hey all,
just bought a Velo GP-90 race seat and need to get some custom rails for my s13. I was thinking of going to meridian motorsports, but just curious as to everyones experiences with different places, and what my best option may be.
If I could get rails from another manufacturer that fir that'd be ideal as it would save the hassle, does anyone happen to know if they anybody elses rails fit??
thanks in advance
Dane
https://www.sau.com.au/forums/topic/109553-custom-rails/
you should be able to get bride rails that bolt straight in for an s13.
or go a custom set up with generic rails.
either way it will cost more than the seat did :P
I've got some Bride bottom mount's at the moment, but this is a side mount type seat. I tested a VL type bride side mount rail today, and the Velo is about an inch too wide as it's an XL (XXL??) version
this is going to suck...
https://www.sau.com.au/forums/topic/109553-custom-rails/#findComment-2021936
you can try centreline suspension in thomastown, they put Roys seat in.. but I seem to remember it was a bitch of a seat to get in so I dont know if he scared them off doing it again :mad:
Thats the thing, they went to a lot of trouble and was happy that they did a good job, but the seating position wasnt that great, i couldnt reach the wheel, pedals and gearshift comfortably...and i sat too high.
They did good work, and would have perhaps been fien for another driver, but it didnt have the adjustability for me to get comfortable
https://www.sau.com.au/forums/topic/109553-custom-rails/#findComment-2022473
Dane, look at getting the Bride 'Low Max' seat rail for s13, got mine from RMS motorparts in Mitcham, they will bolt straight in and u can use universal side mounts to mount seat to rail....
Really??
That's really great to hear!! I'll go in and see Henry on saturday and see if I can trial fit the seat to it, and if it works I'llgrab one. Thanks for that Jack, you may just have made my day!
:mad:
https://www.sau.com.au/forums/topic/109553-custom-rails/#findComment-2022489
Really??
Dane, after many headaches and one custom rail fabricated which wasn't adjustable, the Bride rail was the perfect solution, wish I had bought it from the start, would have saved $300..... From memory the Bride rail cost $250, Henry is a top bloke and usually has a lot of stock....
Did u buy side mounts with the seat? If not stop by Revolution Race Gear (up the road from RMS) and buy some universal side mounts (around $70), and ur laughing...
Took me about an hour to mount the seat to the rail, as I had to get the right position, coz I'm short :mad: ...
Cheers,
Jack
P.S Coz ur a short prick like me you'll like how LOW the 'LOW MAX' rail sits, my head doesn't touch the roof even with a helmet on.....
https://www.sau.com.au/forums/topic/109553-custom-rails/#findComment-2022515
Cheers,
Jack
Cool, this sounds like it may solve my dramas as well. Where is this place?
https://www.sau.com.au/forums/topic/109553-custom-rails/#findComment-2022532
Took me about an hour to mount the seat to the rail, as I had to get the right position, coz I'm short :) ...
Cheers,
Jack
Yeah Henry's a great guy, I've bought a few things through him now and he always offers great service, and is really nice to boot
The seat only came with one sidemount (bought it second hand), so I'llpop into revolution before I go to RMS and pick up some side mounts.
This low max sounds the business! That's why I love the bride that I have now, as it sits me about an inch lower than the stock rails, just enough room for a helmet :mad:
Also, you wouldn't happen to know how wide the bottom of your seat is do you?? I've just measuredmine and it's about 470mm, which is why none of the bride side mount rails fit...
thanks Jack :(
Dane
https://www.sau.com.au/forums/topic/109553-custom-rails/#findComment-2022571
Dane, can't remember, but it's definetly wider than normal...
You wont have any probs, especially if u buy the RR side mounts....
Just make sure u got a drill, tape measure and marker to make sure u mount the seat straight..... Quite easy actually....
https://www.sau.com.au/forums/topic/109553-custom-rails/#findComment-2022617
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
