The restrictor from factory (and aftermarket ones) is about 3mm deep. Generally people just push any new restrictor on top of an old one, so you need to drill 3 to 6mm. But you should drill it out of the block and then push it in later, you don't need crap in the oil galleries.
only problem with that is some restrictors get a bit smaller when you put them in. myne went from a ~1.5mm hole down to almost nothing just from tapping them into the block, then had to drill them out again once they were in
  • 3 months later...
The guys at duncan foster in south sydney fit all those drain back fittings to the end of the head for external oil drain back.
They also fitted to mine a fitting to the exhaust side next to the standard drain ,an external fitting there as the engine leans that way so the oil does not pool up
Makes sense i guess???
Not talking about oil restrictors that are fitted to block ,but oil drain back fittings fitted EXTERNALLY as well
A grubscrew restrictor wont have that issue.
Who ever made those ones that are closing up most likely made them too big in the OD. Too much crush!
they were the tomei ones, but i sent you a long email with far more detail. :thumbsup:
Quick question. I have a neo rb25 which pushes 350 rwkw and sees a lot of track thrashing and limiter action. Never once has catch can seen oil so oil control is pretty decent. Anyway it's all apart now and I'm getting a crank collar fitted and was going to go n1 oil pump. Will I need restrictors in the block? If so what size do ppl suggest. Cheers
They are no good period Simon. Particularly if you are a slider.The constant banging on the limiter will crack the gear as sure as theres shit in a cat.
The last few i saw fail all had the snout extension in place.
A season or two of competition would surely have identified setup weaknesses for the engine.
If you've got no evidence of oil supply/delivery problems, then it sounds like the OEM pump design is ok for the application. Whether that particular pump should be replaced might be an issue to resolve after good inspection.
Are you freshening the engine, or planning on development work and spinning it faster?
A set of billet gears is a worthy investment. I've seen good results from them.
I cant advise you what oil restriction setup works for the neo as I've had no experience with it.
You still need an oil supply to drive the vct but unlike the 33 head you dont have to feed hydraulic lifters. Surely someone on here has had experience with this setup.
I've lost count the amount of times I've hit my limiter with my N1 pump. Hell @ the drags i even flat change just for a laugh.
Virtually 12 months on, no issue at all.
Guess you northern people get different N1 pumps to us down here.
Dale. I spun bearings as a result of an oil cooler connection failure. So replacing crank. Bearings and getting crank collar done also. Haven't pulled my pump apart yet but there was very little in the way of bearing material so I may be lucky. However I kinda doubt re-using it is a smart move. Was leaning toasted cleaning and inspecting housing and fitting billet gears. I don't think I'll run restrictors if I go down this path as pressure and flow should remain the same
    • Who did you have do the installation? I actually know someone who is VERY familiar with the AVS gear. The main point of contact though would be your installer.   Where are you based in NZ?
    • Look, realistically, those are some fairly chunky connectors and wires so it is a reasonably fair bet that that loom was involved in the redirection of the fuel pump and/or ECU/ignition power for the immobiliser. It's also fair to be that the new immobiliser is essentially the same thing as the old one, and so it probably needs the same stuff done to make it do what it has to do. Given that you are talking about a car that no-one else here is familiar with (I mean your exact car) and an alarm that I've never heard of before and so probably not many others are familiar with, and that some wire monkey has been messing with it out of our sight, it seems reasonable that the wire monkey should be fixing this.
    • Wheel alignment immediately. Not "when I get around to it". And further to what Duncan said - you cannot just put camber arms on and shorten them. You will introduce bump steer far in excess of what the car had with stock arms. You need adjustable tension arms and they need to be shortened also. The simplest approach is to shorten them the same % as the stock ones. This will not be correct or optimal, but it will be better than any other guess. The correct way to set the lengths of both arms is to use a properly built/set up bump steer gauge and trial and error the adjustments until you hit the camber you need and want and have minimum bump steer in the range of motion that the wheel is expected to travel. And what Duncan said about toe is also very true. And you cannot change the camber arm without also affecting toe. So when you have adjustable arms on the back of a Skyline, the car either needs to go to a talented wheel aligner (not your local tyre shop dropout), or you need to be able to do this stuff yourself at home. Guess which approach I have taken? I have built my own gear for camber, toe and bump steer measurement and I do all this on the flattest bit of concrete I have, with some shims under the tyres on one side to level the car.
    • Thought I would get some advice from others on this situation.    Relevant info: R33 GTS25t Link G4x ECU Walbro 255LPH w/ OEM FP Relay (No relay mod) Scenario: I accidentally messed up my old AVS S5 (rev.1) at the start of the year and the cars been immobilised. Also the siren BBU has completely failed; so I decided to upgrade it.  I got a newer AVS S5 (rev.2?) installed on Friday. The guy removed the old one and its immobilisers. Tried to start it; the car cranks but doesnt start.  The new one was installed and all the alarm functions seem to be working as they should; still wouldn't start Went to bed; got up on Friday morning and decided to have a look into the no start problem. Found the car completely dead.  Charged the battery; plugged it back in and found the brake lights were stuck on.  Unplugging the brake pedal switch the lights turn off. Plug it back in and theyre stuck on again. I tested the switch (continuity test and resistance); all looks good (0-1kohm).  On talking to AVS; found its because of the rubber stopper on the brake pedal; sure enough the middle of it is missing so have ordered a new one. One of those wear items; which was confusing what was going on However when I try unplugging the STOP Light fuses (under the dash and under the hood) the brake light still stays on. Should those fuses not cut the brake light circuit?  I then checked the ECU; FP Speed Error.  Testing the pump again; I can hear the relay clicking every time I switch it to ON. I unplugged the pump and put the multimeter across the plug. No continuity; im seeing 0.6V (ECU signal?) and when it switches the relay I think its like 20mA or 200mA). Not seeing 12.4V / 7-9A. As far as I know; the Fuel Pump was wired through one of the immobiliser relays on the old alarm.  He pulled some thick gauged harness out with the old alarm wiring; which looks to me like it was to bridge connections into the immobilisers? Before it got immobilised it was running just fine.  Im at a loss to why the FP is getting no voltage; I thought maybe the FP was faulty (even though I havent even done 50km on the new pump) but no voltage at the harness plug.  Questions: Could it be he didnt reconnect the fuel pump when testing it after the old alarm removal (before installing the new alarm)?  Is this a case of bridging to the brake lights instead of the fuel pump circuit? It's a bit beyond me as I dont do a lot with electrical; so have tried my best to diagnose what I think seems to make sense.  Seeking advice if theres for sure an issue with the alarm install to get him back here; or if I do infact, need an auto electrician to diagnose it.
    • Then, shorten them by 1cm, drop the car back down and have a visual look (or even better, use a spirit level across the wheel to see if you have less camber than before. You still want something like 1.5 for road use. Alternatively, if you have adjustable rear ride height (I assume you do if you have extreme camber wear), raise the suspension back to standard height until you can get it all aligned properly. Finally, keep in mind that wear on the inside of the tyre can be for incorrect toe, not just camber
