Item:
1 x R34 RB25DET NEO Turbo
Sydney Northern Beaches
Prefer Local Pickup to save Delivery hassles; but can organize at buyer's added expense.
Item Condition:
* Excellent Condition
* Less than 1mm Shaft Play (in all directions)
* Seals in perfect condition
* Absolutely no oil found in the intake
* Checked by 2 mechanics for above condition report
Reason for Selling:
Upgraded to a bigger turbo... seeking more boost :)
Price and Payment Conditions:
Chasing $600.00AUD excluding delivery charges.
Payment through Direct Deposit or Cash upon Pickup
Extra Info:
* Standard wastegate is not included as it has been re-used for the time being until aftermarket wastegate is purchased.
* Turbo has been cleaned and conditioned after removal.
* No mounting hardware is included as this has been re-used as well.
* Turbo is ready to go right now.
Contact Details:
Please send any queries or offers to me through PM or SMS - 0415 263 309.
Edited by satanic
https://www.sau.com.au/forums/topic/105090-fs-r34-rb25det-turbo-standard/
I don't know a lot about the turbos, but I havre read that the 34 turbos are larger (housings) which make them the ideal turbos to hi-flow.
Had a few offers, only one or two who are actually genuine... please do not send me PMs with stupid offers.
Thanks
Stan
the series II r33 is the same turbo as a r34 gtt
it is a little larger that the first series and has a ball bearing core.
the compressor wheel is nylon which is lighter making it spool quicker. most people are scared off by the thought of a 'plastic' wheel in their turbo but it is the exhaust wheel that will spit as a result of running too much boost for a period of time.
both series turbos have ceramic exhaust wheels also to aid in reduced spool up time.
great turbo. i have one on my rb20. very fairly priced at $600.
You can't see it in the photos because it doesn't come with it... this was clearly stated in the first post; sorry about any confusion caused.
Turbo is still up for sale...
This is a great price..
Take this turbo to ATP(Melb) or GCG(Syd) and get a "sierra/sierra" hi-flow. Whack it on you car, install Tomei Poncams and you should see at least 250rwkw.
I have a 33s1, with Tomei Poncams and Head porting, and am making 274rwkw@16psi. Due to std bottom end, i decided not to push the combo any further, till the forgies are installed. Can't wait till i have 20psi, and start to experiment with the adjustable EX and IN cam gears :(. (PM Bassjunky for details on IN cam gear adjustment :), it can be done while still retaining the VCT )
Even in stock form this turbo should make more power on a 33, till you are ready to hi-flow it :)
Good Luck with the sale
Thanks Al
Even though I had very limited understanding of what the above actually meant technically, yeah, what he said :(
All those guys who PMed, I have replied...
    • Let's be honest, most of the people designing parts like the above, aren't engineers. Sometimes they come from disciplines that gives them more qualitative feel for design than quantitive, however, plenty of them have just picked up a license to Fusion and started making things. And that's the honest part about the majority of these guys making parts like that, they don't have huge R&D teams and heaps of time or experience working out the numbers on it. Shit, most smaller teams that do have real engineers still roll with "yeah, it should be okay, and does the job, let's make them and just see"...   The smaller guys like KiwiCNC, aren't the likes of Bosch etc with proper engineering procedures, and oversights, and sign off. As such, it's why they can produce a product to market a lot quicker, but it always comes back to, question it all.   I'm still not a fan of that bolt on piece. Why not just machine it all in one go? With the right design it's possible. The only reason I can see is if they want different heights/length for the tie rod to bolt to. And if they have the cncs themselves,they can easily offer that exact feature, and just machine it all in one go.
    • The roof is wrapped
    • This is how I last did this when I had a master cylinder fail and introduce air. Bleed before first stage, go oh shit through first stage, bleed at end of first stage, go oh shit through second stage, bleed at end of second stage, go oh shit through third stage, bleed at end of third stage, go oh shit through fourth stage, bleed at lunch, go oh shit through fifth stage, bleed at end of fifth stage, go oh shit through sixth stage....you get the idea. It did come good in the end. My Topdon scan tool can bleed the HY51 and V37, but it doesn't have a consult connector and I don't have an R34 to check that on. I think finding a tool in an Australian workshop other than Nissan that can bleed an R34 will be like rocking horse poo. No way will a generic ODB tool do it.
    • Hmm. Perhaps not the same engineers. The OE Nissan engineers did not forsee a future with spacers pushing the tie rod force application further away from the steering arm and creating that torque. The failures are happening since the advent of those things, and some 30 years after they designed the uprights. So latent casting deficiencies, 30+ yrs of wear and tear, + unexpected usage could quite easily = unforeseen failure. Meanwhile, the engineers who are designing the billet CNC or fabricated uprights are also designing, for the same parts makers, the correction tie rod ends. And they are designing and building these with motorsport (or, at the very least, the meth addled antics of drifters) in mind. So I would hope (in fact, I would expect) that their design work included the offset of that steering force. Doesn't mean that it is not totally valid to ask the question of them, before committing $$.
    • The downside of this is when you try to track the car, as soon as you hit ABS you get introduced to a unbled system. I want to avoid this. I do not want to bleed/flush/jack up the car twice just to bleed the f**kin car.
