Guest Mashrock
Hey - someone put me onto this so I'll quickly answer.
The R34 boxes (getrag) are damn tuff as far as holding power goes. The main gears themselves are nice and strong.
What they suck at is the size of the locator teeth (don't know the real term) that you find between the gears and the shift drums.
If you are really unknind to the Getrags on the downshifts if you are doing track work then those tiny teeth break quite easily. Then you will not be able to get into that gear above 3,00rpm (its like killing a suynchro) I busted them twice in 6 months before learning to be nicer. Now that I know how to treat it propperly I haven't had an issue.
For reference both mine and troys cars are probably around 650HP. But I busted the gearboxes back when my car was about 450HP.
Also - as far as the boxes being the same as the Supra - yes the gears are the same but I think the input shafts are a different size. (I fixed my gearbox with Supra parts as Nissan don't sell them)
Cheers
reading this makes me feel so much better!!
have some love (L)
  • Replies 140
Posted Images
I ordered my Tomei 2.8 kit today.Dont have the funds to buy a complete Tomei built motor.I got the kit for $5950 which is a good price,the kit with the cooling channel in the pistons was $1200 more.
Getting my clutch rebuilt by Jim Berry,better start saving for an OS box I suppose.
Where are u getting the kit from??
What's included in the kit???
Billet crank,H beam rods with ARP bolts,forged pistons,rings.
I'm getting it through a shop in Melbourne.He is doing a great deal for me cause of all the business I've done with him.Not sure he wants me to post up his details,it may be a one off deal.I'll check with him tomorrow.Pretty sure he wants to be a sponsor,not that easy on SAU,he rips Nenguns prices.He can also get me Tomei H beam rods for $1490.
And I dont have to pay up front as he is a legitimate business,he doesnt use my money to buy the parts.
In regards to piston size,I'll let him know tomorrow.The motor is still being pulled apart.I wanted to avoid going this far as I was under the impression the motor had forged pistons.I was a bit shocked when I found out it had stock pistons,stock rods and crank and stock head gasket.It made 370rwkw at 1.5bar.I over revved it with a less than full sump,bearings in the sump.
I suppose at that power level and boost the motor would have let go sooner or later.HKS 2530's now for sale.LOL.
Edited by m&m
Tomei do not do a billet stroker crank...
Yeh,Iwas pretty sure they only did counterweight cranks with there stroker kits.His email to me says billet.I'll confirm with him tomorrow.Either way I'm getting the kit.
pm's replied Tommy and Jag
Edited by m&m
The Tomei RB28 kit comes with a forged semi counter crank that comes from the sae factory as the OEM Nissan one.
lots of unknown but in the rb28 dyno thread i have listed what i know about.
i need to get some split dumps, and i should be sorted.
will even do a test to see how much better they are.
comming soon!
just throw it on the dyno already! costs $50 and can tell us what a set of unknow internals, together with unknown cams and unknown turbos can do! lol. We've been hearing about the 580ps for over a year i for one am dying to see what this beast can do. :D
I posted the first 10 pages of 160 from the RB26DETT rebuild guide by nismo/tomei in my gallery..
There is a full on section in the back showing every step from when tomei receive your engine to when you get it back.. There is alot of steps and pages
Will take me along time to post it all so ill do in sections
Also the only mention of a tomei 2.8l is the kit, not the engine i dont think
But there is pages of stuff on the Tomei derive/genesis and how to tune with reytek, how to install poncams and camgears & Nismo's S1/R1 Engines
Plus a massive parts catalogue in the back with alot of stuff ive never seen on nengun/greenline or other parts places such as all the mines kits/tomei kits etc
yep it's the same book i have. the rebuild stuff is good, but the parts catalogue in the back is a bit out of date. i bought it whilst in japan back in jan 2004 and i think it was by no means a new release even then. awesome book though.
Guest Mashrock
soon rich :P
soon!!
waiting on a clutch from japaz now.
i hope by the end of the month!
i have a skid pan day comming up.
    • So I mentioned the apprentice, @LachyK helped take the bonnet off. We just undid the nuts on the hinges and unclipped the gas struts, then pulled the bonnet back a little as the front was catching on the front bar.  I had a good look at everything today and have removed the rams, repaired/reset the hinges and bolted it back together like it never happened. I'll do a separate write up on the repair, and I also removed the poppers from the Fuga today too to save grief down the road.....as said above it is at least $5k to repair retail. I'm also happier about my ability to prepare a race car, and less happy about Nis-nault's engineering (I can hear @GTSBoy sAfrican Americaning) because the top hose of the radiator didn't slip off.......it snapped clean off. By practice I put the hose clamp hard up against the flare on a neck to make it least likely to ever move (thanks @Neil!). I guess that puts a little more pressure on the end of the pipe as it is further away from the rad, but still, that is pretty shit. I've put it back on for now as there was a fair bit of neck still there, but obviously there is no lip on the neck any more so I don't think I'll track it again until I have a new rad. Speaking of which....more research required. It looks like Koyo makes a standard size radiator in ally which I'll grab in the meantime, but I really want something thicker so might have to go custom in the medium term (ouch) Coolant still needs a refill and I have the pressure tester on it over night, but other than a wash down of the engine bay it seems alright. And @MBS206 noted something noisy on the front of the engine and I think I agree....time for a new accessory belt and tensioners I think.
    • our good friends at nismo make a diff for it, I have one (and a spare housing to put the centre in) on the way. https://www.nismo.co.jp/products/web_catalogue/lsd/mechanical_lsd_v37.html AMS also make a helical one, but I prefer mechanical for track use in 2wd (I do run a quaife in the front, but not rear of the R32)
    • What are we supposed to be seeing in the photo of the steering angle sensor? The outer housing doesn't turn, right? All the action is on the inside. The real test here is whether or not your car has had the steering put back together by a butcher. When the steering is centred (and we're not caring about the wheel too much here, we're talking about the front wheels, parallel, facing front) then you should have an absolutely even number of turns from centre to left lock and centre to right lock. If there is any difference at all then perhaps the thing has been put back together wrongly, either the steering wheel put on one spline (or more!) off, and the alignment bodged to straighteb the wheel, or the opposite where something silly was done underneath and the wheel put back on crooked to compensate. Nut there isn't actually much evidence that you have such a problem anyway. It is something you can easily measure and test for to find out though. My money is still on the HICAS CU not driving the PS solenoid with the proper PWM signal required to lighten the load at lower speed. If it were me, I would be putting either a multimeter or oscilloscope onto the solenoid terminals and taking it for a drive, looking for the voltage to change. The PWM signal is 0v, 12V, 0V, 12v with ...obviously...modulated pulse width. You should see that as an average voltage somewhere between 0V and 12V, and it should vary with speed. An handheld oscilloscope would be the better tool for this, because they are definitely good enough but there's no telling if any cheap shit multimeter that people have lying around are good enough. You can also directly interfere with the solenoid. If you wire up a little voltage divider with variable resistor on it, and hook the PS solenoid direct to 12V through that, you can manually adjust the voltage to the solenoid and you should be able to make it go ligheter and heavier. If you cannot, then the problem is either the solenoid itself dead, or your description of the steering being "tight" (which I have just been assuming you mean "heavy") could be that you have a mechanical problem in the steering and there is heaps of resistance to movement.
    • Little update  I have shimmed the solenoid on the rack today following Keep it Reets video on YouTube. However my steering is still tight. I have this showing on Nisscan, my steering angle sensor was the closest to 0 degrees (I could get it to 0 degrees by small little tweaks, but the angle was way off centre? I can't figure this out for the life of me. I get no faults through Nisscan.
    • The BES920 is like the Toyota Camrys of coffee machines. E61 group head is cool, however the time requirements for home use makes it less desirable. The Toyota Camry coffee machine runs twin boilers and also PID temp control, some say it produces coffees as good as an E61 group head machine.
