The motor is out finding things to do (RB30)
Light weigh pulleys
Are they worth it ? Has anyone gone down the path of changing them over
would like to hear your thoughts
also if any one knows if can buy them from anywhere (iam in melb)
or would i be better of going to some kind of metal shop with my old ones
and ask to turn them up, if so what kinda of metal/alloy would i bee looking at to get them mad off
Cheers
https://www.sau.com.au/forums/topic/106772-lightweight-pulleys/
Light weigh pulleys
Cheers
id only use them for looks,
but yer
alloy with holes in it like how the sr20's use (i.e URAS pullys etc)
that way they are mega light
Light weigh pulleys
Cheers
As mentioned you don't change the crank pulley.
However yes they are worth it.
Reduced inertia is always worth the bother when it comes to the pulleys. It gives increases in the 'response' of the motor. The trust set I have reduced the pulley setups weight by around 2kg. The switching over to an electric thermo fan (thermo switched) reduces this by another kilo or two as well. After that you have a gain similar to a lightweight flywheel in basic inertia reduction.
What does reduced inertia give you?
No horsepower gains as such, but even better a gain in accelleration. A reduced time taken to reach rpm in any given gear.
Reducing inertia is the smart path to reliable speed. It doesn't increase wear on anything unlike horsepower increases. For that reason paying a little more for an accelleration gain up front is worth it because you DONT KEEP PAYING FOR IT.
Most people don't understand this or have more often than not have never been told.
while I'm on the topic I have a good idea that a $2,000 carbon fibre tail shaft makes for rather good value for money when you consider you are saving fuel ,contributing less wear and require no extra supporting mods to go significantly faster 0-100kmh.
Once I get round to installing one I will time it on the dyno for those who's brains can't concieve of anything other than what their mates tell them about how to make a car go quicker.
Ok so reducing the inertia by lightening the pulleys is a good thing.
By underdriving the gearing is going to improve the response further, possible slight power increase?
So, doing the above is in turn going to reduce load on the engine correct?
Just thinking aloud but load is what helps a turbo spool, so would reducing the load and getting the increase in acceleration speed be offset by a later spooling turbo as load has been reduced?
I love this topic. Any way to reduce roational inertia will increase acceleration of the enigne and acceleration on the raod. Increase in acceleration of the engine means that additional timing can be added which increases torque. And as for turbo engines it doesn't matter if your reducing the load on the motor becuase it will be offeset by the addition exhaust gas flow due to the quicker reving motor.
And as was said earlier never remove a harmonic balancer on a motor that was designed to use one, unless you want to twist you crank.
excellant topic.. as for the pulleys i have them on my rb26 in my s13 cost me 300 bux for the set how ever you might have to be a bit carfull seeing as there goin on a rb30.. find out which rb20 or 25 has the same size pulleys because rb26 to rb20/25 have different size pulleys especialy water pump pulley
You are contradicting yourself there...just a little though. Yes, lightening things that turn, reduces inertia in the torsional axis, and you say that this won't lead to an increase in horsepower, which it won't as everyone knows, you can't create energy. You say that the car will accelerate faster...which it will, but it is impossible for the car to accelerate faster without having more power.
Accerlerating something that turns requires a certain amount of torque, for a certain amount of time (A certain amount of power) Just like accellerating something in the linear plane requires a certain amount of force for a certain amount of time.
When rotating parts are lighter, less torque is needed for less time to accelerate to the same RPM. (IE less power). So, you are consuming less power to accelerate rotating parts, you have more energy in a given second (power) to use to accelerate the car in the linear plane.
IE, you are putting more power down to the road OR the dyno. So...the power 'gain' should be able to be measured on the dyno.
Looking at it anohter way...if you think about how a dyno works, it lets the engine accelerate in RPM a certain number of RPM per second. The dyno then measures how much torque it needs to hold the engine at this rate of acceleration. Power is then calculated. So, if the car is going to accelerate faster, the increase in power will show on the dyno.
Also, a lightweight carbon prop shaft that saves say 10kg, will make no where near as much difference as a lightened flywheel that saves 5kg.
The reason is the steel prop shaft's moment of inertia is much lower than that of a the flywheel. IE. The average mass of the prop shaft is much closer to the axis of rotation than it is for the flywheel.
The lower the moment of inertia, the less torque is needed per second to accelerate the mass to a given RPM. I can’t remember the exact relationship, but it would be a square law. I could dig it out a of an old physics textbook if I could be bothered.
You can test this by rolling a ball bearing, a shot put and a steel pipe down a hill. All else being equal, the ball bearing and the shot put should reach the bottom at the same time. The pipe should arrive last, because it has the highest moment of inertia, meaning more energy is wasted accelerating the pipe in the torsional axis.
Mik,
Accellerate without more power you are saying no?
I think there is a little confusion here. Mass is a part of the equation. If we lessen the mass and apply the same power to it's accelleration it takes place faster.If the same engery is used and 'conserved' in the equation when mass is reduced,
accelleration (over a delta T ---- remember it's meters per second per second)
or velocity (moment-------meters per second) is increased to give the same value in a blunt expression. Variations of this sum occur according to round and round or linear motion but, pretty much thats what happens.
Tailshafts are hollow too, this means the outer edge contains the mass, the middle is air. Then there is the twisting forces on them which the flywheel doesn't have to cope with etc....
Propshaft wise it seems that there is more complicated equations involved than the simple approach we would taken. To save headaches on this thread I suggest that you email the guys at www.acpt.com they are the aerospace company that make the shafts for Mines and others.
All I can comment on is the experience I have had over the years making bits lighter and going faster as a result. The fact that people have trouble 'getting it' has meant I end up going quicker often in the same vehicle with less money spent and less power. Like people really ought to consider 'learning how to drive your car' as a mod of great value for money. This approach may have an up front cost but, it's free thereafter.
Extra power always costs you more for every second you use it.
    • Update 3: Hi all It's been a while. Quite a lot of things happened in the meantime, among other things the car is (almost) back together and ready to be started again. Things that I fixed or changed: Full turbo removal, fitting back the OEM turbo oil hardlines. Had to do quite a bit of research and parts shopping to get every last piece that I need and make it work with the GT2860 turbos, but it does work and is not hard to do. Proves that the previous owner(s) just did not want to. While I was there I set the preload for the wastegates to 0,9bar to hopefully make it easier for the tuner to hit the 370hp I need for the legal inspections that will follow later on. Boost can always go up if necessary. Fitted a AN10 line from the catch can to the intake hose to make the catchcan and hopefully the cam covers a slight vacuum to have less restrictive oil returns from the head and not have mud build up as harshly in the lines and catch can. Removed the entire front interior just shy of the dashboard itself to clean up some of the absolutely horrendous wiring, (hopefully) fix the bumpy tacho and put in LED bulbs while I was there. Also put in bulbs where there was none before, like the airbag one. I also used that chance to remove the LED rpm gauge on the steering column, which was also wired in absolute horror show fashion. Moved the 4in1 Prosport gauge from sitting in front of the OEM oil pressure gauge to the center console vents, I used a 3D printed vent piece to hold that gauge there. The HKB steering wheel boss was likely on incorrectly as I sometimes noticed the indicator reset being uneven for left vs. right. In the meantime also installed an airbag delete resistor, as one should. Installed Cube Speed premium short shifter. Feels pretty nice, hope it'll work great too when I actually get to drive. Also put on a fancy Dragon Ball shift knob, cause why not. My buddy was kind enough to weld the rust hole in the back, it was basically rusted through in the lowermost corner of the passenger side trunk area where the wheel arch, trunk panel and rear quarter all meet. Obviously there is still a lot of crustiness in various areas but as long as it's not rusted out I'll just treat and isolate the corrosion and pretend it's not there. Also had to put down a new ground wire for the rear subframe as the original one was BARELY there. Probably a bit controversial depending on who you ask about this... but I ended up just covering the crack in the side of the engine block, the one above the oil feed, with JB Weld. I used a generous amount and roughed up the whole area with a Dremel before, so I hope this will hold the coolant where it should be for the foreseeable future. Did a cam cover gasket job as the half moons were a bit leaky, and there too one could see the people who worked on this car before me were absolute tools. The same half moons were probably used like 3 times without even cleaning the old RTV off. Dremeled out the inside of the flange where the turbine housing mates onto the exhaust manifolds so the diameter matches, as the OEM exhaust manifolds are even narrower than the turbine housings as we all know. Even if this doesn't do much, I had them out anyways, so can't harm. Ideally one would port-match both the turbo and the manifold to the gasket size but I really didn't feel up to disassembling the turbine housings. Wrapped turbo outlet dumps in heat wrap band. Will do the frontpipe again as well as now the oil leak which promted me to tear apart half the engine in the first place is hopefully fixed. Fitted an ATI super damper to get rid of the worn old harmonic balancer. Surely one of the easiest and most worth to do mods. But torquing that ARP bolt to spec was a bitch without being able to lock the flywheel. Did some minor adjustments in the ECU tables to change some things I didn't like, like the launch control that was ALWAYS active. Treated rusty spots and surface corrosion on places I could get to and on many spots under the car, not pretty or ideal but good enough for now. Removed the N1 rear spats and the carbon surrounding for the tailpipe to put them back on with new adhesive as the old one was lifting in many spots, not pretty. Took out the passenger rear lamp housing... what do you know. Amateur work screwed me again here as they were glued in hard and removing it took a lot of force, so I broke one of the housing bolts off. And when removing the adhesive from the chassis the paint came right off too. Thankfully all the damaged area won't be visible later, but whoever did the very limited bodywork on this car needs to have their limbs chopped off piece by piece.   Quite a list if I do say so myself, but a lot of time was spent just discovering new shit that is wrong with the car and finding a solution or parts to fix it. My last problem that I now have the headache of dealing with is that the exhaust studs on the turbo outlets are M10x1.25 threaded, but the previous owner already put on regular M10 nuts so the threads are... weird. I only found this out the hard way. So now I will just try if I can in any way fit the front pipe regardless, if not I'll have to redo the studs with the turbos installed. Lesson learned for the future: Redo ALL studs you put your hands on, especially if they are old and the previous owners were inept maniacs. Thanks for reading if you did, will update when the engine runs again. Hope nothing breaks or leaks and I can do a test drive.
    • No those pads are DBA too  but they have colors too. I look at the and imo the green "street" are the best.
    • I’m not sure what happened I told them about sonic tunes free OTS tune and the next the I know .. I was booted..   To funny
    • Yea - I mean I've seen my fuel pump which is decades old and uh, while I'm not saying this with real knowledge... but I sure get the ick at using anything in the fuel system that produced the state of that pump. Many years ago I went through multiple pumps (and strainers) before I dropped the tank to clean it out with extreme violence. I'm talking the car would do maybe 50km before coming to a halt, which resulted in me cleaning out the filter with some brake cleaner and going on my way. None of my stuff ever looked like what came out of your fuel tank. I don't think I'd be happy with it unless every single component was replaced (or at least checked/cleaned/confirmed to be clean here).
    • I'm not going to recommend an EBC pad. I don't like them. Just about anything else would suit me better. I've been using Intima pads for a while now.
