Does anybody know if the Nismo Keys that are gettin around fit a Stagea?
I asked Nengun, and they said they don't think it will cos the Stagea is similar to the ER34, not a definate answer so i thought someone on here would know for sure.
https://www.sau.com.au/forums/topic/105382-nismo-key/
I've got a nismo key (blank) that l'm using for my other car, which supposedly fits most skyline's, so l'd be under the assumption it would be fine, as l can't see there being much difference between the stagea key barrell & the R33's.
https://www.sau.com.au/forums/topic/105382-nismo-key/#findComment-1943407
Also, make sure whoever cuts it does a good job, as obviously replacing it will be a rather more expensive proposition!!!
I'd probably take it to a keycutter rather than your local hardware store who might cut maybe 2-3 keys a week...
It's not like you've just shelled out for a key that you could have bought directly from the cutter for $2 (or whatever a blank key costs nowadays).
https://www.sau.com.au/forums/topic/105382-nismo-key/#findComment-1947889
Thats exactly what i'll be doing, they should be able to use the number off my original key, and punch it out on the nismo key, i've had that done before.
Much more acurrate than cutting with the grinder when they copy a key.
https://www.sau.com.au/forums/topic/105382-nismo-key/#findComment-1949680
Mines still got the numbers on it ;)
Oh by the way, i emailed Greenline and they have confirmed that the Nismo key, that they and Nengun sell will fit the series 1 stagea, don't know about the series 2 though.
https://www.sau.com.au/forums/topic/105382-nismo-key/#findComment-1963379
on the subject of keys, does anyone know how to program the chip in the key hob to enable remote locking?
i cut a blank nissan key to match the original for a spare. the hob of the key has 2 buttons: lock & unlock.
the newly cut key starts the engine fine (i was suprised!) and now I want to know how to program the chip in the key hob so remote locking works.
sometimes there is a bizarre sequence of actions like insert & remove key 5 times in 10 secs, open/shut door etc.
any suggestions?
https://www.sau.com.au/forums/topic/105382-nismo-key/#findComment-1973013
My cousin had a key programmed for her N16 Pulsar, can't remember where she bought it, but had it programmed by a Nissan dealer.
It might be an idea to ring your local dealer and see if they can do it, surely the sequence can't be too different between models.
Also, I believe there are some places who cut keys who are also able to do the programming for you, if you still can't manage to find the sequence or process to do it yourself.
https://www.sau.com.au/forums/topic/105382-nismo-key/#findComment-1973084
i only got one key with my car, and for some reason it's bent. it still starts the car, but i doubt i could get a key cut for it. some genious has ground off the numbers on the key as well.
to get a key cut fresh, i'm assuming i'll need to take the car to a dealer or locksmith for them to get a number off the ignition barrel?
https://www.sau.com.au/forums/topic/105382-nismo-key/#findComment-1973482
Cool, interesting reading chook! Wonder if it works with aftermarket ECU's, eg PowerFC?
Meh still, when I got my Mongoose alarm hooked up, it disabled the key door lock/unlock from working, good thing I got two alarm keyrings :)
https://www.sau.com.au/forums/topic/105382-nismo-key/#findComment-1973580
Please note that size 10 keys have been discontinued.
Only some places still have the item in stock.
https://www.sau.com.au/forums/topic/105382-nismo-key/#findComment-1974442
  • 2 months later...
Its amazing what u find out about Stageas.
Only today i asked my local M10 for a spare key they said they could cut.
Now i've read this. Hmmmmm! The numbers have been ground off the only key supplied.
This whole Forum is getting like the X Files!
https://www.sau.com.au/forums/topic/105382-nismo-key/#findComment-2121576
    • Nah, OEM washer bottle and brake fluid reservoirs are fine I don't know what it is with the plastic that Mazda used, some plastics, like the washer bottle and brake fluid res are fine, and still look new after 20 years use, where as the coolant expansion tank, and PS reservoir, that I replaced with new OEM items when I first got the car, turned yellow and started getting brittle a few years later If the dirty yellow stained plastics didn't trigger me there wouldn't be an issue, but they did, much like the battery bracket....... Meh As for going back to work full time to support car stuff, nope, why, because I own a Mazda NC MX5, not a Nissan R series Skyline 🤣
    • I've never heard of CJ-motor, so can't advise you on them. I'd just go straight to GCG for a GCG highflow though. Seems no point to use a middleman. I'm somewhat surprised that the price on the CJ site is lower than the GCG retail price. Even though CJ would get a discount of some sort, you would hardly expect them to give up so much margin. Maybe the price is out of date? Having said that "I'd go to GCG"...when I did my highflow, I went to Hypergear. I did this https://hypergearturbos.com/product/rb25dethighflow/#tab-dyno-results with the R34 OP6 450HP profile. With the BB centre (extra $400) and intially with the standard boost actuator, but I eventually got him to send me the high pressure one when I got to the point of being able to actually use it. Ends up costing the same sort of money as the GCG highflow, but this is, of course, the turbo that I KNOW has a shorter length core and so moves the comp cover rearwards. The GCG apparently doesn't do that. My mechanic also swears by the GCG highflow, given that we have another turbo rebuilder who does something essentialy the same as theirs, using Garrett wheels. He says it stands up at really low revs and makes good power. I haven't pushed my HG highflow past ~240-250rwkW yet (should have a little more in it, but unclear how much) and it does have a fairly gentle boost ramp. OK, it's much better now that I have gotten my boost controller tuned up on it.  A lot of my earlier unhappiness was because I couldn't keep the wastegate flap as closed as it needed to be (including some mechanical issues). I'd still prefer it to boost up nearly as quickly as the stocker, and it certainly a bit slower than that. So maybe the GCG one is worth the first look (for you).
    • Ok thanks 🙂 I will higly consider this. Any "known" company for a good reviews and experience to send that off? Is that CJ-motor good one? Or go straight to GCG site? I need to use VPN to even find some of those "shops" let alone access them 🙂
    • You can literally put in as much WMI as it takes to quench the combustion totally (and then back it off a little, obviously), and it will keep making more and more power. The power comes from the cooling effect of the water (and the meth) and the extra fuel (the meth, which also has massive octane). It is effectively exactly like running E85. One might be slightly better than the other, but they are damn close. But with either you can lean on the boost or the timing (or both) waaaay more than with just petrol and the results are similar. Here's the first thing I googled for an anecdotal bit of evidence. Can't access the attachment without being a gold member, but it is there for the getting if able to, or searched up elsewise perhaps. https://www.hpacademy.com/forum/general-tuning-discussion/show/wmi-vs-e85/
    • Dang, those BBS are so nice!
