Hi ppls,
I am soon to rip the head off, replace valve springs, headgasket and oil restrictors.
I attempted to remove the oil restrictors out of a spare rb30e I have in the shed. I failed. :(
How are these removed? Is it possible to remove and install new without removal of the motor/sump?
I have seen other (non rb) blocks where the oil restrictor have a thread located in the top section of the restrictor, this allows easy removal.
:D
https://www.sau.com.au/forums/topic/107288-removal-of-block-oil-restrictors/
Hi ppls,
I attempted to remove the oil restrictors out of a spare rb30e I have in the shed. I failed. :)
Drill and tap.
Figured as much.
My main concern with drill and tap is leaving metal filings in the block.
I could grab a hoover or something as I drill or make an attachment to fit down the galley after its removed to suck out any possible filings but its always a worry.
Any suggestions?
Hopefully I don't have to report that engine failure Geoff. :)
I'm going to rip the ones out of the vl block and see how far I can push the old restrictors down. If the galley doesn't taper or do anything silly I will push the old ones down and simply drop the new ones on top.
While on the topic.. I've been told the RB26 Tomei headgasket kits from nengun come with the restrictors. RB25/rb20 doesn't. Yet they have similiar price.
Is this really the case or do the tomei restrictors have to be purchased seperately?
Either way I'll drop nengun an email and post back my findings.
Can you use a 26 gasket with a RB25DE head?
and the r32 rb26 head doesnt run vct either. oil/water galleries would be similar to r32 rb25de? Cylinder size is the same...
Solid lifters are always a bonus.....
Wonder if i should sell my fully rebuilt and ported head, and go the gtr head....? Depends...
This is where i am confused. I can get VG30DETT lifters for lsightly cheaper then what Tomei sell their kits for. It would be cool to run 260/10.25mm cams.
The theroy say that solid cams will make more power because they accelerate open/closed quicker, they are lighter etc. But the cost of doing it, only to have to shim/long term maintenance etc...well????
If i spend the same money on the combustion chamber and ports, and stuck with the 260/8.5mm cam ( a cheaper option),how much less power, if any, would it make????
Does having large lift cams hurt velocities/cylinder filling at low rpm like large duration cams???
oh, and this is on topic as ,umm, because when you run oil restrictors, ...well the hydraulic lifters also use oil :P
Hi all , correct me if I'm wrong but aren't the oil restrictors made of brass ? I seem to remember AJ removing one from an L series block by screwing a self taping screw into it and pulling it out with a slide hammer . I dont think the interference fit is real tight .
Cheers A .
I think this may answer some q's Roy.
http://www.overboost.com/story.asp?id=1132
Especially the 2nd to last paragraph, that says : Synchronizing lift with piston speed keeps airflow at optimal velocities through the ports
Awesome.
I'm a happy man. :P
I've since discovered the tomei restrictors are 1.5mm.
RB30 are 1.8mm
RB26 are 2mm
RB20/25 are 2.4mm
Thanks.
One last question... Does the rb26 tomei headgasket kitcome with 2 restrictors?
Running the hydraulic head I need to keep the two.
Awesome.
I'm a happy man. ;)
RB30 are 1.8mm
RB26 are 2mm
RB20/25 are 2.4mm
Thanks.
nope, they come with one. They are a very easy thing to make though.
No drama's... I am able to get my hands on another easy.
Proengines.. Whats your view on 2 x 1.5mm restrictors?
Obviously I won't hold you to anything you say as I doubt any one has actually tested, so its an unknown.
But technically speaking, does the hydraulics really need much more oil over its big brother solid?
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
    • -10 is plenty for running to an oil cooler. When you look at oil feeds, like power steering feeds, they're much smaller, and then just a larger hose size to move volume in less pressure. No need for -12. Even on the race cars, like Duncans, and endurance cars, most of them are all running -10 and everything works perfectly fine, temps are under control, and there's no restrictions.
    • Update: O2 sensor in my downpipe turned out to be faulty when I plugged in to the Haltech software. Was getting a "open circuit" warning. Tons of carbon buildup on it, probably from when I was running rich for a while before getting it corrected. Replaced with new unit and test drove again. The shuffle still happens, albeit far less now. I am not able to replicate it as reliably and it no longer happens at the same RPM levels as before. The only time I was able to hear it was in 5th going uphill and another time in 5th where there was no noticeable incline but applying more throttle first sped it up and then cleared it. Then once in 4th when I slightly lifted the throttle going over a bump but cleared right after. My understanding is that with the O2 sensor out, the ECU relies entirely on the MAP tune and isn't able to make its small adjustments based on the sensors reading. All in all, a big improvement, though not the silver bullet. Will try validating the actuators are set up correctly, and potentially setting up shop time to tune the boost controller on closed loop rather than the open loop it is set to now. Think if it's set up on closed loop to take the O2 reading, that should deal with these last bits. Will try to update again as I go.
    • More so GReddy oil relocation kits, sandwich plates, etc. all use 10AN fittings. And same, I've only used 10AN and my car sees track work (circuit, doing laps, not 10 sec squirt business).
