Baysidebluebnr34 Posted February 10, 2006 Share Posted February 10, 2006 just wanted to get so thoughts on air filters, I have a gtr and I am thinking about changing to a k&n pannel or pod filters, but want to know if there is any point to change to pods instead of just a k&n panel? Link to comment https://www.sau.com.au/forums/topic/105309-stock-air-box-vs-penel-filter-vs-pod-filter/ Share on other sites More sharing options...
TurboX Posted February 10, 2006 Share Posted February 10, 2006 The K&N will get you more air flow.. The Pods will get you defect grief... Link to comment https://www.sau.com.au/forums/topic/105309-stock-air-box-vs-penel-filter-vs-pod-filter/#findComment-1939991 Share on other sites More sharing options...
joe2548 Posted February 12, 2006 Share Posted February 12, 2006 in victoria pod filters are legal. pods make a cool sucking sound(if u like that kinda stuff) but most of them have very coarse elements and let to much dust in if u ask me. do u want to wear ur engine for the sake of 2hp? go the k&n panel filter. Link to comment https://www.sau.com.au/forums/topic/105309-stock-air-box-vs-penel-filter-vs-pod-filter/#findComment-1943055 Share on other sites More sharing options...
RB30-POWER Posted February 12, 2006 Share Posted February 12, 2006 The Mines machine runs airbox. Surely no one can argue with that. Link to comment https://www.sau.com.au/forums/topic/105309-stock-air-box-vs-penel-filter-vs-pod-filter/#findComment-1943250 Share on other sites More sharing options...
MADGT4 Posted February 12, 2006 Share Posted February 12, 2006 The Mines machine runs airbox.Surely no one can argue with that. <{POST_SNAPBACK}> I love that! So true! I'm about to upgrade alot of components in the engine and i think i may be switching back to stock air box! Link to comment https://www.sau.com.au/forums/topic/105309-stock-air-box-vs-penel-filter-vs-pod-filter/#findComment-1943350 Share on other sites More sharing options...
TTT Posted February 13, 2006 Share Posted February 13, 2006 search for "piper cross" filters have a read Link to comment https://www.sau.com.au/forums/topic/105309-stock-air-box-vs-penel-filter-vs-pod-filter/#findComment-1944231 Share on other sites More sharing options...
maccattack Posted February 13, 2006 Share Posted February 13, 2006 Have a look at the ARC Super Induction Box. Draws air like a pod but should avoid being defected due to its design. I run one in my GTR. It actually has two intake panels - on top and on the side. All alloy construction with replaceable filters. Worth a look Link to comment https://www.sau.com.au/forums/topic/105309-stock-air-box-vs-penel-filter-vs-pod-filter/#findComment-1944410 Share on other sites More sharing options...
N1GTR Posted February 13, 2006 Share Posted February 13, 2006 I can vouch for the ARC box, i pulled my pods of and replaced with the ARC box - no noticable power loss at all Link to comment https://www.sau.com.au/forums/topic/105309-stock-air-box-vs-penel-filter-vs-pod-filter/#findComment-1944558 Share on other sites More sharing options...
benm Posted February 13, 2006 Share Posted February 13, 2006 The ARC box does look cool and efficient however its also around $500 which is abit rich if you ask me. I'm still not sure if I should convert back to the std airbox or get a custom made enclosure. Does anyone happen to have a pic of a std R32 GTR airbox? Link to comment https://www.sau.com.au/forums/topic/105309-stock-air-box-vs-penel-filter-vs-pod-filter/#findComment-1944619 Share on other sites More sharing options...
BAILED Posted February 13, 2006 Share Posted February 13, 2006 Can you buy panel filters that make good induction noise ? Link to comment https://www.sau.com.au/forums/topic/105309-stock-air-box-vs-penel-filter-vs-pod-filter/#findComment-1944817 Share on other sites More sharing options...
ferni Posted February 13, 2006 Share Posted February 13, 2006 its not the filter that make noise, its the fact that they are in a box so you don't hear the sucking, its sucking from the front of the car, not in the engine bay. Link to comment https://www.sau.com.au/forums/topic/105309-stock-air-box-vs-penel-filter-vs-pod-filter/#findComment-1944946 Share on other sites More sharing options...
rev210 Posted February 13, 2006 Share Posted February 13, 2006 I went from pods (heat sheilded), back to the factory airbox with K&N panel. The air pick up at the front bar means 'rammed' air at speed keeps the box closer to a positive air pressure which reduces the resistance to flow. The factory airbox's chamber volume could be improved however for higher horsepower. The ARC airbox ; where does the air get draw in from as it looks to me like it might still suck in hot engine bay air? Link to comment https://www.sau.com.au/forums/topic/105309-stock-air-box-vs-penel-filter-vs-pod-filter/#findComment-1944955 Share on other sites More sharing options...
Baysidebluebnr34 Posted February 13, 2006 Author Share Posted February 13, 2006 I have decided to keep the standard air box and put a k&n filter in. I had the box out the other day and discovered there is two inlets, one on top and one on the side. The one on the side is blocked of from the factory but the bung can be removed easy( this one draws cold air from inside the fender) this also helps with the induction noise and you can hear the standard blow off valves. Link to comment https://www.sau.com.au/forums/topic/105309-stock-air-box-vs-penel-filter-vs-pod-filter/#findComment-1944972 Share on other sites More sharing options...
N1GTR Posted February 13, 2006 Share Posted February 13, 2006 I bought both a standard box with a nismo filter (thanks tosh) and an arc box, settled for arc box, so after having each of the 3 options i chose arc box Benm : at the next cruise you can inspect one if you want, its currently in my mates silver r32 Link to comment https://www.sau.com.au/forums/topic/105309-stock-air-box-vs-penel-filter-vs-pod-filter/#findComment-1945060 Share on other sites More sharing options...
Wazz Posted February 13, 2006 Share Posted February 13, 2006 2 hp? haha i wanna see someone do a before and after dyno test on this.. if i can find somone with a gtr with stock airbox i'll do test stock airbox vs apexi bolt ons i'd go with apexi bolt on kit for gtr if i were you.. Link to comment https://www.sau.com.au/forums/topic/105309-stock-air-box-vs-penel-filter-vs-pod-filter/#findComment-1946580 Share on other sites More sharing options...
rev210 Posted February 13, 2006 Share Posted February 13, 2006 Air filter is a seriously small horsepower improvement. The fact that you gain anything on a dyno is soemtimes negated when you dyno/test with the bonnet 'down' as you always ought to. The airflow characteristics at speed are often quite different to the dyno booth. Link to comment https://www.sau.com.au/forums/topic/105309-stock-air-box-vs-penel-filter-vs-pod-filter/#findComment-1947044 Share on other sites More sharing options...
cuando Posted February 14, 2006 Share Posted February 14, 2006 If you have an NA car do you get induction noise if you have a podfilter? I was thinking about putting one in with a heat shield but dont want any annoying noise. Link to comment https://www.sau.com.au/forums/topic/105309-stock-air-box-vs-penel-filter-vs-pod-filter/#findComment-1947283 Share on other sites More sharing options...
Tangles Posted February 14, 2006 Share Posted February 14, 2006 ARC boxes come up all the time on ebay - check weekly for a good price, direct from Japan. Nothing like $500, more like $200 delivered by memory. Link to comment https://www.sau.com.au/forums/topic/105309-stock-air-box-vs-penel-filter-vs-pod-filter/#findComment-1947390 Share on other sites More sharing options...
Xizor Posted February 14, 2006 Share Posted February 14, 2006 ARC boxes come up all the time on ebay - check weekly for a good price, direct from Japan. Nothing like $500, more like $200 delivered by memory. <{POST_SNAPBACK}> I've been looking and only keep seeing expensive american shit. Link to comment https://www.sau.com.au/forums/topic/105309-stock-air-box-vs-penel-filter-vs-pod-filter/#findComment-1949103 Share on other sites More sharing options...
BreathLess Posted February 14, 2006 Share Posted February 14, 2006 If you have an NA car do you get induction noise if you have a podfilter? I was thinking about putting one in with a heat shield but dont want any annoying noise. <{POST_SNAPBACK}> You do as i have a pod on my N/A but it runs through the intercooler holes in the car out to the front just behind the front bumper. Dont know if that makes a differences. Link to comment https://www.sau.com.au/forums/topic/105309-stock-air-box-vs-penel-filter-vs-pod-filter/#findComment-1949120 Share on other sites More sharing options...
