight spot between the drivers side air box mount and the lower radiator outlet, but if you've got this far you will sort that too. This is the lower mounts with the rad out so you can see where the rubber bushes go, it is a straight shot upwards Done! Assembly is the reverse of disassembly, with blood less likely to be shed.
    • Right, onto the second last trick. The Air Con condenser is mounted to the front of the radiator and stays in the car when the radiator is removed. There are 2x 10mm headed self tappers holding the top of the condenser to the radiator, remove those The bottom of the condenser is attached to the radiator with clips. You need to lift the condenser out of those clips and clear (up, then forward). f**ked if  could work out how to do that last bit with the front bumper on. I hope you can, and you share the trick.  Bumper removal probably deserves its own thread one day once I've recovered the will to live, but basically you need to remove the wheels, front inner guard liners (clips and 10mm headed bolts), the self tapper between the guard and the bumper at the rearmost point of the bumper (same as an R32 that bit), any remaining clips at the top/front of the grill, an absolute bastard design with a plate that holds the top of the bumper above the headlight each side (only 1 bolt which is tricky to get to, but the plate catches 2 places on the bumper and must be removed....carefully!) and push clips between the bumper and guard under the headlight. If you've done all that you will be faced with wiring for the fog lights on both sides and in ADM Q50 RS at least, 4 nasty tight plugs on the driver's side for the ADAS stuff. So, the clips at the bottom look like this on drivers side (looking from the front) And on the passenger side (also from the front), you can see this one is already out Clearance on both of these are super tight; the condenser needs to move up but the upper rad support mount prevents that, and the radiator can't move down far because it is (rubber) mounted. Once you achieve the impossible and drop the condenser off those mounts so it does not stop the rad moving, you are good to go
    • OK, next the shroud needs to come off and there are a couple of tricks. Firstly, there is a loom from near the passenger side headlight to the fans, coolant temp sensor etc and there is no plug to undo.  In my case I was OK to leave the shroud on top of the engine so I just undid the passenger side fan plug and about 10 of the clips which gave enough free wire to put it aside. The fan plugs were super tight, the trick I used was a small falt screwdriver to push down on the release tab, then a larger flat screwdriver to lever the plug out of the fan unit....be careful with how much force you apply! If you need to remove the shroud altogether for some reason you will have to deal with all the plugs (tight) and clips (brittle)....good luck. I removed all of the clips and replaced them with cable ties that I will just cut next time. Also, in the Red Sport / 400R at least, the intake heat exchanger reservoir hose is bolted to the shroud in 2 places with 10mm headed bolts; so remove them (the hose stays in the car; no need to undo it at the t fittings down at the radiator lower mount. Once you've dealt with the HX hose and the wiring loom, there are 3x 10mm headed self tappers holding the top of the shroud to the radiator; remove those.   The shroud then lifts out of the bottom mounts where it sits on the radiator, up and onto the engine out of the way. Simples
    • Ok, disregard my “rate them” comment, sorry for my unrealistic input
