Queensland Wasteland
  • Replies 28.4k
  • chaos
    4853
  • BelGarion
    4045
  • GTS-t VSPEC
    2546
  • rb25
    2007
scott, brief summary of results of intake temp tests:
Ambient temp was 17deg.
cruising at 100km/h
pod=15deg
afm=15deg
engine bay=35
cruising in surfers, around 45km/h (heat soak set in and didnt get worse)
pod=35deg
afm=37deg
engine bay=55
pulling up after cruising at 100km/h:
2 minutes to reach heat soak as shown in above (surfers cruise)
and it takes 7 minutes to get rid of it.....
idle on turbo timer:
pod=40deg
afm=45deg
engine bay=60deg
    • No, code 21 is very straightforward. It can only be the things described in that diagnostic flow. In fact it has no way of knowing that the spark plug resistance is out of spec.
