i am gonna have to rebuild my bottom end wen i got the gts-4 it was all good now i have blow by and loosing oil preasure some one put a new head on the old block and the standard old ring couldnt handle the new spec and its ratshit now. so if i have to rebuild the block i think i am gonna go rb30 with my standard head as they should all match up i am told if i am gonna spend money i think i am gonna go all the way do it once and do it proply!!!!!!!!!!
https://www.sau.com.au/forums/topic/109166-3-litre-r32-gts-4/
I was under the impression you cant use the RB20 DET head on an RB30???
Considering my bottom end looks like its stuffed but the head and manifolds have so much work done it would be handy to just swap the head over onto the RB30 with the adapter awd plate.
Though that would increase the height of the motor which currently hits the hood air duct anyway ;-(
Ita a dilema as I have RB20 and RB30 NA Blocks in the shed.
The RB20's bore is considerably smaller than the RB25 / 26 / 30. Therefore the combustion chamber is considerably smaller (in both capacity and diameter). So the risk is that the pistons will be smashing into the rim of the combustion chamber every time they come up to TDC. And the compression ratio will probably become way to much for a turbo system.
Added to that, there are some alignment problems between oil galleries in the RB20 head and the RB30 block.
Just about every RB30DET uses a RB25DE(T) head - I am aware of only 1 successful RB20DET head transplant onto a RB30 block.
agreed... most RB30 builds these days are done using the Series 1 N/A RB25DE head, it also helps that this is a cheap and common part.
Good to see the number of GTS4's on the rise :P
Have a search for the DIY RB26/30 link for some good advice on this subject.
gts-4me - I would seriously sit down and put numbers to this plan of yours.
You haven't said what mods you have so I am going to assume you have the standard mods of, exhaust, filter, boost controller and fmic...
I'll give you some rough numbers on doing it on the cheap and doing it yourself.
my plan was to do a budget rb30det build for my gts4 and get about 280-300rwkw.
here is a small but crucial list.
$100 = rb30 bottom end
$750 = rb25de head from r32
$300 = valve springs from rb25det (used)
$250 = VRS Gasket kit
$300 = New bearings and new rings
$200 = New timing belt and pulley
$150 = New water pump
$300 = AFM (Z32 or Q45)
$300 = Fuel Pump
$600 = Decent clutch to handle the new torque
$300 = GTR injectors (6 x 444cc should be enough for the 280-300rwkw)
$1900 = GT30 (500hp internally gated turbo)
$450 = 4wd sump adapter
$500 = mods to the above sump adapter (not something you can really do yourself)
$1300 = R32 power fc
$500 = Tune
Now this is assuming you can do it all/most yourself.
as in, you have an engine stand, you have all the right tools and space to do it all.
if you don't and need someone to put all these things together, modify the engine mounts so the motor sits lower, bolt it all together, put it in car ... add another $1000 at least.
now, if you go easy on your stock GTS4 gearbox, it'll last for a while.
you break it??? buy a gtr one for about $1000, plus who knows what dollars for mods to fit it to standard diffs and shafts.
so lets see, what this new rb30det gts4 on the cheap costs.
$8200 = parts.
$1000 = someone putting it together and putting it in car
$1000 = gtr box
your other options..
build rb23 or 24 - probably a little cheaper than above as you use your bottom end and therefore don't need the 4wd adapter stuff. still... over $5K on parts and machining.
rb25 from stagea (4wd block) = engine alone is worth about $3500
putting it in, making it work, blah blah = $5K
rb26dett = $5K on average for the engine and you don't even know it's condition..
expensive cars to modify these things.. well at least to get good power out of..
i wouldnt suggest bolting a rb20 head straight onto a rb30 bottom end
i know a guy that did it.. using a old r31 skyline with its stock rb30 and auto.. simply bolted the rb20 head on ran all the rb20 stuff.. comp ratio worked out to be somewat around 11:1 which is well way to bloody high for a turbo motor and well.. it did pull a good skid.. full boost very very very early(stock rb20 turbo) and a couple months later it went bang not sure wat broke but yer it was sold to some young bloke before it died and died abou 2 months after the bloke bought it
you would be better off sourcing a rb25de head and doin everything gtst has said in above post
where do i get another rb20 for 600 bucks i just bought the rb30 and was gonna do the goods but i dont want to spend that dosh as my engine is lossing oil presure and has a wine at 1200 rpm and sounds like its coming from the 1st cam bearing (help)
It looks as if the GTR head in the gts4 is the way to go.
No issues with clearance and having to work out how to lower the motor.
If you can pick up a gtr head, inlet manifold, exh manifold with a set of stock turbo's it could be an easy and quick way to 250rwkw.
It also leaves open the option of picking up a set of well priced s/h 2530's and bolting them on, a little more fuel pressure and push those injectors. :cool:
The piston oil squirters.. ignore that, there are no issues. VLT's have been around for years and do not have problems, mine and many other rb30det's don't have problems either.
    • It would be well worth deciding where you want to go and what you care about. Reliability of everything in a 34 drops MASSIVELY above the 300kw mark. Keeping everything going great at beyond that value will cost ten times the $. Clutches become shit, gearboxes (and engines/bottom ends) become consumable, traction becomes crap. The good news is looking legalish/actually being legal is slighly under the 300kw mark. I would make the assumption you want to ditch the stock plenum too and want to go a front facing unit of some description due to the cross flow. Do the bends on a return flow hurt? Not really. A couple of bends do make a difference but not nearly as much in a forced induction situation. Add 1psi of boost to overcome it. Nobody has ever gone and done a track session monitoring IAT then done a different session on a different intercooler and monitored IAT to see the difference here. All of the benefits here are likely in the "My engine is a forged consumable that I drive once a year because it needs a rebuild every year which takes 9 months of the year to complete" territory. It would be well worth deciding where you want to go and what you care about with this car.
    • By "reverse flow", do you mean "return flow"? Being the IC having a return pipe back behind the bumper reo, or similar? If so... I am currently making ~250 rwkW on a Neo at ~17-18 psi. With a return flow. There's nothing to indicate that it is costing me a lot of power at this level, and I would be surprised if I could not push it harder. True, I have not measured pressure drop across it or IAT changes, but the car does not seem upset about it in any way. I won't be bothering to look into it unless it starts giving trouble or doesn't respond to boost increases when I next put it on the dyno. FWIW, it was tuned with the boost controller off, so achieving ~15-16 psi on the wastegate spring alone, and it is noticeably quicker with the boost controller on and yielding a couple of extra pounds. Hence why I think it is doing OK. So, no, I would not arbitrarily say that return flows are restrictive. Yes, they are certainly restrictive if you're aiming for higher power levels. But I also think that the happy place for a street car is <300 rwkW anyway, so I'm not going to be aiming for power levels that would require me to change the inlet pipework. My car looks very stock, even though everything is different. The turbo and inlet pipes all look stock and run in the stock locations, The airbox looks stock (apart from the inlet being opened up). The turbo looks stock, because it's in the stock location, is the stock housings and can't really be seen anyway. It makes enough power to be good to drive, but won't raise eyebrows if I ever f**k up enough for the cops to lift the bonnet.
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
