  • Replies 46
Posted Images
I thought improved production rules stated that you can use any engine as long as the maker of the engine was the same as the maker of the car.
so it eligable?
No an R32 GTST is not eligible for IPRA.
The only grey imports legal for IPRA ar e R32 GTR and S13 Silvia.
To be eligible for IPRA, a car must be either:
1) Group A homologated
2) commercially available to the public in asutralia as new cars through a manufacturer's dealer network, or
3) otherwise recognised by CAMS...for group 3J
S13 silvia is the only grey import recognised by CAMS for IPRA http://www.cams.com.au/bulletins/B06-019%2...%20Vehicles.pdf. So an S13 chassis is allowed, but only with S13 silvia body. And only with CA18 and SR20 engines that were available in that model. Not permitted to run a 6cyl engine in that chassis, as the block must have the same number of cylinders/rotors as standard, and the same configuration of cylinders as the standard car (ie in-line, horizontally opposed).
S14 and S15 are eligible as they were sold here.
R32 GTST is not eligible. R32 GTR is group A homologated, and therefore OK.
No R33 or R34 is eliglible.
only allowed to use engines from eligible vehicles, so RB20 and RB25 variants are not allowed. No eligible vehicle had them. RB30 is OK, and cyl heads on approved blocks are free for early model vehicles. If you use a non-standard head or block in a late model vehicle, you must comply to minimum racing weights- ie 1602-2000cc (non turbo) 1045kg. turbo 1.8 or 2L 4cyl = 3001-4000cc 1285kg, but they must have the same number of cyl in the same config as the standard car- eg in-line 4cyl can only be replaced by another inline 4cyl engine from the same manufacturer.
1.4 Automobile make and model: Vehicles manufactured by the same company but under a different brand name are considered to be the same make, eg, Nissan/Datsun, Mazda/Eunos, Toyota/Lexus etc. Any component fitted to a production vehicle will be regarded as belonging to that manufacturer of that vehicle irrespective of the actual source of manufacture. Manufacturers are not considered to be the same solely by virtue of having a common parent or holding company. Model refers to a member of the same family of vehicle as produced by the manufacturer.
I've always interpreted this as "if the GTR is eligible, then so is the GTSt", as it is the same model as a GTR, ie R32, but a different spec. Although I could be misinterpreting it.
that's simply a definition of make and model, and you interpretation is correct, but that sentence does not make any make or model of vehicle eligible. You need to read the section on eligible vehicles. Eligibilty is granted on a per vehicle basis, not on a model family basis.
All models of Touring Cars with DOTAR's import approval are elligible for Improved Production. They are commercially available in Australia. To have you model included you just apply in writing to your State's elligibily officer. The list is updated continuously.
:whistling: Cheers :stupid:
PS; An R32GTST ran in the Improved Production Nationals last time they were in Tasmania, where they are again in 2006.
:O Cheers :devil:
from my previous post, which is directly out of the 3J regs in the CAMS manual:
2) commercially available to the public in australia as new cars through a manufacturer's dealer network
DOTARs doesn't count. You must be mistaken about seeing one compete at the nationals in Tas. Or maybe they didn't get a full grid and invited other categories to make up numbers?
the list of specially approved models is
1. Mitsubishi Mirage Cyborg (to cater for ex Mirage Cup cars)
2. Nissan Silvia S13 (turbo and naturally aspirated)
that's it
Edited by hrd-hr30
    • The cross sectional area of a circular hole scales with the square of diameter. So a 2mm diameter hole is 4x the area of a 1mm hole. Not double. The 1.7mm hole is nearly 3x the area of a 1mm hole. You do not need restrictors at both ends of the oil supply line. If you have new, additional restrictors at the turbo end, that you did not have before, then you do not need a restrictor at the inlet end.
    • Hi all. Been a while but things are moving along. I just have something that I am wondering about. Since I will use OEM turbo oil pumbing, I got myself a new bolt, the one that goes into the engine block oil feed. As I recall (and see visually) this bolt comes restricted with I think a 1.7mm hole? Not quite sure but it was something around that size. The turbos have 1mm restrictor bolts installed, as necessary due to ball bearings and my higher oil pressures. Can I now just use that OEM bolt with the 1.7mm hole in for the engine block or will this actually be too much oil flow restriction and I have to drill it out first? In my head it would make sense for the bolt to be at least 2mm wide as both turbos take "1mm of oil flow". Do let me know if my logic is flawed here, I just want to make sure I don't kill my turbo bearings with too little oil. Don't know if I can trust the saying I read somewhere that ball bearing turbos essentially only need an oil mist
    • There are several aftermarket options available, from not-too-painful moneyhttps://justjap.com/collections/driveshafts-bearings/products/d-max-reinforced-replacement-rear-driveshaft-set-fits-nissan-s13-s14-s15-r32-r33-r34-c35 and  https://justjap.com/products/crank-motorsport-billet-rear-axles-fits-nissan-skyline-r33-gts-t-r34-gt-t?srsltid=AfmBOorQk4xkGUa98kO7v2ePLUiNt-HRrM2AwWNw9mbSIVE1ujBVwY__, all the way up to The Driveshaft Shop https://driveshaftshop.com/skyline-cv-axles/
    • Yeah based on old XRC5964S specs, it looks to be roughly GTX3576R sized? But this 5964S compressor will flow 90lb airflow somewhat similar to the compressors in both the GTX3584RS or G35-1050.. I fully expected the 0.64 rear A/R to choke up top - seems way too small from typical convention - but these are seemingly beneficial over the prior 0.82 results.. Be interesting to see if he comments on the EFR question in that thread - he mentioned in a prior video that BW EFR's were the "cats pajamas 10 years ago", but by the sounds of things all his kits have been using Xona for quite a while now.
    • Yeah it’s still got the oem manual gearbox and clutch, only kinda mods are a blow off valve, coil overs, and a aftermarket intercooler. Also had it for about 2 months now with a lovely midnight purple paint on it.
