Guest Mashrock
Hey - someone put me onto this so I'll quickly answer.
The R34 boxes (getrag) are damn tuff as far as holding power goes. The main gears themselves are nice and strong.
What they suck at is the size of the locator teeth (don't know the real term) that you find between the gears and the shift drums.
If you are really unknind to the Getrags on the downshifts if you are doing track work then those tiny teeth break quite easily. Then you will not be able to get into that gear above 3,00rpm (its like killing a suynchro) I busted them twice in 6 months before learning to be nicer. Now that I know how to treat it propperly I haven't had an issue.
For reference both mine and troys cars are probably around 650HP. But I busted the gearboxes back when my car was about 450HP.
Also - as far as the boxes being the same as the Supra - yes the gears are the same but I think the input shafts are a different size. (I fixed my gearbox with Supra parts as Nissan don't sell them)
Cheers
reading this makes me feel so much better!!
have some love (L)
  • Replies 140
Posted Images
I ordered my Tomei 2.8 kit today.Dont have the funds to buy a complete Tomei built motor.I got the kit for $5950 which is a good price,the kit with the cooling channel in the pistons was $1200 more.
Getting my clutch rebuilt by Jim Berry,better start saving for an OS box I suppose.
Where are u getting the kit from??
What's included in the kit???
Billet crank,H beam rods with ARP bolts,forged pistons,rings.
I'm getting it through a shop in Melbourne.He is doing a great deal for me cause of all the business I've done with him.Not sure he wants me to post up his details,it may be a one off deal.I'll check with him tomorrow.Pretty sure he wants to be a sponsor,not that easy on SAU,he rips Nenguns prices.He can also get me Tomei H beam rods for $1490.
And I dont have to pay up front as he is a legitimate business,he doesnt use my money to buy the parts.
In regards to piston size,I'll let him know tomorrow.The motor is still being pulled apart.I wanted to avoid going this far as I was under the impression the motor had forged pistons.I was a bit shocked when I found out it had stock pistons,stock rods and crank and stock head gasket.It made 370rwkw at 1.5bar.I over revved it with a less than full sump,bearings in the sump.
I suppose at that power level and boost the motor would have let go sooner or later.HKS 2530's now for sale.LOL.
Edited by m&m
Tomei do not do a billet stroker crank...
Yeh,Iwas pretty sure they only did counterweight cranks with there stroker kits.His email to me says billet.I'll confirm with him tomorrow.Either way I'm getting the kit.
pm's replied Tommy and Jag
Edited by m&m
The Tomei RB28 kit comes with a forged semi counter crank that comes from the sae factory as the OEM Nissan one.
lots of unknown but in the rb28 dyno thread i have listed what i know about.
i need to get some split dumps, and i should be sorted.
will even do a test to see how much better they are.
comming soon!
just throw it on the dyno already! costs $50 and can tell us what a set of unknow internals, together with unknown cams and unknown turbos can do! lol. We've been hearing about the 580ps for over a year i for one am dying to see what this beast can do. :D
I posted the first 10 pages of 160 from the RB26DETT rebuild guide by nismo/tomei in my gallery..
There is a full on section in the back showing every step from when tomei receive your engine to when you get it back.. There is alot of steps and pages
Will take me along time to post it all so ill do in sections
Also the only mention of a tomei 2.8l is the kit, not the engine i dont think
But there is pages of stuff on the Tomei derive/genesis and how to tune with reytek, how to install poncams and camgears & Nismo's S1/R1 Engines
Plus a massive parts catalogue in the back with alot of stuff ive never seen on nengun/greenline or other parts places such as all the mines kits/tomei kits etc
yep it's the same book i have. the rebuild stuff is good, but the parts catalogue in the back is a bit out of date. i bought it whilst in japan back in jan 2004 and i think it was by no means a new release even then. awesome book though.
Guest Mashrock
soon rich :P
soon!!
waiting on a clutch from japaz now.
i hope by the end of the month!
i have a skid pan day comming up.
    • Yeah well per the video it took 15s for the stock unit to start up....even if I give it a few seconds discount for starting that is at least 12 sec before you get a reverse camera if you are trying to leave a park.  The android unit is way faster, but 2016 for the stock unit is a long time ago in consumer electronics
    • Yea that’s why I said ima test them with multimeter and see the reads.
    • Only at idle. Isn’t a problem when rev it seems.
    • @Haggerty This seems silly to ask, but are you confident in your ability to tune the Haltech?
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
