Yeah would work, I personally don't like that one myself and I normally use the one below, don't know why just prefer it over many of the others, just remember clean both surfaces well with carby cleaner put a thin bead around the aac valve let it dry for about 15 minutes finger tighten let dry for another 15 minutes then tighten her up.
http://m.supercheapauto.com.au/Product/Permatex-Ultra-Blue-RTV-Silicone-Gasket-Maker-Multipurpose-95G/5352
Just completed this....took a newbie hour and a half. Car is a lot smoother both when accelerating and standing still. Seems to have removed the engine hunting issue.
One thing I did differently was cleaning the insides, spraying wasn't doing much so ended up filling a bowl with the cleaner and letting it sit for 5 minutes. Also the gasket was in pretty decent condition so just used the same one.
Thanks for awesome walk through! :yes:
  • 1 month later...
  • 3 weeks later...
I've been having a few issues with my car recently in the way thats it seems sluggish and hesitant through the rev range specifically between 2-4k
I recently adjusted my AAC valve before reading this without first unplugging the brown plug (rb20det) could this be a cause to the issue, maybe I adjust it too far or something? Ideas?
  • 5 months later...
  • 8 months later...
  • 2 years later...
  • 11 months later...
Hey All,
First of all good write up!
Has anyone ever had an issue where they have cleaned their IACV and then put it all back together to have a ticking noise from the IACV? Seems to only be present when revving the car and sometimes at idle. I've made 100% sure it is coming from the IACV by unplugging the brown connector, seems to stop straight away when unplugged. Let me know guys, it's doing my head in.
Dan
So I'm stumped... all of a sudden my idle hangs at around 1400rpm for about 30 seconds before it drops to it's set idle of 900rpm, cleaned aac valve and tried adjusting etc etc with no luck, any ideas?
Hi All,
Per my last post, I think the issue maybe due to frequency setting on my Wolf 3D V4. Did some more searching online last night and read that someone has a similar issue to me but in a Haltech.
https://forums.haltech.com/viewtopic.php?t=11221
Since I don't have the hand controller or the cable to connect to the Wolf, I may have to give it in for a tune.
I'll update once I have more information.
Dan
    • No, you're wrong, and you've always been wrong about this. The Nismo has 2 sets of openings. One is a real 2-way, and the other is a 1-way. There is no 1.5-way possible with the ramps that they offer. A real 1.5-way does exist. That Cusco stuff I posted is a prime example. If the forward drive ramps are, say 55°, and the overrun ramps are, say, 30°, then you will get about half as much LSD effect on overrun than you do on drive. It is real, it realy works. OK, you're slightly right. The Nismo has 55° and 45° ramps on the 2-way, so it does offer less LSD effect on overrun. But, I think that just means that they've (probably) sensibly established that you do not want actually equal LSD effect on overrun. You just want "quite a lot, but not quite as much as the drive LSD effect".
    • Just wanted to unearth this and post my baby with the new front ❤️😝 Took her to my wedding rehearsal today. Next up is getting wide skirts (after wedding)
    • Yea, that is what I was getting at in my ramblings too. The nismo one actually is a 1.5 way and a 1 way. They don't do a *2* way because a true *2* way would have equal ramp angles. Or is that a true 1.5 way? Realistically I think a "1.5 way" does not actually exist. A diff can either lock in two directions or one. It also doesn't help that a LOT of people in Australia speak about 1.5 way diffs are referring to their 1 way diff.
    • Well, the trouble with that ^^ is: The configuration shown is absolutely a 1-way, not a 1.5-way. There is no way that a 1.5-way can be said to offer LSD action only on acceleration. If Nismo cannot get that right, then it is impossible to believe their documentation. That ^ is not a 1.5 way setup. That is a 1-way.   And so now I have allowed all doubts to flourish and have gone back to look at the MotoIQ video. I originally made the mistake of believing him when he said "this is a 1.5-way" at the ~6:10 mark. Because what he did was take the gear assembly out of the 2-way opening and just rotate it one place to the left to drop it into the 1-way opening. When he dropped it in there, the cam was "backwards" compared to the correct orientation shown in all other photos of that config. The flat shold have been facing the 1° ramp side of the opening, not the 55° ramp side. And I thought, "gee that's cute", but I was concerned at the time, when he put the other ring back on, that the gap between the rings looked like it was wider then in the 2-way config. And then I said a lot of things in my long post on Tuesday that could only make sense if the guy from MotoIQ was correct about what he'd done. BUT... I have now done my homework. I grabbed a frame of the video with the 2-way config, and then grabbed another with the "1.5-way" config, snipped out the cam and opening of that frame and just pasted it direct on top of the 2-way config. I scaled it so that the triangular opening was almost exactly the same height in both. AND.... the gap between the plates is wider with the cam installed in the triangualr opening backwards. That is.... it cannot go together that way. There would be massive force on the plates all the time, if you could even reassemble it.  So, My statement on the matter? The Nismo diff is actually only a 2-way and 1-way. There is no 1.5-way option in it, regardless of what they say. Here's a photo of a real 1.5-way ramp opening from Cusco (along with the 1 way option). And the full set of 1 through 2 way options from their racing diff, which is not same-same as what we'd typically be using, but...the cams work the same. A little blurry, but it comes from this Cusco doc, which is quite helpful. AND.... Cusco do in fact do what I suggested would be sensible, which is to have rings that do 1 and 1.5, and 1.5 and 2. Separately.
