The motor is out finding things to do (RB30)
Light weigh pulleys
Are they worth it ? Has anyone gone down the path of changing them over
would like to hear your thoughts
also if any one knows if can buy them from anywhere (iam in melb)
or would i be better of going to some kind of metal shop with my old ones
and ask to turn them up, if so what kinda of metal/alloy would i bee looking at to get them mad off
Cheers
https://www.sau.com.au/forums/topic/106772-lightweight-pulleys/
Light weigh pulleys
Cheers
id only use them for looks,
but yer
alloy with holes in it like how the sr20's use (i.e URAS pullys etc)
that way they are mega light
Light weigh pulleys
Cheers
As mentioned you don't change the crank pulley.
However yes they are worth it.
Reduced inertia is always worth the bother when it comes to the pulleys. It gives increases in the 'response' of the motor. The trust set I have reduced the pulley setups weight by around 2kg. The switching over to an electric thermo fan (thermo switched) reduces this by another kilo or two as well. After that you have a gain similar to a lightweight flywheel in basic inertia reduction.
What does reduced inertia give you?
No horsepower gains as such, but even better a gain in accelleration. A reduced time taken to reach rpm in any given gear.
Reducing inertia is the smart path to reliable speed. It doesn't increase wear on anything unlike horsepower increases. For that reason paying a little more for an accelleration gain up front is worth it because you DONT KEEP PAYING FOR IT.
Most people don't understand this or have more often than not have never been told.
while I'm on the topic I have a good idea that a $2,000 carbon fibre tail shaft makes for rather good value for money when you consider you are saving fuel ,contributing less wear and require no extra supporting mods to go significantly faster 0-100kmh.
Once I get round to installing one I will time it on the dyno for those who's brains can't concieve of anything other than what their mates tell them about how to make a car go quicker.
Ok so reducing the inertia by lightening the pulleys is a good thing.
By underdriving the gearing is going to improve the response further, possible slight power increase?
So, doing the above is in turn going to reduce load on the engine correct?
Just thinking aloud but load is what helps a turbo spool, so would reducing the load and getting the increase in acceleration speed be offset by a later spooling turbo as load has been reduced?
I love this topic. Any way to reduce roational inertia will increase acceleration of the enigne and acceleration on the raod. Increase in acceleration of the engine means that additional timing can be added which increases torque. And as for turbo engines it doesn't matter if your reducing the load on the motor becuase it will be offeset by the addition exhaust gas flow due to the quicker reving motor.
And as was said earlier never remove a harmonic balancer on a motor that was designed to use one, unless you want to twist you crank.
excellant topic.. as for the pulleys i have them on my rb26 in my s13 cost me 300 bux for the set how ever you might have to be a bit carfull seeing as there goin on a rb30.. find out which rb20 or 25 has the same size pulleys because rb26 to rb20/25 have different size pulleys especialy water pump pulley
You are contradicting yourself there...just a little though. Yes, lightening things that turn, reduces inertia in the torsional axis, and you say that this won't lead to an increase in horsepower, which it won't as everyone knows, you can't create energy. You say that the car will accelerate faster...which it will, but it is impossible for the car to accelerate faster without having more power.
Accerlerating something that turns requires a certain amount of torque, for a certain amount of time (A certain amount of power) Just like accellerating something in the linear plane requires a certain amount of force for a certain amount of time.
When rotating parts are lighter, less torque is needed for less time to accelerate to the same RPM. (IE less power). So, you are consuming less power to accelerate rotating parts, you have more energy in a given second (power) to use to accelerate the car in the linear plane.
IE, you are putting more power down to the road OR the dyno. So...the power 'gain' should be able to be measured on the dyno.
Looking at it anohter way...if you think about how a dyno works, it lets the engine accelerate in RPM a certain number of RPM per second. The dyno then measures how much torque it needs to hold the engine at this rate of acceleration. Power is then calculated. So, if the car is going to accelerate faster, the increase in power will show on the dyno.
Also, a lightweight carbon prop shaft that saves say 10kg, will make no where near as much difference as a lightened flywheel that saves 5kg.
The reason is the steel prop shaft's moment of inertia is much lower than that of a the flywheel. IE. The average mass of the prop shaft is much closer to the axis of rotation than it is for the flywheel.
The lower the moment of inertia, the less torque is needed per second to accelerate the mass to a given RPM. I can’t remember the exact relationship, but it would be a square law. I could dig it out a of an old physics textbook if I could be bothered.
You can test this by rolling a ball bearing, a shot put and a steel pipe down a hill. All else being equal, the ball bearing and the shot put should reach the bottom at the same time. The pipe should arrive last, because it has the highest moment of inertia, meaning more energy is wasted accelerating the pipe in the torsional axis.
Mik,
Accellerate without more power you are saying no?
I think there is a little confusion here. Mass is a part of the equation. If we lessen the mass and apply the same power to it's accelleration it takes place faster.If the same engery is used and 'conserved' in the equation when mass is reduced,
accelleration (over a delta T ---- remember it's meters per second per second)
or velocity (moment-------meters per second) is increased to give the same value in a blunt expression. Variations of this sum occur according to round and round or linear motion but, pretty much thats what happens.
Tailshafts are hollow too, this means the outer edge contains the mass, the middle is air. Then there is the twisting forces on them which the flywheel doesn't have to cope with etc....
Propshaft wise it seems that there is more complicated equations involved than the simple approach we would taken. To save headaches on this thread I suggest that you email the guys at www.acpt.com they are the aerospace company that make the shafts for Mines and others.
All I can comment on is the experience I have had over the years making bits lighter and going faster as a result. The fact that people have trouble 'getting it' has meant I end up going quicker often in the same vehicle with less money spent and less power. Like people really ought to consider 'learning how to drive your car' as a mod of great value for money. This approach may have an up front cost but, it's free thereafter.
Extra power always costs you more for every second you use it.
    • For these last 7 years of ownership, I've always had to use a small scissor jack under one of the front tow hooks to raise the front just enough so my low-profile jack fits under to reach my subframe jack point. I'm beginning to get annoyed of always having to do this. Are there any lower low-profile jacks that fit under the gtr lip on a dropped car?
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
