Hey guys, Considering how lame Thursday nights at the usual hot spots are becoming,, was wondering if anyone is interested in a SKYLINE only meet at toombul shops,,, maybe everyweek, maybe not.
but if anyone is interested in a sorta regular fortnightly meet then let us know..
Might be good to chat in person rather than on forums for a change..
anyway let us know.
each fortnight different location/activity depending on what people are interested in doing.
Edited by Silver_R34_GT-T
https://www.sau.com.au/forums/topic/108762-this-thursday-night-the-30th-march/
  • Replies 120
Posted Images
ok how about this, next thursday night, 16th, at toombul.. then on the days between thursdays, we all discuss new spots or cruises etc.. might make it more interesting...
anyway like i said, Thursday the 16th, meet under the rail at 8:30-9ish?
Someone bring a BBQ lol
anyway let us know.
Hey mate I often see you cruising round redcliffe. I drive the silver 33 gtst as in my photo. Seen you at kippa ring shops parked up under the covered car park. Have to say hi next time I see you.
But dont know how to get to the meet place from St Lucia. lol....
Go along Coronation Drive and turn left into Hale Street. Drive along the ICB until the Abbotsford Road turn-off. Take this turn off (this becomes Sandgate Road). Continue driving along Sandgate Road until you see the shopping centre on your right hand side.
Hope this helps :O
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
