SAUWA Cruise
This cruise will be a repeat of a very popular cruise that we ran last April. It will go through the Eastern Hills to Chittering and then Swan Valley and will end with a picnic at Lilac Hill Picnic spot. West Swan Road. Guildford
*** THIS WILL BE A LONG CRUISE ***
When: Sunday 19th of March
Where: BP Truck stop - On The corner of McDowell Street and Abernethy Road KEWDALE.
Time: 10am for a 10.30am Departure
There will be a raffle held
Tickets $2 each or 3 for $5
Prize: HP Photosmart 335 Photo Printer.
With a HP bt450 Bluetooth Wireless adapter included
- Courtesy of ITC
What to bring:
Full tank of fuel (Definate)
BBQ food and cooking utensils
Chair or picnic blanket
Drinks
Maps available on the day
T-Shirts and Stickers for sale on the day
Tshirts - $25 for members $35 non-members. Limited sizes available
Collared shirts $35 for members, $45 non-members. Limited sizes available.
SAUWA Stickers $5 each
  • Replies 111
Been a member for over a year now & haven't been able to make it to any event or meet anyone (cept Josh), I'll see if there is anything I can do with work tomorrow, but until then it's another one I'll miss. Dammit!!
Should be there....considering the track day is postponed it'll be a chance for a decent shakedown run :)
Don't have a clue where the locations are but what do you guys reckon would be the roundtrip km on this cruise??
Some good news, I organised the day off, I go to work on Tuesday instead so I get to come! :P Look forward to meeting some people from here too. If anyone from here that's NOR needs a ride let me know, probably want a navigator if it's as long as stated. :P
One other question, SAUWA stickers??!! $5 each aren't they? If possible I'll grab a few, only got 2 skylinesaustralia stickers on my spoiler, need to fly the sauwa flag too.
    • Fark what are the changes of that snapping like that, clean. Nek minnit, custom radiator goes in, with built in oil cooler like those discontinued PWR ones from yesterdeacades ago
    • I thought I'd do a write up on an auto transmission fluid change for a the nissan 7 speed Automatic. At some stage the genius engineers decided that the fluid in the trans was "for the life of the transmission", (which seems kind of self supporting to me) and removed the dip stick and fill tube (funnily enough there is still a casting for it). Anyway, for this job you do need 2 specialist tools in addition to regular hand tools, jack and good chassis stands. You need a way to pump fluid up to the transmission; I got one of these but there are plenty of other options: https://www.ebay.com.au/itm/364584087070 Don't trust the generic listing though, it does not come with the required adapter for the Nissan 7 Speed. You need one of these, can't do the job without it: https://navarapart.com.au/product/genuine-nissan-patrol-y62-d23-np300-navara-re7-dipstick-fill-connector1 You need a heap of compatible transmission oil. Could be Nissan, could be anything else rated for Nissan Matic S. You need at least 10 litres, I had 15 to give it a better flush... Also, you need some biiig oil catch trays, at least one of these, or bigger if possible (volume was fine, size was very marginal): https://autobarn.com.au/ab/Autobarn-Category/Tools-%26-Garage/Specialty-Tools/Oil-Service/Garage-Tough-Oil-Drain-Pan-Black-16L---GT1068/p/TO03191 Finally, a measuring jug is very useful if your pump does not have volumes marked on it, I got a 6l one: https://www.repco.com.au/oils-fluids/fluid-accessories/measuring-jugs/penrite-measuring-jug-6l-pmj006/p/A5322648 Oh, and gloves.....this stuff is horrible (not as bad as diff oil, but getting there) ....First, jack up your car.....
    • So I mentioned the apprentice, @LachyK helped take the bonnet off. We just undid the nuts on the hinges and unclipped the gas struts, then pulled the bonnet back a little as the front was catching on the front bar.  I had a good look at everything today and have removed the rams, repaired/reset the hinges and bolted it back together like it never happened. I'll do a separate write up on the repair, and I also removed the poppers from the Fuga today too to save grief down the road.....as said above it is at least $5k to repair retail. I'm also happier about my ability to prepare a race car, and less happy about Nis-nault's engineering (I can hear @GTSBoy sAfrican Americaning) because the top hose of the radiator didn't slip off.......it snapped clean off. By practice I put the hose clamp hard up against the flare on a neck to make it least likely to ever move (thanks @Neil!). I guess that puts a little more pressure on the end of the pipe as it is further away from the rad, but still, that is pretty shit. I've put it back on for now as there was a fair bit of neck still there, but obviously there is no lip on the neck any more so I don't think I'll track it again until I have a new rad. Speaking of which....more research required. It looks like Koyo makes a standard size radiator in ally which I'll grab in the meantime, but I really want something thicker so might have to go custom in the medium term (ouch) Coolant still needs a refill and I have the pressure tester on it over night, but other than a wash down of the engine bay it seems alright. And @MBS206 noted something noisy on the front of the engine and I think I agree....time for a new accessory belt and tensioners I think.
    • our good friends at nismo make a diff for it, I have one (and a spare housing to put the centre in) on the way. https://www.nismo.co.jp/products/web_catalogue/lsd/mechanical_lsd_v37.html AMS also make a helical one, but I prefer mechanical for track use in 2wd (I do run a quaife in the front, but not rear of the R32)
