its munted, if it boots again be ready to get all the files off it quick smart.
data recovery programs usually only work if the drive works, try booting using Heirin (sp?) it has tools to fix up all major brand hard drives, might get her up n running again
i have a few paper weights like ur drive
I used to work in a computer shop and we used to wrap the drive in newspaper and chuck it in the freezer for 15 minutes or so. This seemed to give them a limited life to do some last minute grabbing.
That trick is limited to only a few models. Basically Seagate and a couple others started using a cheaper substrate for the IC's. Only problem is, once the substrate warmed up to 60'c, it became conductive causing a huge short circuit inside the HDD controller. Putting it in the freezer would cool the chip long enough to transfer any data off and onto a new drive.
-D
Luke I wouldn't even bother trying to boot off it again, you might really stuff it.
Pull it out and stick it into a machine that already has a boot drive and operating system in it then drag files across.
+1 to this. Your drive may only have an issue with the partition table. If you run a scandisk on the HDD from another drive you can sometimes recover it. At the least you'll want to find out if there are any reported errors from the drive itself.
-D
-D
We use that trick as well
but the HDD in antistatic bags and leave it in the freezer over night
and surprise surprise you can get possibly 30-45minutes of proper activity happening and get most data off that
after the 3rd or 4th time the HDD will be just as good as being under a 10 tonne press lol
thats how we destroy our work HDD's b***hes
might just be the MBR, does it get past post at all? if so u could fix it useing the windows disk
if it booted it wouldnt be MBR. MBR either works or doesn't.
Corrupt file tables will cause sporadic boot failure as data is written in places where it shouldnt be, or data is read from corrupted blocks.
-D
^^^ I've got the Logitech Pro9000 web cam - inbuilt mic, HD quality and great for skype HD video calls. Also, has some novelty features that your kids will like eg. a character face overlay that mirrors your expressions and face tracking. But, for something cheaper the Logitech S7500 has similar features to the above except no auto focus and slightly lower mp camera.
hrmm....I really like the twin pack idea and price of the Swann but I also like the hi-res capabilities of the Logitech Pro9000 & Orbit (Sphere) models
My vote is with logitech, since I've been using them for a long time. Theyre rock solid
-D
EB Games are having a massive sale atm fyi. Many games and other items are 2 for $50.
I picked up Assassin's Creed and Crysis Warhead for a grand total of $50 yesterday. Bargain - especially since Assassin's Creed was still priced at $89.94 and Warhead at $49.95.
Now I say good bye to another large chunk of my rarely available free time :D
+1, I have two of these, one for home and the other for work / on the road.
Great unit, never had any issues, GOOD quality video, not like most cams I've seen.
Not cheap, but webcams seem to be an item where you do get what you pay for.
hey Chops we should do another beer with Andrew sometime.
thanks for all the responses guys, I've checked a few reviews and am definitely leaning towards the logitech (buy it once I suppose)....just have to decide whether to get the Pro9000 or Orbit (Sphere)
If anyone here uses steam, just be careful of someone with the username Mor.B.Z.Wojtaz // zagram mixa // and if you get sent a link to here http://newsteams.tk/ - DO NOT LOG IN, its a scam website to steal your steam details. A mate received a message from him saying he had won a free copy of left4dead and GTA4, and to claim log into that site, but hopefully everyone here is smart enough.
Also on a side note, Pete, how are those hard drives?
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
