Ok, upto the stage of my rebuild that involves giving things a bit of a colour infusion.
Bayside Blue's have been done to death on RB26's now... whilst its a good colour and would go perfect with my car... i dont wanna use it.
So, i need ideas for the plenum and rocker covers... bearing in mind that my car is Navy Blue so things like orange/red/yellow really dont work too well with it.
Anyone have any idea what colour should could look at?
Im stuck on this one :(
:sorcerer:
https://www.sau.com.au/forums/topic/108606-need-some-ideas/
  • Replies 47
Posted Images
Ash, Ash, Ash...
The colour of your covers should compliment and offset the colour of the car.
Purple Golgo with gold motor looked hawt. A midnight purple cover wouldn't have had the same impact.
Gayside blue wouldn't suit at all - too tonally wrong.
I ask this...
What colour are your calipers or other 'hilight' items on the car?
This would be a good colour to match.
Personally, I'd go with a deep red finish on your calipers and engine (similar to an R34 motor) - will stand out against the navy blue and even look good with the green stripe down the side from when you backed into your neighbour's car ;)
You might have a nice car yet.
https://www.sau.com.au/forums/topic/108606-need-some-ideas/#findComment-2000864
I reckon the Champain colour of the NUR spec 34's would look pretty hot
(light gold-almost silver)?
maybe the same mustang red as Al's R33?
or a very light (almost silver) metallic lime sort of colour...?
I'll look around for some colours to post so you know what I'm on about.
https://www.sau.com.au/forums/topic/108606-need-some-ideas/#findComment-2000903
Hmm... deep red actually, wouldnt look so bad now i think about it.
Although it wont match with the green rear 1/4 panel for long :D
Im changing brakes this year anyhow to AP's or similar, so for now i wont worry about colour-matching them.
Although some sorta silver has me thinking over it aswell.
Champagne colour, didnt think of that
Gotta decide by the end of the week too as the motor is nearing completion ;)
https://www.sau.com.au/forums/topic/108606-need-some-ideas/#findComment-2000953
Crikey Ash, two threads in such a short space of time that are both useful and are longer than 3 words, now I am lost for words!
Depends if the engine is going to be a focal point of the car, i.e the bonnet spending its days lifted at shows and not because the engine has caught fire. If so, use the engine as the base and use the rest of the body to pick details out. For example door strips/door handles/badges the corresponds with the engine. The red in James' pic is very nice and perhaps a shade even similar to Al's GTST. Metallic Morello Cherry is a personal fave but have no examples sadly. :D Look forward to seeing the finished product anyway. ;)
https://www.sau.com.au/forums/topic/108606-need-some-ideas/#findComment-2000960
Plan is to have the motor stand out from the engine bay itself.
Im not worried about "un-due" attention at all as the motor is essentially factory so ive got no worries with the law on that one... so it can be a little outlandish and it doesnt matter.
Being the car does attend shows once every so often and ive got some other "things" happening later on to compliment the "show" side of things.
https://www.sau.com.au/forums/topic/108606-need-some-ideas/#findComment-2001123
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
